- Dec 23, 2024
Hi Folks,
I have a couple of questions for you as I am stuck. I started this wonderful hobby a year ago and built OcCre Polaris as my introduction model. I made a few mistakes but with your help I corrected them and completed the build to my satisfaction, it was traditional in that its plank on frame then a second very thin plank on top of the first. Nothing new for you guys. I didn’t experience any issues with the second planking and it came out well. I didn’t follow Occres instructions as they show them using a contact adhesive which is applied to both surfaces then put together where it sticks instantly, no second chances it has to be right first time. I used the white glue ( Speed bond its called ). It worked and the result was good. My new model has a different shaped hull and has different curves along its length. Using the white glue which needs several hours to set, I find on trying to stick the very first second plank that the plank does not want to mould to the shape of the hull, it projects from the hull. My first question is how do I get the second plank to mould to the hull ? Do I use cyano glue which is relatively quick to set and try holding the plank in place while it sets. Or do I soak the plank in water first before trying to stick it in place. I placed several pieces of the first planking in water and that made the first plank very malleable and I was able to mould them through a couple of different hull shapes.
Also, does glue have a shelf life ? I unfortunately have to build my models in my garage which this time of the year ( Northern hemisphere ) is cold probably 5 degrees C. I have a heater going while I am there but does the cold affect the glue’s ability to stick ?
