I appears that you beveled the edges of the strakes on the upper part of the hull. The best u can tell us that the edges were not beveled in the portion if the hull below the waterline.I've finished sheathing the sides below the quarterdeck. I still haven't decided what to finish the forecastle and quarterdeck with. The blue hornbeam issue is still unsolved. I'm leaning toward mahogany, which I used for the lower hull. But I still have work to do on the forecastle and head, and I've also thought about using padauk (a solid red material) to frame the gunports. I'll also use it later to make the inside of the gunport covers, so I don't have to paint them.
View attachment 558250View attachment 558252
View attachment 558259View attachment 558253View attachment 558254View attachment 558255View attachment 558257View attachment 558258
I will remember this technique. A great way to achieve precision.
Did you plank the bottom side of the stern platformsToday I tried to make slats of moldings. Of course, you don't have to expect them from the Chinese in the set, because, as they say.: saving drowning people is the work of drowning people themselves (another Russian saying). Sawn 4 by 2 mm slats made of beech and walnut. Using a mini engraver and diamond cutters, he made a curly loop out of a piece of hacksaw blade. It didn't work out right away, I had to spend half a day. The beech molding covered the end of the balcony of the upper gallery. Of course, I had to bend it with a soldering iron first. I'm not entirely happy with the result, probably I should have sawed pears instead of beech.
View attachment 562219View attachment 562220View attachment 562221View attachment 562218View attachment 562217
View attachment 562214View attachment 562216
Yes, I covered the lower balcony with mahogany veneer, as well as the quarterdeck. I will not paint the model.Did you plank the bottom side of the stern platforms
Thank you. I will follow your lead on this as I'm undecided on the paint.Yes, I covered the lower balcony with mahogany veneer, as well as the quarterdeck. I will not paint the model.
Looks great, very precise
Думаю, это будет правильная высота.View attachment 563260
I have already written in previous messages here about this error and that it is necessary to raise these beams. The distance between the balcony galleries should ideally be 35 mm.I think this will s the correct elevation View attachment 563260
These dimensions gave meI have already written in previous messages here about this error and that it is necessary to raise these beams. The distance between the balcony galleries should ideally be 35 mm.
View attachment 563281View attachment 563282
View attachment 563283View attachment 563284
