Ronnie's First Rodeo - Billing Boats African Queen Build Log
Sydney, Australia
Hi SOS,
Merry Christmas!
I hope all of you are well and enjoying the Christmas and New Year festivities with your loved ones. :)
Welcome to my build log for my first ever model boat build: the Billing Boats African Queen 1:12 kit. I aim to document my progress here. As this is my first time dabbling in the world of boats, please excuse my lack of knowledge when it comes to maritime terms.
This will also be a bit ambitious, but I will be powering this boat with a live steam plant from MSM, an Australian company specialising in model steam plants for boats. If anyone's interested, I went with their #4038 plant.
First off, can I just say that the included instructions leave a lot to be desired... At first I thought it was just me being new to this, but after reading about other builds of this kit online, I'm not alone. And that's somewhat comforting!
As with previous projects I've built, like headphone amps, I studied the instructions and labelled each part using a pencil.
The first part I made was the wooden boat holder, where I used a metal ruler to measure the required lengths of wood before cutting it with a rotary tool. I admittedly didn't cut it too straight, and had to sand it flat, but it turned out pretty good! I used Tarzan's Grip super glue to hold the pieces together.
I then turned my attention to the ABS hull, trimming the vertical lip off the top using the rotary tool. I still need to sand this to clean it up, but it's good enough for now.
Next up, I measured where the front-most "wall" (?) is meant to be from the very front of the hull and marked that on the hull. This gave me a reference point for all the wooden "ribs", allowing me to measure and mark them up. To cut out the notches for the ribs, I used a hobby knife which worked a treat.
This is where I left off today, having glued each rib to the length of wood. The next step is to glue the lengths of wood to the hull.
It's slowly coming together! :)
Hi SOS,
Merry Christmas!
Good luck! It is interesting to see a plastic hull and wooden parts. Take your time!
Rob
I only get to work on my AQ kit when we are away from our Brooklyn apartment and in our Kingston area country house, so I’m into my third year on this build. I strongly suggest that you go to the Billings internet site where there is a photo build of the kit by an expert modeler you can access that is on the AQ page. A key is to leave the kerf (selvage?) on the tip of the hull until the deck is fastened to it later in the build. The printed instructions do not guide you on this point and I am at the point where I am about to put down the deck with much less to support it because I removed the kerf as a first step in following what a supplemental instruction page appeared to require. I still cannot figure out how the deck is basically flat but the bulkhead that attaches to underneath is rounded on top. Any builders have help here?
Hi SOS,
I'm back with an update on my African Queen. Since my last post, I've glued the side supports to the side of the ABS hull, and started assembling the wooden ribs that support the floor/decking. I started up the front, gluing that largest main piece to the hull while the rest will go in a little later. The back isn't glued yet, just used as a guide while the glue sets.
It's amazing how much firmer the hull feels now that it has some support in place. Starting to feel more and more like a boat. :)
I've started gluing the rest of the wooden supports to the hull. About half way there, just two more to go.
However, I did notice that if I use too much of the Tarzan's Grip glue, it seems to deform the ABS slightly when I use too much of it... Luckily I spotted that on the first two wooden supports as shown below, ultimately preventing it from happening on the rest. The hull doesn't seem weakened or compromised, just warped slightly. I think using too much glue gives off too much heat, which wraps the ABS.
For anyone planning to use this glue, just be wary of using too much on thin ABS!
