I am a 78 years old Japanese model ship building enthusiast.
Wanglius san
Thank you very much for your wonderful post.
I really appreciate your introduction of so many Japanese ships and their related websites.
KingDaddyo san
Thank you for your interest in Japanese ships.
As a Japanese, I would recommend the Higaki Kaisen kit.
It is also available for overseas purchase.
In addition, I once assisted with the building of a Higaki Kaisen on the forum that Mr. Hunt of Lauck Street Shipyard used to host, so I can also send you the reference materials from that time.
Woody Joe Overseas Sales
https://woodyjoe.shop-pro.jp/?mode=sk#overseas
Higaki Kaisen
https://img07.shop-pro.jp/PA01355/556/product/104473077.jpg?cmsp_timestamp=20160915165310
That’s all, thank you in advance.
Additional note: A junk is a Chinese ship, while Japanese ships are called wasen.
rtwpsom2 san
Thank you for your post.
I appreciate you providing information that even I, as a Japanese person, did not know.
It’s true what they say: the lighthouse is darkest at its base.
All,
By the way, the kit isn’t nearly this complicated.
Since you just have to attach the planks, those who are planning to build the kit need not worry.
Also, I would like to introduce a reference book.
Nowadays, it’s easy to translate things quickly.
If you’re interested, please give it a read.
https://www.amazon.co.jp/日本の船を復元する-古代から近世まで―復元するシリーズ〈4〉-GAKKEN-GRAPHIC-DELUXE/dp/4054016502?language=en_US
This is a typical website explaining traditional Japanese ships.
https://www.kitamae-bune.com/about/main/?utm_source=chatgpt.com
I stand corrected on the ship name, my apologies. What does Wasen translate to? I watched the first couple of videos posted by Tanaka Takanao on the Higaki Kaisen. He is very skilled as the videos clearly show. I am very interested in the Higaki Kaisen as my next kit to build. I have bookmarked it to order soon so I will have it on hand when ready. It is available on Amazon thru the Woody Joes store.
I can see joining this forum was a great idea. You meet diverse people with so many skill levels! The most important thing is all the help you all offer as I learn and build!
King Daddyo san
Wasen is a traditional Japanese wooden sailing ship or a small hand-rowed boat. Its structure is entirely different from that of a Chinese junk.
During the Edo period, Wsen were categorized as Hishigaki-kaisen, Bezai-sen, and Kitamae-fune. Like Virginia sloops or Bermuda sloops in the West, these ships share the same basic design, with only minor variations in details.
For more information, please refer to the website I shared in my previous post. If possible, I also recommend reading books on the subject. Modern translation tools make this process quick and convenient.
https://www.amazon.co.jp/日本の船を復元する-...N-GRAPHIC-DELUXE/dp/4054016502?language=en_US
I look forward to seeing your Hishigaki-kaisen. These ships are structurally very different from Western sailing ships. In particular, when they are hauled ashore, the mast is lowered, and the rudder is also lifted toward the stern.
Thank you very much.
Postscript 和船=wasen 菱垣廻船=higakikaisen 弁財船=bezaisen
船=sen or fune
Masaaki Hikosawa san (did I say that correctly?)
I will be ordering the Hishigaki-kaisen soon. Will keep you informed as I receive and open box to review it. I did look at the book and will order it as well. Google Translate does make it much easier to negotiate other languages. The launch I am building right now, all of the large scale prints are in Italian and I use my phone for reading the prints!!
I will be watching many more of the Tanaka Takanao YouTube videos on the Higaki Kaisen. I think I will learn much from his building techniques. I think, initially I am intimidated by his skill level. All the more reason to not only watch them, but watch them closely and follow them while building mine when I get it.
Appreciate your guidance and conversation!! I am also going to be buying the Woody Joe 1/50 Nikko Toshogu Shrine Yomeimon Wooden Model. I love the artistic detail and overall beauty of the shrine and think it will be a challenging build for me to do it justice.
Respectfully,
Eugene Keith
OK, progress photos. I have taken the temp bulkheads out. Sanded the remaining portion of the bulkheads level for fitting the floor in. I have pre-sanded the port and starboard sides with 80-100 grit. Then I applied wood filler to all rough areas and re-sanded with 120 grit. Once I had it down to a better finish I started with the starboard side and fine filled wood filler to all visible small linear gaps. I then sanded this down again with 120 grit. Then I went over the starboard side again to touch up any minor gaps I missed and then sanded it down with 120 grit again. It looked well filled as far as no visible gaps so I worked my way from 180-220-320 and now I think it might be good enough. (I keep reminding myself, don't let prefect get in the way of good enough) I now have to start the same process for the port side. Once I'm done with that I'll do the inside and outside of the transom and then go onto the interior walls and lower deck surface. I have decided to go shopping for a single piece of wood that will let me build the cap rail. I'm going to match the kit wood and trace the hull outline on a single piece of wood and then cut it to shape to fit along the cap rail location. This should give me a cleaner look, not have to cut and fit several pieces and not have to deal with bending thicker wood. Once the cap rail is in place and before I finish it, I'll use an exacto knife and etch lines where the joints would have been. Should have the same finished look.
Slow but good progress.
OK, so I changed my mind. I went back and followed the 400 grit up with 800 and then 1500 grit. Now I have to go find someone with a baby tomorrow so I can see if it is as smooth as a baby's butt..... I have to admit, theres a substantial difference between the finish on 400 grit and 1500 grit!! On to the port side.
King Daddyo san ,
My name is Masaaki Hikosawa.
彦沢 = HIKOSAWA, 正明 = MASAAKI.
Therefore, you have written my name correctly.
Additionally, “the Hishigaki-kaisen” is incorrect.
The proper term is 菱垣廻船 = Higaki-kaisen.
I am very pleased that you have taken an interest in Japanese ships, wasen.
By referring to the book I introduced and the kit’s instruction manual, you should be able to complete it without any difficulty.
Please pay particular attention to the finishing of the stern, as it is easy to make mistakes in this area.
I am attaching a photograph for your reference:
https://www.oceandictionary.jp/z/z23000/z23613.jpg
For your information, here are URLs for a wasen preserved on Sado Island, Niigata Prefecture, where I reside:
https://www.visitsado.com/event/3544/
https://www.google.com/search?sca_esv=453f87096d44fbd1&sxsrf=AE3TifPkbC_vDv-wjUH54mpvyY39kiPRzw:1757399060783&udm=7&fbs=AIIjpHzMeWLHhiYizDqllP6shc4y4UUCaI3quTWbnoCuZpW64fKPvoQPOwVLnLctdj9U3xe0wHfy3GdwOPqqqivnTql1racnoV9xT9CZS57lRB3RQ2ZKTjaamKaSt4Pj5zu-h7O6MrpQ9uHythkIc5dToakoz6PbqVLDW9fwGrit4bJ-CZMWQ-TV7MbuCtK47lIFz_9UtWItEnRWhYnDOoLuOm6UwRxtYBMjlRg039gthGgWJn6WBEQ&q=佐渡白山丸&sa=X&ved=2ahUKEwiYnPzVhcuPAxWgoq8BHVBEHpcQtKgLegQICBAB&biw=1200&bih=486&dpr=1.6#fpstate=ive&vld=cid:b432cfed,vid:GaRV3NHwLpY,st:0
Finally, the photograph you posted appears to be of the kit you are currently constructing.
I am greatly looking forward to seeing the completed model.
Yours sincerely,
Masaaki Hikosawa
P.S. "The materials I attached are brochures from the now-closed Museum of Maritime Science. Therefore, there are no copyright issues."
Thank you for the links!! I have not purchased the Higaki-kaisen as of yet. I have it book marked the location on Amazon from Woody Joes Store. I have to begin negotiations with my wife for the funds to procure the kit. We have been married for 49 years so I have learned the proper procedure for obtaining something outside of our budget. That way I can make it happily to 50 years of marriage!! No worries, I will get it in the next couple of months, likely before I finish the current build. I am also going to obtain the 1/50 Nikko Toshogu Shrine Yomeimon kit as well. I think that will be enjoyable to build.
You were right about my current ship. I am building the Amata Armed Launch. I have completed planking all three layers on the hull and now am starting the rough finishing before I do the wood filler. Once I have completed the wood filler I can go back again and do the full range of sanding from 120 grit up to 1500 grit. Still a ways to go. I'll post more photos later.
Respectfully,
King Daddyo
King Daddyo san ,
Just to let you know, the kits are available directly from the manufacturer.
And besides the Higaki-kaisen, there are many other kinds of kits.
A German lady I know even built a Japanese ship from 500 years ago.
〈How to order from overseas〉
Contact Form
https://woodyjoe.shop-pro.jp/customer/inquiries/new
I will also celebrate my 50th wedding anniversary next year.
In Japan, once you get married, the entire salary goes to the wife.
The husband lives on the allowance that the wife gives him each month.
There is an old Japanese saying: “Marriage is the grave of life.” (laughs)
That’s all for now. Best regards.
Respectfully,
King Daddyo
Hey Daddyo, I have also learnt how to negotiate with the wife and she was happy for me to pay the money for model to be bought but she did not realize I had to ship it out to Australia, which was as dear as the kit itself. However, my wife only sees a bunch of sticks, not like me, a nice smelling cherry wood and all the other woods sent that along with also, fantastic drawings that make it quite simple? to do. Keep hackling. Best of luck. May your sanity prevail.
Wanglius san
KingDaddyo san
Higaki Kaisen
Masaaki Hikosawa, Thank you for those magnificent pictures of the ships and sail boats from Japan and Asia generally.
I am after my build of the Bounty, do a Chinese Junk in model form also.
Regards
Dear all,
I am very pleased that you are interested in Japanese ships—Wasen.
There are significant differences between Japanese sailing ships, Western sailing ships, and Chinese junks.
The Higaki-kaisen, a representative Japanese sailing ship from the past, has neither a keel nor frames like Western sailing ships, nor does it have bulkheads like Chinese junks.
If we describe Western shipbuilding as “plank-on-frame” and junks as “plank-on-bulkhead,” then Wasen are simply plank-built. Therefore, their structure is relatively fragile, and they were primarily built and used for coastal routes.
About 400 years ago, Japan did possess plank-on-frame shipbuilding techniques. However, the Tokugawa shogunate prohibited the construction of ships capable of open-ocean navigation, which meant only fragile coastal vessels like Wasen could be built. “Please refer back to the materials I posted earlier.” I believe Wasen offer fascinating subject matter for sailing ship model enthusiasts.
For those who are planning to build a Wasen model, I strongly recommend looking at the works of The Rope, the group I belong to. I am sure you will find them very helpful.
Thanks for reading.
THE ROPE 50TH ANNUAL SHIP MODEL EXHIBITION 2025
https://www.theropetokyo.org/2025/03/30/第50回ザ-ロープ帆船模型展2025/
50-01 Naniwa-maru
50-55 Godairiki-bune
THE ROPE 49th Annual Ship Model Exhibition 2024
https://www.theropetokyo.org/2024/04/05/第49回ザ-ロープ帆船模型展2024/
Higaki-Kaisen
49-13
49-14
49-16
49-17
Sengoku-bune
49-15
UMI-GOZBUNE ‘Taihou-maru’
49-18
the 44th Exhibition 2019
https://www.theropetokyo.org/展示会作品集/第44回展-2019年/第44回展-4-5/#44-30
Higaki-Kaisen
44-30
P.S. I recommend the following books to those who would like to learn about Chinese junks.
https://www.amazon.co.jp/歴史の海を走る―中国造船技術の航跡-図説-中国文化百華-山形-欣哉/dp/4540030981
