- Dec 14, 2021
Hello all. For a while now I’ve been experimenting with resin printing to make printed objects look less like plastic. One of the directions has been to make rigging blocks that look a little more like wood and these are now available for those that are interested. (For those who haven't used them, the major advantage of resin rigging fittings is consistency: every block and deadeye is identical, there is no variation in the hole sizes, rope grooves or hole pattern. If the design is good, they simply work).
The variation in colour within the block is created through a dye process and is intrinsic to the block. There are very slight variations between blocks, sizes and batches, which I think adds to the wood illusion. In fact I should say that, to my eye, they bring to mind horse chestnuts and coffee beans, but “faux coffee bean rigging blocks” doesn’t quite cut it! My production process includes ‘de-burring’ i.e. removing the print support pips from the block, and giving them a coat of Vallejo matte acrylic varnish to protect them from UV and fading.
These blocks are intended to be used ‘as is’, with no need for painting or any other finishing or prep by the user. Just rig them straight from the packet. I’ve made the rope holes a little larger than true scale, to make threading easier, and I’m sure there will occasionally be a need to clear the rope hole of varnish residue, though I haven’t found any clogs so far.You can still over-paint or coat them if you wish and the wood effect can be enhanced by polishing with products coatings such as Osmo wax-oil or whatever else you feel like trying out.
I’ve made these available on my Ebay shop in single, double and triple sheave variants; and for now, I’m stocking the four most popular sizes: 3mm, 4mm, 5mm, 6mm.
Here are some additional photos… do bear in mind that close-up photography is a cruel master and the blocks look very smooth to the naked eye.
