Where to find plans for US Cargo Ships
I am looking for plans for the SS African Comet (1962) (hull number C4-S-58a) and/or the SS Pioneer Myth (1954) official number 267033. I have tried getting around the US National Archives site with no luck. I have just emailed Ingalls Shipbuilding and hopefully will hear back from them, but if anyone has a suggestion that would be great.
Thanks
Allan,
How about the Mariners Museum, Newport News, VA? I see that the nearby Newport News Shipbuilding and Drydock Co built several C-4 vessels.
According to Wikipedia: Like other MARAD designs, this is a case where a basic hull form was used for several different applications. So, this may be a case where if you can find an accurate hull drawing you will have to fill in the details for your particular ship.
The design was apparently versatile enough that the basic hull form could be stretched by adding a mid body section. You can do the same thing to fit the hull to your particular ship as the mid body was parallel and the lines fore and aft did not change.
Roger
Thanks Roger,
I will definitely look at this. There were six ships built to the African Comet design so if can find these that would be best but barring that, your suggestion may be a good alternate route.
Thanks
Model Shipwright has plans for U.S.N.S Comet which I believe is the same ship. Take a look and good luck!
Found the following which is labled at the African Comet class. Need the body plan though.
They give the following description
In August of this year Farrell Lines Incorporated took delivery of the first vessel in its "Third Fleet." The African Comet, built by The Ingalls Shipbuilding Corporation, a division of Litton Industries, is the first of six ships in FarrelLs current $621/2-million building program. They were designed by Gibbs & Cox, Inc., New York naval architects, who also served as owner's representative in connection with approval of plans, purchase specifications and inspection during construction. The African Comet is a big ship. At 572 ft LOA, she is the largest yet built under the present Maritime Administration subsidy program. Her total bale capacity is 688,026 cu ft, including 28,000 cu ft of refrigerated space. Her total carrying capacity homebound from Cape Town, Union of South Africa, is 10,700 dwt.
Thank you very much, but the African Comet on which I sailed was not a navy ship, but rather a freighter launched in 1962 and was owned and operated by Farrell Lines. With five sisters of the same design coming out of Ingalls' yards I am sure there are drawings somewhere. The hunt goes on. :)
Richie, It looks like you could build a whole new ship from these drawings. Thanks for posting.
Roger
Roger
There are three variants of the C4 on the website. The only difference between the S- and B-series hulls was just 1 meter (3 ft) . It makes sense that all S-series ships have the same hull, including the "African" (A58) ones.
But if possible, you should still check the information.
Why don't you use NARA? They have the original C4-C drawings. After all, it is known that the differences in the hull are insignificant?
You may be right but looking at the profile drawings and photos of each type ship they are completely different. Also I found the following:
C4-S-A3 ships were built during WWII and were designed as troop ships that were 523 feet long and 9000 HP
C4-S-58a ships were built nearly 20 years later, were 575 feet long and made for bulk cargo with about 16,000 HP.
I still hope to find the correct drawings, but I truly appreciate the reference you sent. Thank you kindly. :)
USNS Comet is not the same design as African Comet.
I was good friends with a retired now deceased chief engineer aboard the African Comet.
He loved that ship.
We both searched for plans but could only find the profile that you already have.
I understand. Then it's better to take Mr. Roger Pellett's advice. And add a section.
To increase the length of the hull, this was often done without changing the hull contours at the "ends".
I am not sure the body plan is the same anywhere on the hull. The beam is different as well. I can expand the body plan in CAD, but what about the vertical size? I have no idea on this dimension at each station. There may be too many variables to use Roger's suggestion. In the end, it might work, but I need the body plans on the C4-S-58a to know that, and that means I have the right drawings that I am looking for. Catch 22??? The hunt goes on :) :)
Thanks Richie Incident -- BTW does your screen name have anything to do with 1988 Richie Incident in Beverly Hills? That was a brawl of some notoriety.
No. I'm from Russia. At one time, when I was into rock and roll, my band was called Incident. Back then, my friends nicknamed me "Ritchie" after Ritchie Blackmore. But not because of his ability to play the guitar, but because of the sin of pride like his ROTF
