Fluyt in oak - Kolderstok by Janzwart
Update 38
For the upcoming model builders' day, I need to pay a little more attention to the flute.
One issue I've been struggling with for some time is the uneven spacing of the deadeyes on the fore shrouds.
I tackled that first. It turned out that I could lower the deadeyes a little without too much trouble, so without too much demolition.
It looks much better now.
The next step is to apply webbing lines and extend the masts with a steng.
But that will come a little later.
Left: Old situation, Right: Current situation.
To be continued
Translated with DeepL.com (free version)
Update 38
To be continued
Good morning. That is a massive improvement. Excellent. Cheers Grant
Update 39,40,41
I started with knotting the ratlines.
And after a while I finished this knotting. One sailor has to test it immediately.
After finishing the ratlines, the “putting” have now also been placed. They still need a few more ratlines.
This is from the foremast:
And from the mainmast
I have also shaped and blackened the yards and I am now busy knotting the various blocks to them.
to be continued
Update 42
Another step forward.
Here, the “fokkesteng” has been inserted and lowered with the “Fokkestengwindereep” just above the mars.
Here, the stay rigging has also been installed and the stay windlass has been shorn. Unfortunately, something went wrong here. Can you see it? I will tell you in the next update.
Here, the main mast has also been placed with the mast rigging and partly fitted with webbing lines.
Here too, the yardarm strip has been shaved. On many models, this is not applied because on real ships it is removed again after the yardarm has been placed. It is not often that the yardarm has to be lowered on a ship, so it is superfluous.
Here, the large steng windlass is attached with a tackle to a ring on the deck next to the mast.
And this is the complete picture at the moment.
To be continued.
But unfortunately Deepl doesn’t know the names of parts of a “Fluit”, and neither do I. I realise that the description at the pictures can be hilarious. Sorry for that.
When someone knows a site where I can find correct translations, let me know.
Update 43
In my previous update, I mentioned that I had started placing the stengewant and applying the ratlines.
However, something did not go quite as planned.
The ropes were much too loose, so when applying the ratlines, you could easily pull them together.
I continued in the hope that it would turn out fine, but it didn't.
I removed it and am going to start again with placing the ropes.
Update 44
Last time, I showed you that the ratlines in the stengewant had failed. So I reattached them. And now it looks acceptable.
I also attached the main backstays
and the main staysail stay.
The jib stays have also been applied and attached to the bowsprit.
And the overall picture.
So now it's time for the yards.
I also need to start thinking about how I want to present the model in order to best show its function as a timber hauler.
But that later.
First, let's continue with the Katwijk bomschuit.
To be continued.
Update 43
Update 44
But that later.
To be continued.
Good morning Jan. Looking mighty fine indeed. The ratline redo is way better. Kudos
Cheers Grant
Update 45
If a "fluit" ship needs to collect wood somewhere, it will probably be anchored in a harbor somewhere and the logs will be towed to the ship. Once it is full, it will probably leave again quickly.
The sails will certainly not be taken down, but they will be raised to the yardarm. I am not sure whether they will just be raised or also tied to the yardarm for safety's sake. I am assuming the latter. So, hoist the sails and tie them down.
But first, make the sails. Kolderstok used a very light white fabric. I cut out the sails, sewed in the strips, and sewed the hems. Then I dyed them in strong tea.
And now they are lying there like this. I forgot to take a photo of all the sails, so the jib is already tied to the yard. But I was able to take a photo of the other sails.
The blind and the mizzen need to be turned a quarter turn and I did not use the bonnets.
The jib is equipped with "lijkentouw" and is tied to the yard.
The blocks and lines have also been attached.
Here the brails have been hoisted.
And here the “gording” have been added. And all that on a third hand.
And finally tied to the yard.
The next step is to hang this yard on the mast.
To be continued.
Update 46
And now to hoist the foreyard. I tied one end of the halyard to the yardarm and fed it through the cap, through a block and back through the cap, and tied the other end to the yardarm as well.
Then I realized that I also needed a truss.
So I made the truss.
And then I tried to attach the truss to the yard.
That took some fiddling around.
I finally managed it. But the result was not what I wanted.
Firstly:
The yard hung too high against the top, so that the lifts did not form a nice triangle with the yard.
Secondly:
The blocks that guide the lifts downwards were much too far from the mast.
Thirdly:
And the halyard had a strange bend.
So again. And take everything apart again:
After some more fiddling, it now hangs more neatly:
The halyard with a block and tackle attached to the servant. I can see now that the end of the tackle still needs to be attached to the head of the servant.
And the halyard now runs without any strange bends.
And now on to the next sail.
To be continued
Update 47
After the fore sail it’s time for the fore top sail.
Here you can see it hanging from the fore top yard track with the necessary blocks, and the brails trimmed and pulled up slightly.
The next step is to hang the yard and attach a few lines. The sailor who did this is a bit cross-eyed because he didn’t notice that the yard isn’t hanging straight.
Oh well, it’s just a workboat; military precision isn’t required here.
A quick look at the foredeck:
And at the braces between the foremast and the mainmast.
Now this model is set aside for a moment, and it’s the Katwijk bomschuit’s turn.
To be continued.
