Need plans for Sergal Cutty Sark art. 789
I was recently given a model ship from a gentleman that passed away (from his wife). It includes everything except the plans. The instruction book is in the box but none of the plans are there so basically I can't do anything with it. Can somebody help me on a way of getting a set of plans for my ship. Your help would be greatly appreciated.
Here is a link to GM Ship Modelling. These may or may not be the plans you are looking for. I'm not exactly sure of any relationship between Sergal and Mantu, but GM seems to intermix them It may be worth an email to them (with the kit number and scale of your model) to see if they have what you want.
Thank you For your help. I did not see any plans for ships on that website. Just ships for sale .Sergal was a part of Mantua for some years but it doesn't exist anymore. So it's just Mantua
I'm sorry, somehow the url got cut off when I pasted it. Try this link, it takes you right to the page with the plans. Regardless, an email to them wouldn't hurt.
First do some research. Use the Search forum function here on the forum to check out builds for this kit. The hulls for these plank on bulkhead kits generally follow a similar format; transverse bulkheads attached to a longitudinal backbone, some sort of deck attached for rigdity and then the hull planked, maybe two layers.
I believe that it’s possible to build the hull with what you have by carefully reading the instructions. I would sort out the kit contents, putting away parts that you won’t need until later in the build. Then try to match parts with your instructions. The bulkheads need to go on the backbone in a specific order. If you don’t get a fair (nicely curved) hull they’re in the wrong order. Hopefully they’re marked with some sort of logical code.
Once you get a planked hull, if you can’t find drawings than you might want to invest in some good commercial drawings of Cutty Sark not made by the kit mfgr.
Many kit builders complain about the drawings provided with kits for rigging these models. Again there are accurate sources for rigging Cutty Sark when the time comes.
Don’t look long range. Focus on discrete steps with the information that you have. Dry fit parts, stand back, and examine your work until happy with the result.
Roger
Thanks so much for the help, unfortunately, those plans are for the art 958, a later model. My model is the art 789 and they don't have that one, bummer
I have the plans for the 789. I will send them to you to copy but I must have them back as I still need them to finish the model and I always keep a set of plans for anything that I build. How can we do this? Norgale
Don’t forget to get longridges book. There are countless serious errors on the plans most prominently on dead eye position. I built my model basically from longridges book. Twelve years work. No rush.
Oh, that sounds fantastic. I am in Colorado Springs, Colorado, not sure where you are. But we can exchange phone numbers somehow, if you'd like, and then talk about it.
