Building a Pinnace
The cutter project is done and the model in it's new home. Now I have a request for a pinnace and hope it will be interesting to anyone following this build.
I chose a pinnace from 1800 as the drawing is quite detailed and the scantlings were all on the drawing as well as a note which are all shown on the copy of the drawing I made. The contemporary plans from RMG that I downloaded are from the Wiki Commons site. First up was downloading it and tracing the profile and top view.
Below is the original and the redrawn version. If anyone is interested I would be happy to scale the redrawn plans to whatever is needed and send out to you. I enlarged the original plan to 1:1 for the initial tracing. For my purposes I then reduced to 1:48 which will yield a 7.5" boat (if I build it accurately :) ) If any mistakes are found, or questions arise please feel free to point them out.
I traced the station lines which are to the outside of the frames. I then reduced them 1.5 inches (full scale) to accommodate the thickness of the frames that will go over the formers. They were then printed on label paper and stuck to plywood. My garage is hot in the summer and sweat dripped off my brow and the ink ran in a couple spots so a new printout is needed, but not a big deal, just a sheet of paper.
The photo shows each former piece on the plywood which is 0.218" thick. With the room and space being 15" (0.3125", 7.9375mm) I like to use spacers to stiffen the assembly of formers. The spacers are 0.094" thick. Believe it or not, the glue will have a thickness to it that can throw things off so when these are assembled on the build board, a continual check needs to be made to avoid cumulative error. Even 0.005" too thick over 20 spaces would accumulate to the boat being about 5" (127mm) too long at full scale, 2.65mm at 1:48
The photo below shows the spacers top left and the plywood with the formers.
Golf course is closed this week for our last punch of the year so more time for the pinnace project. :)
The build board is just a piece of 1/2" plywood scrap cut to meet my needs. The plan view drawing was printed on label paper and put onto the build board. I then drilled holes to accommodate the tops of the frames and hold them in place during the bending and then the planking process. The center portion was then cut out so the formers can be glued wood to wood. Gluing to the label paper does not work for obvious reasons. It's as bad or worse than gluing to a painted surface instead of wood.
Progress on building the forming unit. Note that I cut off the corners so I have room to get a snipper to cut off the frames a little above the board so I can remove the little pieces left in the holes later on and save the forming set up for future builds. I'll try to remember to post a photo of this when this is done for a clearer explanation.
Allan, congratulations on a good start! The replica of the Endeavour's pinnace is very well done. Allan, look for photos on the Internet (I don't have any). Many details omitted from the drawings are visible and understandable there.
Thanks Iutar, your post and photo are very much appreciated. What is the item marked below? I thought maybe a tiller or sail boom but not sure as it looks to be attached to the mast under the thwart.
I see pillars under the thwarts and benches. I have not seen these on any contemporary drawings of a 30 foot English pinnace or models. Do you have any information about these based on contemporary sources? I would like to know more about these.
THANKS AGAIN
This is the gaff. It's been removed and is just lying to the side of the mast.
I have not been able to find any systematic information on stanchions. There are stanchions, then there are none. Considering the large number of people transported by this boat (there is even a longitudinal seat), I think stanchions should be installed.
You may be right. All things considered, the breadth is only 6 foot 4 inches and single banked so typically only one person per thwart. There are fixed thwarts which I think should have a pillar. For the thwart at station "A" there would need to be one on each side of the mast opening. It could be that one would suffice if off center, but it would not look right in my mind.
Thanks for your input Iutar, always appreciated, and a pleasure to see parts of your library of photos.
The "plug" is finished on the building board. Based on the scantlings in the original drawing the frames are sided and moulded 1.25" (0.026"/0.66mm at 1:48). They are pliable enough to bend after only five or ten minutes in water. It is hard to see in the photo, but three frames are in place and rest are laying on the left side of the plug ready to go into a cup of water. The white pieces are cardstock about half the thickness of the frames. They help keep the frames centered on the forming plug and thin enough not to get glued to the planks when they go on.
Planking on a boat is as much a pain in the neck as on the ship itself in many ways, but as it is only 7/8" thick (0.0182" at 1:48 -- 0.46mm) It is very pliable when soaked in water for a few minutes and easy to bend to the hull. Pinnaces were carvel built so I am more concerned with the planks being flush against each other. As this never seems to happy 100% of the time I make the planks a little thicker to account for finish sanding later. There are seven strakes of planking on each side, The breadth of each of the planks midships were typically from 6" to 8" wide so I calculated a breadth that yielded 7 strakes and came up with 0.154" (just under 7.5" at full scale) The tapering of the plank breadth that I did was mostly done on the planks before soaking. Once wet they are clamped to the hull and dried with a hot air gun. After being heated and dry they hold their shape when removed from the hull and any small adjustments in breadth, using the marks on the frames as the guide, are easy to do with a sanding stick. The prepared plank is then glued to the frames and deadwood at the stem and stern.
Note that the planking may cause a little twisting of the stem and stern post even with the frames in place. Small blocks are glued to the building board to keep the stem and stern post on the centerline.
The picture below shows some of the strakes in place. Once completed sanding should smooth everything nicely. You can see at the bow that the planks are not perfectly flush, thus the extra thickness I gave will allow this area to be sanded so the planks are flush when finished.
The planking is on and the boat removed from the building plug. A bit of cleanup is needed and a few planks are slightly bent out of shape at the top but a wet paper towel on the trouble spots for a few minutes will allow them to be straightened out before the wainscoting and gunwales go on. The first photo is one of the forming pieces. Note the corners are cut off. This makes it easy to get a snipper in to cut the frames so the hull can be removed from the plug and leave a tag that can be easily grabbed and pulled out of the board so it can be used again without redrilling.
Doing some studying before making the rudder I found some interesting things that may be a problem for my build.
In the photo of a longboat from RMG below an interesting thing I had not noticed before is that the rudder pins are fixed to the gudgeon, not the pintle. I am not questioning that this may have been done at times, but when the boat was on board and the rudder shipped, the pins would still be there and sticking up. Not an ideal safety situation :eek:
It may be that this is a model for display, but the gudgeons and pintles are brass and not iron or brass that is painted over. Would this be the case on the real boat?
Scaling the boat to 1:1 in CAD, the tiller is 2" in diameter at the rudder, but scantlings for 30 foot and 32 foot longboats from Steel call for a rudder that is 1.75" thick so a 2" tiller would not work. Would the tiller have a smaller diameter iron pin to pass through the rudder, would the tiller be wider and have a slot to fit over the top of the rudder, would the tiller actually be smaller than 2", or would the rudder be thicker than Steel specifies?
Any help or ideas are greatly appreciated.
TIA
Allan, yes, that's right, this design was made in the 18th century and even today. The rudder should be removable, but it shouldn't fall off the hinges by itself. The pin is not as dangerous as it seems
Thanks Iutar
It is a small detail but like most things in these old ships, common sense tells us it would be better this way so, as you pointed out, the rudder would not pop up and unhinge itself in rough sea.
Some progress after being away.
The gunwales, keelson, footwaling and bulkhead are in place. For the scroll work, instead of painting, I inserted a photo of a model from RMG and sized it for the model. I then made a mirror image and printed the painting on paper. I tried it on silkspan with no success so went with standard printing paper. It is far more subtle than painting it with artist colors. Not sure which method I like best, but it is nice to have choices.
Painting from RMG model with mirror image
Scroll work glued to model. I tried using matter medium on a test piece but the colors started to blend together as it water based medium and water based ink. PVA is water based as well but did a much better job and maintained the colors better.
Keelson, footwaling, risers, mast steps and gunwales in place. Definitely some cleaning up to do before adding the thwarts, benches, etc.
Only saw this now: beautiful work! And lovely to see so much detail in a small model.
Allan, I'm sorry, but in 1800, ornamentation was no longer applied to friezes.
Don't be sorry Iutar, I totally agree with you.
The client wanted it and in the end it will be his model. I am not as much of a purest when there is cash on the table.:)
