Model Shipways U.S.S. Constitution cross section
Hey all, looking for clarification on the rigging of the topmast shrouds for the build. This will be my first attempt at this model and having a great time with it. Th instructions indicate 6 18" lengths which makes more too many shrouds for the fighting top/top mast.
I am sure there is a thread on this somewhere. Please advise.
Cheers
Mikey 52
Builds:
Correl HMS Victory cross section
Mamoli USS Constitution cross section
I'm wondering if that's a typo at the bottom of page 70 indicating the number of shroud lines to prepare.
It looks like there are ten deadeyes, so that should only require five shroud lines.
I tried reading further ahead, but didn't notice any reference to using the sixth shroud line.
I'm building the same kit, but I'm barely started on the hull. However I've noticed a number of errors in the instructions or details left out. They even show special tools being used that weren't on the list in the front of the first manual.
I believe there are only 5 topmast shrouds. I would cut them a few inches longer to make sure you have enough length. There are many errors in the instructions mostly dealing with how thick or long some piece is. Pat a word of caution, when assembling the side walls of the gun deck make very sure of which side goes where, the pieces are asymmetric and poorly marked. I got into a big jam placing the wrong pieces on the wrong side.
I have a build log of my progress and in the beginning I mentioned 2 other build logs that have been invaluable to me.
Rob
After I posted this, I found another build log on Model Ship World which addressed several issues that I have had. Tom has great suggestions and some clarification regarding the instructions for this kit.
Thanks Pat and Rob for getting back to me!
Model Ship World blog can be found here:
There are several pages (at leased 5).
Mike
Mike
Yes Tom Culbs build log is one of the two I mention in my build log. His work and knowledge has been invaluable in helping me construct my cross section. Mike and Pat you should both consider your own build logs. I find them very helpful!
Rob
I may Rob, new to this build log stuff. I want to go back and look at yours as I need all the help I can get with this kit.
Mike
After reading about problems people encountered because of the frame deck beams, I decided to mark the top positions of the orlap and berthing deck beams on the end frames, label them, then cut them off of the frames.
It really opened up the lower areas, making it much easier to work.
I'm also combining the hold and berthing ceilings into a single piece of 1/16 inch basswood on each side so the diagonal bracing can be modeled more accurately.
