LUGGER REYUSHA ASTRAKHAN, Scratch, Scale 1:40
Lima, Peru
Over the past few weeks, I've been busy writing about other topics and had left my workshop somewhat forgotten, so after cleaning and sharpening blades, I reviewed my plans and cut wood, and here I started a Russian sailboat. I'll begin with its origins and characteristics.
REYUSHA ASTRAKHAN
1 History
The boat we'll be discussing was the "kosovye" boat, whose origins date back to the time of Stepan Razin (1630-1670). In Bogoslavsky's book "On Merchant Shipbuilding in Russia, Rivers, and Coasts," the seaworthiness of a "kosovye" vessel is described as follows.
"With a cutwater inclined 30° from the vertical and a bow raised more than a foot above the deck, the vessel, so to speak, effortlessly rises over the approaching waves. These, when cut by the cutwater, pass calmly without throwing a single drop onto the deck, sliding down the sides of the hull." The first "rechniki" (or "small kosovye boats," as they were then called) appeared in the early 19th century. The name "rechnik" probably comes from the local word "reit" (to tack). The length of these vessels ranged from 8 to 10 m (up to 18 m in some cases), the beam from 1.8 to 2.8 m, and the draft from 0.6 to 1.0 m.”
“The general characteristics of this boat are that the forecastle (from the cutwater to the bulkhead in frame 5) had a shelter where fishermen could rest and seek protection from bad weather. The first compartment (between frames 5 and 9) was used to store nets and tackle. The second compartment (between frames 9 and 10) was for storing fish; the last housed fishing tools and supplies. The open, unobstructed stern was used for working with the nets, preparing food, and other tasks.”
“The boat had a carrying capacity of approximately 7 tons. Regarding the rigging, they carried a quartersail. Later, a fixed mast with a quartersail was adopted. The total sail area was 50–60 m². This simple design allowed for high speed, maneuverability in narrow rivers, and the ability to sail upwind.”
2. References:
Курноскин С. П., Филин П. А. Очерки по истории судоходства уральских казаков [Электронное сетевое издание]. — Москва : Институт Наследия, 2024. — 216 с. – DOI 10.34685/b7429-1676-0824-w. — ISBN 978-5-86443-462-8.
Kurnoskin S. P., Filin P. A. Ensayos sobre la historia de la navegación cosaca en los Urales [Publicación electrónica en línea]. - Moscú: Instituto de Patrimonio, 2024. - 216 p. - DOI 10.34685/b7429-1676-0824-w. - ISBN 978-5-86443-462-8. (Paginas 109 a 114)
3. General Information
REYUSHA ASTRAKHAN
Country: Russia
Type: Sailboat
Function: Transport/Fishing
Length: 11.04 m (276 mm)
Beam: 3.17 m (78 mm)
Draft: 1.14 m (28 mm)
Overall Length: 12.59 m (315 mm)
Overall Height: 11.00 m (275 mm)
Scale: 1:40
4. Model Preparation
The idea and information were taken from the magazine Modelador-Constructor (MK-1985/05), A. Timoshechnin. From the plans and hull lines, the sections for the frames, the deck shape, and the dimensions of the sails and rigging were obtained. The drawing was done in AutoCAD, and using the resulting PDF file, the false keel, frames, and main parts were laser-cut from a 4 mm plywood sheet. With the cut sheets available, the parts are disassembled, sanded, and presented; they are glued with white glue, realigned, and mounted on a frame. The frames will then be sanded to shape them and receive the 5 mm strakes.
Well, this is as far as I've come. I'll take it easy and hope to finish in a few weeks.
Отличное начало! Спасибо за фотографии процесса!
Если вас особенно интересует малое судостроение в России, у меня есть кое-какая информация, которую я могу вам предоставить для начала.
Желаю Вам чудесного дня и всего самого наилучшего!
Здравствуйте! Пишу вам через Google Translate. Да, меня интересуют лодки, и я буду благодарен за любую дополнительную информацию. Некоторое время назад я сделал кох, который можно посмотреть по ссылке. С уважением.
Of course, calling this boat a Luger is too serious :) A Luger is a well-designed combat vessel after all. "Reyushka" is a type of fishing or trading boat. They were built from whatever came to hand and as they came up with.
Your picture says: "Sailing boat on the Volga River" that's really correct.
In the last few days, and now that I'm ready to finish the boat, I've been reviewing the bibliography and references, and I have to make some changes to the text. There aren't many, but they're necessary. Later, I'll post the photos to complete this boat.
REYUSHA ASTRAKHAN
1 History
Originally, boats of this type were called small kusovye, from which all other varieties arose livestock, frame-mounted, and transport. The Reyusha, or also Rayushka, came from the small kosovye boats and were built on log beds. They were used in the seal fishery, which is why they were also called seal boats.
Their origin dates to the time of Stepan Razin (1630-1670). In Bogoslavsky's book "On Merchant Shipbuilding in Russia, on Rivers and Coasts," the seafaring qualities of a "kosovaya" boat are described:
“The general characteristics of this boat are that the forecastle (from the cutwater to the bulkhead in frame 5) had a shelter where fishermen could rest and take shelter from bad weather. The first compartment (between frames 5 and 9) was used to store nets and tackle. The second compartment (between frames 9 and 10) was for storing fish; the last housed fishing tools and supplies. The open, unobstructed stern was used for working with nets, preparing food, and other tasks.”
“Reyusha had a carrying capacity of approximately 7 tons. As for the rigging, they carried a jib sail. Later, a fixed mast with a jib sail was adopted. The total sail area was 50–60 m². This simple design allowed for high speed, maneuverability in narrow rivers, and the ability to sail upwind.”
In another book by Kurnoskin S.P., Filin P.A. also describes the Reyusha, in the following paragraphs:
“Thus, was born the Reyusha, a type of Caspian sailing boat: beautiful and swift. Fishermen began to use it, under the name of the small fishing kusovaya, for search fishing, where speed was as important as in the seal trade. Initially, the sailing rig was transported like that of the frame-mounted kusovaya.”
“But the mizzen mast, which had a barley sail, was removable; while working with the fishing gear, it was stored on deck. These vessels set nets throughout the North Caspian and, throughout the day, and sometimes even at night, sailed from one fishing spot to another, or in search of a stable vessel to deliver the fish. The crew usually consisted of three people. In calm weather, they rowed and, in narrow, shallow channels among the reeds, they pushed with poles.”
“The rudders had the same design and contours as those of the kusovye, except the stern was uncovered; the sides were tarred on the outside, and the deck was impregnated with drying oil. The hull was divided into compartments; in the bow was a narrow forecastle (just over a meter high and a meter and a half wide); next to it was a net store, then a fish compartment, and the last compartment contained hooks, firewood, and utensils. Behind the bulkhead of this compartment was the cabin, where the helmsman steered while underway.”
2. References:
REYUSHA ASTRAKHAN
Country: Russia
Type: Fishing boat
Scale: 1:40
The idea and information were taken from the magazine Modeler-Constructor Magazine (MK-1985/05), mkmagazine.almanacwhf.ru – A. Timoshechnin. Also, from the book "Essays on the History of Cossack Navigation in the Urals." From the plans and hull lines, the sections for the frames, the shape of the deck, and the dimensions of the sails and rigging were obtained. The drawings were made in AutoCAD, and the resulting PDF file was used to laser-cut the false keel, frames, and main parts from a 4 mm plywood sheet. Once the cut sheets were available, the parts were disassembled, sanded, and presented; glued with white glue, realigned, and mounted on a frame. The frames were then sanded to shape and received the 5 mm strakes. The dimensions of other minor elements were taken and redrawn freehand on a workbook.
For the hull up to the bow, 2x5 cedar planks were used. The good wood made it easy to bend. I finally finished it, and the first skin turned out quite well. I filled it with a mixture of sawdust and white rubber, sanded it again, and applied a light coat of honey stain reduced to 25%.
The deck was made with 4x100 mm strips of 0.5 mm veneer, glued with white glue over 1.5 mm veneer. The foremast, mizzen, and yards were prepared. They were all stained a honey color; the rudder and tiller, the hold, were also prepared. The chain stays, anchor, and fishing tackle were also prepared.
The sails were cut to the measurements obtained from the plan and are made of a white cotton fabric, which is difficult to glue; the clews for the sheets were made. The ropes were of different gauges, 0.6 mm dark-colored for the shrouds and for hoisting the yards, and 0.45 mm light-colored for the running rigging and halyards. This final section presents photos of the finished Reyusha.
REYUSHA ASTRAKHAN
1 History
2. References:
REYUSHA ASTRAKHAN
Country: Russia
Type: Fishing boat
Scale: 1:40
Studying abroad has been the best experience of my life, but writing lengthy academic reports in my non-native language takes me forever. I was struggling to find credible sources for my economics paper and didn't know how to integrate them smoothly. I ended up looking at https://essays.studymoose.com/buy-research-paper/ to see how professional writers cite their economic data. It was an incredible learning tool that boosted my confidence immensely.
Thats rly awesome!
