NHI Kolibri N-3, scale 1:48, scratch build Completed
I sort of hijacked @Loracs blog on this topic, but I'll contaminate my own blog from now on to elaborate a bit on 3D-modeling and the free 3D-modelling software FreeCad, which I'm currently using to generate a 3D-model of the Kolibrie.
For various reasons I want to have a 3D-model of the Kolibrie, the main one being that I consider building a second model of this helicopter. Another reason is that I'm trying to create a more consistent dataset, instead of having snippets of vaguely related data, like the scans I made back in 2024.
This is where it gets really tricky; the information I'm using to build mtpy 3D-model is exactly the same data I'm now using to build a model from and which I find lacking in usability. Creating a more reliable model from unreliable data, yeah right, you gotta be kidding me.
The main data/dimensions I'm using haven't changed, so there's an awful lot of guestimating going on, at best it will be my interpretation of this helicopter (or at it's worst a nice caricature of said helicopter...).
A very nasty surprise were the scans of the partly dimensioned main geometry drawings of the helicopter. The ratios of the scans in X- and Y-directions are not the same, so I had to check known dimensions in both directions to ensure correct scaling.
I'm not sure where this error originates from, is it in the scanned originals, or is it the scan software of the cellphone, or is there another phenomenon I'm not aware of?
Another issue I encountered was that the models I generated in 2024 in full scale, which I thought usable for any scale, were essentially not scalable. I'm still trying to figure out why not and I have some ideas, but I need a little more experimentation before drawing conclusions.
Also, the FreeCad software frequently crashes and, while there is a restore function, more often than not I end up with corrupt models, taking endless hours to repair.
The best way to split up the helicopter provides me with a nice challenge; I have to consider preliminary build sequence and manufacturing techniques, which dictate the way I have to set up the structure of the models. Since I'm building a scale model, it does not necessarily has the same structure as for its full size namesake.
Below a picture of where I'm currently at, it's slightly more advanced than what I showed in Loracs' blog, lack of progress is mainly due to lack of progress, caused by system crashes and frequent backtracking to correct modelling errors.
It's easy to establish that the free version of Autodesk with its limitation of ten models is not working for me. By the time I'll have the 3D-definition completed, I expect to have 50+ models and that's a conservative figure.
Note to anyone using 3D modelling software: you can't hit the save-button often enough (spoken from own experiences).
When I first got my 3d printer in 2019, I found DesignSpark from RS-Online. I used it to create quite a few models before moving to OpenSCAD, which is open source and totally free. DesignSpark has a free version with no size or quantity limitations. The page I linked shows the differences between versions. If you can live without mirroring and STL reverse engineering, it may very well suit you. I don't remember it crashing often.
Now, I love OpenSCAD, however, unless you have a computer programming background, I wouldn't recommend it for you. Rather than visually creating a model by sketching, extruding, etc., a model is defined in a programming language and appears visually in a workspace as you write the code. Yeah, I know, seems odd and totally counter-intuitive, and at first, I couldn't imagine how you could possibly do that. Once I got the hang of it, however, I fell in love. Again, unless you like writing code, try DesignSpark instead. :D
Great subject Johan, I use TurboCAD software in my little mapping business and there is nothing more frustrating than battling software crashes, freeze ups, or all the sudden the program just shuts down after a 2-hour design session, and you haven't saved any of your work. I have read many other comments from users of various CAD software apps, and these types of problems seem too common across the board. I do wonder if users of really high-end CAD software have to deal with the same types of problems.
Sounds a bit like the old CADDS5 software, which also required writing code in Basic. Editing was a freaking nightmare though: one had to go back to the first line of the feature to be edited and take it from there, you couldn't go scrolling up and down the spec tree. That would definitely lead to a corrupted model.
Like I mentioned before, professionally I used Dassault Systémes CATIA, lastly version 5. Even with this high-end tool we frequently had issues, although I'm not altogether sure it was always related to CATIA, or that maybe part of the blame fell to either Unix or Windows.
I can't recall whether or not we had an autosave function, native to CATIA, but regular saves are essential.
I will chime in and say Creo (ProEngineer) 3D CAD software is very stable. A crash is a rare occurrence that usually only happens with large assemblies. And even then it’s rare. I use it daily, and I probably average 2 crashes per year. It is similar to Solidworks, which is another great software for mechanical and structural Engineering.
That said, I think your computer is very important and should have a high end graphics card with a lot of RAM. 3D is like gaming and it uses a lot of memory. And your processing speed is very important as well. So bottom line, doing 3D CAD on a low end computer would be a recipe for frustration. I am not implying you are, but you want to make sure your computer can handle the minimum requirements for the software you are using. Hope I’m not being rhetorical, as I know you have CAD experience professionally. ;)
True statements you made about software stability and hardware. I'm using Apple hardware, meaning I am limited in my options for 3D-modeling software. Professional software is beyond reach as well, mainly because of their price tags. Autodesk for instance has a monthly US$85 subscription fee for their Fusion software. For my purposes FreeCad offers the best program, meaning I'll have to live with less stability, but hopefully I'll find one day the reason for the issues I'm experiencing.
Dear Johan. I am incapable of making any worthwhile contribution your build log. The subject matter of your build is as much beyond me as using a PC and software to build a model. However, there are things that I greatly admire: your sentiments for choosing the subject, your undeterred determination to build the most accurate model that you can and the perseverance that you have shown in this build. For that I commend you!
Thanks so much for taking the time to look through my build log of this helicopter. I know it's not your forte, so I do appreciate your response and your compliment.
Admittedly, this build is quite a bit of a struggle, due to sparse accurate information, but also due to the fact I have to sort out every single detail on my own; there's no @Peter Voogt, @Dean62 or @Heinrich (just to name three and no offense to others) to learn from.
One of the challenges I face is to simplify very complex systems and break those down to bare bones minimum to be able to build it in scale 1:24. That also impIies I have to understand how all these systems work, quite a nice bonus and quite a feat for my grey matter.
I get you. To me the simplification process from something mechanically complex to a relatively simple rendition, would be an almost insurmountable challenge, but then you have always relished the need for creativity that goes with challenges like these. I have full faith in you that you will master this complex area of the build and create something that does not only have a visual WOW component, but also the strong emotional ties which makes this project so special.
As mentioned before, I am spending quite a few hours in trying to get a more or less realistic1:24 3D-model.
I also hinted earlier that that's easier said than done. Now, a few weeks in the process, I can confidently say that the learning curve is steep, very steep. Moving away from the high-end, professional modeling software to the freeware modeling software remains a huge step. Actions, like projecting 3D elements to sketches, or vice versa became a tedious job. That doesn't mean the freeware is inferior or not good, it's just written differently and one simply cannot expect the same capabilities with freeware.
Still, FreeCad is a very competent piece of software.
Also my starting points are not particularly unambiguous; the few drawings I have were already scanned and sized down from A0 to A4 and scanned again, resulting in al kinds of unwanted deformations and distortions. To make matters worse, the 3 view drawings I use are from three different drawings or even a brochure, meaning the three views don't necessarily agree with one another. The side view shows the least deformation/distortion, leading to the assumption that this view is the most reliable one.
The above reinforces my view on recreating history, based on historical documents, drawings, sketches, etc, namely that what I recreate is not and cannot be historical correct, but merely an expression of my interpretation of the available data.
Still, the emerging 3D-model somewhat start to resemble the Kolibrie and more, I enjoy the results.
The first picture shows the side view, with the 3D-model in front of a scan of an original drawing. As can be seen my 3D-model closely matches the scanned and resized drawing.
The next picture shows the top view, taken from a brochure. It's rather evident that there are quite some deviations, especially the windshield frame differs significantly.
Then there is the front view. The scan is heavily distorted and even manipulations of the original didn't yield a trustworthy picture:Foto 20-01-2026 om 20.50.png
The picture below shows the current status of the model, with the spec tree. That spec tree grows like crazy and I haven't even started modeling the complex parts. Yet.
And finally two 3D views of the helicopter model. Still a lot of details need to be added, but, once home, my main focus will be on actual building again and 3D-modeling will have to take the back burner.
Be aware, FreeCad is a very competent piece of software.
Also my starting points are not particularly unambiguous; the few drawings I have were already scanned and sized down from A0 to A4 and scanned again, resulting in al kinds of unwanted deformations and distortions. To make matters worse, the 3 view drawings I use are from three of different drawings or even a brochure, meaning the three views don't necessarily agree with one another. This led to the assumption that the side view I have is the most reliable one, just because it showed the least deformation/distortion.
The above also reinforces my view on recreating history, based on historical documents, drawings, sketches, etc, namely that what I recreate is not and cannot be historical correct, but merely an expression of my interpretation of the available data.
The next picture shows the top view, taken from a brochure. It's rather evident that there are some deviation, especially the windshield frame appears to be off.
Then there is the front view. The scan is heavily distorted and even manipulations of the original didn't yield a trustworthy picture:View attachment 571756
In appearance, you have a convincing 3D representation of your model. I would say you have a strong knowledge base with Free CAD to come as far as you have. I know with my TurboCAD, every so often I will pick some complex part off the internet such as an engine governor or U-joint PDF that has dimensions and draw it up in 3D just to keep up my drawing skills.
You made a good point, Dan; keeping your 3D-modeling routine up-to-date is essential to stay current. There are many options, hidden in the software, allowing various approaches for modeling specific details. For instance there are various methods creating a solid feature. Developing your own preferred method is quite helpful in getting up to speed.
