It can also depend on how you are moving the yard around the mast. It doesn't stay at the center of the front of the mast and pivot, but rather rotates around the circumference of the mast. That can make a great difference.
1. THESE PICTURES ARE FANTASTIC!
1. YES. And to make that slackening easier, the foremost shroud probably did not have deadeyes at the bottom for adjusting, but was instead attached to a very large (oversized) conventional block and tackle (maybe a double or more likely a triple). Adjustments to this foremost shroud had to be made quickly, frequently and securely.I asked the same question when I was rigging my Mamoli Constitution. An experienced ship modeler friend, replied that if the spar needed to be more angled the foremost shroud involved could be slackened at the deadeyes. I suppose that is why the ratlines are not attached to the foremost shroud on each mast.
A major part of the fascination of O'Brian's books was the nautical details- beyond any other I think. They kept me going to the nautical lexicon to decipher and made me understand the complexity of the sailorman's acquired knowledge."He [Jack Aubrey] took two or three turns, looking up at the yards: they were braced as sharp as the main and foremast shrouds would allow, but they were not as sharp as they might have been in an ideal world, and he made a mental note to tell the bosun to set up cross catharpings – they might gain three or four degrees."
Master & Commander by Patrick O'Brian.
That was a central problem with my digital format, since I hadn't set up the truss yet I was simply rotating the yard on it's own pivot to test it's freedom to move. That's one of the shortcoming of digital work, it tempts one to put the cart before the horse at every turnIt can also depend on how you are moving the yard around the mast. It doesn't stay at the center of the front of the mast and pivot, but rather rotates around the circumference of the mast. That can make a great difference.
These are excellent drawings, I will absolutely make getting a copy of this book a priorityBut perhaps the most detailed book on French shipbuilding is Jean Boudriot's four-volume work on the 74-gun ship. It has everything. Look for the third volume on rigging.
View attachment 542628 View attachment 542629 View attachment 542630 View attachment 542631 View attachment 542632 View attachment 542633 View attachment 542634
The pivot point for the yard would be at the center point of the mast cross-section.That was a central problem with my digital format, since I hadn't set up the truss yet I was simply rotating the yard on it's own pivot to test it's freedom to move. That's one of the shortcoming of digital work, it tempts one to put the cart before the horse at every turn
Good point. I should have mentioned in my comment that there didn't seem be any evidence that the British used blocks on shrouds. But having said that, one thing I've learned in researching maritime history is that there was never just one way of doing things.The French sometimes tightened the front shrouds not with deadeyes, but with blocks. But this is not always the case. Most often, the French used deadeyes to tighten the front shrouds.
View attachment 542782 View attachment 542783 View attachment 542785 View attachment 542786
Actually the monograph of my reference ship shows the first shroud connected to a triple block instead of a deadeye, this was not done for the reproduction but apparently that wasn't unknown. It isn't explicitly stated this is done to accommodate the sweep of the yards, but it is interesting and I'd been wondering why it was shown that way.I believe an earlier commenter had it correct in saying that the truss, parral or whatever device was restraining the yard had to have enough slack to allow the yard to swing forward when the sails filled. I don't believe the forward shroud was slacked when the yards were braced up hard. I've never seen a drawing or model depicting a shroud connected to a block and tackle and easing and retightening deadeyes would be too laborious. I believe this limitation on bracing is why in later years the yard was connected to the mast with a gooseneck fitting which extended the pivot point well forward of the mast.
I use blender, I plan to make some videos about the process towards the end. Im about 6 months into the process and maybe 30% doneVery nice modeling. What program are you using?
I should have realized that weeks ago when I asked what parrels were for.The pivot point for the yard would be at the center point of the mast cross-section.![]()
If you're also building L'Hermione I'd love to chat periodically. What kit are you using? (If any?)1. THESE PICTURES ARE FANTASTIC!
2. What book, publication, etc did they come from?
3. I want a copy ASAP. I am just starting to rig my L'H.
4. No matter how much reference material you collect, there always seems to be more and better.
5. Thanx for the update.
