So very neat and tidy. The ship and surroundings.
Thank you very much for your question, but based on my current knowledge, I'm unable to provide a definitive answer. Due to certain practical limitations, I was unable to conduct thorough research on this aspect. Therefore, the construction of this section was based on references from the books The Statenjacht Utrecht 1746 and Scratch Building the Yacht UTRECHT , which contain drawings and photographs of the section you inquired about.The build continues to be very nicely done! One question for you and your build followers: When, if ever, did the Dutch switch to metal stoves rather than brick? The English changed to iron stoves and it became fairly common place by 1757 but did the Dutch make the change at some point as well?
Thanks
It is great to see that you had multiple sources of information and used them so well.Therefore, the construction of this section was based on references from the books The Statenjacht Utrecht 1746 and Scratch Building the Yacht UTRECHT
Thank you for staying engagedArban, you have the nicest little tools and impossibly clean work area I’ve ever seen! And your Pegasus is amazing!
I quote... an incredible job so far!Arban, you have the nicest little tools and impossibly clean work area I’ve ever seen! And your Pegasus is amazing!
Regrettably, this wasn't carved by me. I only refined it with carving knives. This is a set of CNC-pre-carved pieces made from pear wood!The carvings are exceptional. As the fourth photo show chisels, were all the carvings done with chisels or did you use burrs as well? Your carvings are better than most CNC carvings!
What kind of wood was used for the carvings?
Thanks Arban,
MarvellousView attachment 539515View attachment 539516View attachment 539518View attachment 539517View attachment 539519View attachment 539520View attachment 539521View attachment 539522View attachment 539523View attachment 539524View attachment 539525View attachment 539526View attachment 539527View attachment 539529View attachment 539528
That's sickMarvellous
