Makes one wonder what it does to your insides! Another idea, wonder what Coke would do, as it's good for freeing off seized enginesInteresting, I may have found a use for the bottle of Worcestershire sauce which has been in my cupboard for years!
You are probably right but why is the copper plating on the USS Constitution green after being in the water? Same for the plates on HMS Victory (picture below) I did a quick search but the only things I could find are summarized as follows:Copper turns green when exposed to air, not while it's submerged
Jerry, Everything I'm seeing on the web indicates that salt water will cause oxidation of copper plating.Exposure to the air after being submerged in saltwater caused oxidation.
I spray freshwater and wipe off the bottom of my model when it comes out of the water. Where I missed, you'll see green.
If Victory's green, it's because they made it that way artificially. Cutty Sark isn't green, she brown, like a old penny.
Cutty Sark's copper isn't green, it's brown, like an old penny.
I’ll beg to differ with you on that point, Jerry. While that may hold true in small, still bodies of water, out on the open ocean there is more than enough wave action to ensure thorough oxygenation of seawater to a significant depth.I imagine so since that's what I said. Except oxidation requires oxygen, of which there isn't enough underwater to turn the copper green.
After reading further, I think Namabiiru has it right, there is enough dissolved oxygen in seawater to cause oxidation of copper sheathing, although the process is slower compared to exposure in air.
Hi JerryYou're gonna do what you "like" regardless, so go ahead and slap lime green paint on her, tie up those crows-feet to her tops, and cover her in pirate flags, may as well stitch anchor cable sized lines in her sails too - that'll make it look "salty."
That's what copper sheathing looks like after it's been in the air for a while. She was drydocked for some time to do below the waterline repair work. If somebody wants to model a copper sheathed hull, out of the water, it should look like this. The sheathing was never "new penny shiny" by the time the bottom was sheathed and the vessel ready for launch. In the salt air of the waterfront, copper goes green pretty quickly.I don't know if this is helpful or not, but I use a combination of vinegar and salt to get the patina. I made the assumption that the verdigris was everywhere, as per this photo of the Consitution:
