Thanks, but my Dremel is a huge beast. Plus it has a large stiff electric cord that I’d have to keep clear of the model while drilling hole after hole. Looking for something much smaller. Sometimes called a pen drill.I prefer to dremel. I think we should be patient and proceed slowly.
Yeah. That’s the form factor I am looking for. Without the engraving functionality.
Looks nice. That minimum 5000 RPM isn’t an issue when drilling wood then. Was worried about that.Have a look at the DREMEL model 2050. I have one and it works perfectly for jobs like you are describing.
Jim
I have bought a number of mini drills - it saves having to keep changing the bits and collets for different drill sizes. All work well and cost about £15. Some will take a dremel chuck to make life even easier.I have maybe a thousand 0.5 mm nail holes to drill in my hull. (Dunno really, haven’t counted em yet)
Don’t want to use my Dremel nor my manual pin vise.
What small portable electric drill do you recommend?
Makes sense. Thx.If your worried about RPM limits, remember that smaller bit work better at higher RPM, they bog down and break when used at low RPM.
Manual drilling is different then slow RPM powered drilling, as when using by hand, you can feel the bit digging in and stop before breaking.
Thx. I do want to buy a few 0.5mm bits. Only have one on hand. And it’s got “break me” written all over it.I placed a link in this topic to a nail drill machine. Cheap and perfect for the job. I use that too.
Tutorial - An easy introduction to making wood ornaments by Stephan Kertész (Steef66)
For the Modelbouwer I wrote an article about carving and I wish to share it with you here. I hope this will an educational subject to get more people into carving or take away the fear on starting with it. Sometimes you come across models of historic sailing ships that have beautiful ornaments...shipsofscale.com
and I bought special drill bits for it (blue boxes) from 0,3 to 2,3 mm is available. So if you only need 0,5 buy only them.
So, inspired by your technique, I ordered a couple of these from Temu.I have bought a number of mini drills - it saves having to keep changing the bits and collets for different drill sizes. All work well and cost about £15. Some will take a dremel chuck to make life even easier.
Looks good. I ordered a couple of the cheap drills, and this one. I was looking at the K2, because it had a collet that takes diff drill shafts - but someone posted a vid showing a small drill wobbling in the K2 - so I am going with your suggestion - the F2. If all three drills function - I can put my most used tiny bits into each one. And enjoy the luxury of ready to use drills.Try this beauty. fanttik f2 master
I Presumed its for tree nailsI have maybe a thousand 0.5 mm nail holes to drill in my hull. (Dunno really, haven’t counted em yet)
