For CA glues, You will most commonly find Zap glues and also glues from Bob Smith Industries.Most of us use a PVA glue (including myself). I like Titebond.
Sometimes people (including myself) use CA.
Some use the UV curing glues and others like the basic white glues.
Some love epoxy.
Part of it depends on what you are gluing and what it's going to be used for.
LOL I never hit reply to post this...
Thank you for the info. Been modeling plastic sailing ships from the beginning of time. It would be difficult to build a wood model in an apartment in Brooklyn NY. So at 88 years old I decided to try a wood sailing ship. My plastic ships were all highly detailed as to the rigging etc.Here are my own glue recommendations:
All wooden parts are glued using various brands of PVA wood glue. For non-wood components, I primarily use CA glue (see photo). The reasoning is fairly straightforward: different tasks require different adhesives, each with its own holding strength, viscosity, and working time. Below is the list of glues I use most often and where they work best.
PVA / Wood Glues
CA (Cyanoacrylate) Glues
- Lineco Neutral pH Adhesive
Very thin; dries fast and clean without clogging. Excess glue is best removed before it fully cures, as it leaves a transparent film. Recommended for the finishing planking layer. Light handling is possible after about 1 hour of drying time.- Titebond I, II, III
Excellent strength with a slower drying time, allowing for longer assembly and adjustment. Ideal for structural components such as bulkheads and framing. Full cure in approximately 24 hours.- Elmer’s Wood Glue Max
Ideal for the first layer of planking and tight joints; also well suited for framing. Bonds extremely strong. Contains real wood fibers, which helps with staining. Dries fast and clean.- Moment Stolyar Super PVA
An excellent all-purpose wood glue brought to me from Russia. Dries fast and clean and produces a strong bond.- Ponal (found mostly in Europe), I use it occasionally because it is hard to obtain in the USA.
- M5T
My go-to CA. Extremely thin—almost water-like. Penetrates joints and holes easily, bonds very strongly, and cures in seconds. Importantly, it does not clog as it dries. Best used for photo-etched parts. Note: glued parts cannot be blackened, and wood bonded with CA will not accept stain.- M1100G
Essentially, the thicker-viscosity sibling to M5T. Equally reliable, just suited to applications where gap control is needed.- ZAP CA
Needs little introduction and is widely used among modelers worldwide. This version is very thin and fast-curing, but the bond strength is moderate, and it can leave white residue as it dries.- Rapid Fuse CA
I use this as a utility glue. It has a thick viscosity and is useful for temporary joints, as parts can be separated without damage if needed.![]()
I am building my models in an apartment in Brooklyn, NYThank you for the info. Been modeling plastic sailing ships from the beginning of time. It would be difficult to build a wood model in an apartment in Brooklyn NY. So at 88 years old I decided to try a wood sailing ship. My plastic ships were all highly detailed as to the rigging etc.
Good time for modeling today with at least 8 inches of snow in Brooklyn so far today. To both you and Clipper, have fun, stay safe.I am building my models in an apartment in Brooklyn, NY
Only...4 rooms... lucky you!The Brooklyn apartment was only 4 rooms![]()
4 rooms! Luxury! We used to dream of living in 4 rooms. All 20 of us lived in a septic tank, but we were happy.Only...4 rooms... lucky you!
