Santìsima Trinidad 1:84 by Artesania Latina - Build log
Italy
Hello everyone! The time has come to open the new Santisima Trinidad shipyard and begin the new log.
First of all, thanks to everyone who followed my Victory log and gave me valuable advice!
So, let's begin by examining the box and making some preliminary observations.
The materials appear to be very well packaged, with care taken to separate them clearly and easily identifiable. In particular, all the small parts are contained in four separate plastic boxes, making them easily accessible and easy to store while waiting for their use.
The various strips are also divided by size into labeled bundles.
The pre-cut boards appear to be made of good material, and all the pieces are immediately identifiable with abbreviations printed on the piece itself whenever possible.
Overall, therefore, the materials and packaging appear to be of good quality, generally in line with the OCCRE and Amati kits (which I have previously used) and decidedly superior to those from Mantua Models.
A rather unusual feature is the complete absence of plans or paper instructions, which is certainly compensated for by the possibility of downloading numerous PDF files. In the case of this kit, about fifteen files provide over eight hundred pages of fully photographic explanations.
Personally, I find this system very convenient, because with a reasonable level of experience (and for a model like this, that's absolutely essential...) you can have a thorough understanding of all the construction phases without having to follow them to the letter.
Furthermore, using a tablet to view the PDF files allows you to easily zoom in on each image, achieving greater detail.
Finally, this is a model with a single-plank hull, and for me, this represents a new challenge that I'm really curious to tackle, especially since the same method is used to build the decks.
I don't think I have anything else to add, so it's time to get to work!
Hey Ismaele,
You've picked yourself quite a challenge there. It's huge and will definitely keep you busy for a long time. PDFs are good, but I still prefer the construction plan. I like having a construction plan where I can look up parts or make adjustments. I hope you have fun and I'll be sitting in the front row to watch you... :D Thumbsup
Really in the set there is a big double faced colour poster reproducing a view of the entire ship, a lateral view of the hull and an above view of the decks. I didn't mention it, but actually it will be useful.
I've started assembling the frames on the keel and I'd like to share two details that I think are useful.
This is my first time using Titebond Quick & Thick glue, and I find it fantastic for this type of bonding. It has a very thick consistency, so the best way to apply it is with a dentist's spatula, which allows for maximum precision and avoids wasting glue. This prevents drips, and the glue also allows for the ability to slightly move the pieces while assembling them, while also drying very quickly.
To ensure the pieces are assembled at 90°, after several attempts with different set squares, I've decided that the best method is to use two Lego blocks I stole from my grandchildren!
First impressions of the structure's assembly.
The pieces are contained within 3 mm thick plywood boards. The laser cuts are very precise, and the piece numbering is foolproof.
On the other hand, the quality of the material is rather poor, and I would certainly have preferred a thickness of 4-5 mm. Assembly, given the precision of the parts, is certainly easy, but great care must be taken in handling the pieces to avoid unwanted breakage.
Furthermore, once the glue has dried, don't even think about going back to correct any small misalignments, because breakage is guaranteed (and I say this because it happened to me...).
In any case, the entire structure seems very well thought out, and I can already say that once all the parts are installed, the hull frame will certainly be sturdy and non-deformable, despite being lightweight.
I'll give you a definitive opinion at the end of this phase.
With Titebond, you should be able to wet the glued area and then loosen it.
Thank you, but I think this can work only when the glue isn't yet completely dried, so I didn't even tried this technique. Anyway the breakage was minor and easily repaired. I only mentioned it to emphasize the weakness of materials.
I've finished assembling the main hull structure and can confirm my first impressions.
The materials are light and thin, individually much less robust than those I've found in other kits so far.
Nonetheless, the precision of the cuts and the abundance of joints, combined with a greater number of frames, ensure that the structure, while overall lightweight, appears solid and non-deformable, forming a rigid cage.
It reminds me of the structures seen in aircraft models.
Ultimately, the result so far, even though achieved using different methods than I was used to, is satisfactory.
Now comes the most difficult part, because the decks and hull planking also require methods that are new to me.
But we'll talk about that next time...
Just a thought as I have only been building for a year and have limited knowledge compared to the experts on here, but I have built my first ship, then a WW1 aircraft and now on my second ship, but although the many pieces appear flimsy on all the models, so require TLC, but when assembled are pretty solid.
Your progress so far looks good and when the decks etc are installed will give it rigidity.
Also it is quite a big model and surely will be even more flimsy due to its size until the decks etc are installed.
My first model was an OCCRE beginners build with the second model being the Artesania Latina Sopwith Camel and now the OcCre The Black Swan.
All pieces appear flimsy as I said but they are models.
Keep going because I am enjoying it. Thanks
