This is the wall that has the cannon port directly behind it. As you can see it's not something that can be removed. You can even see daylight through the port.
Oh my days... from this view it's pretty clear that the bulkwark or the gunport (or both) is in a wrong position. That's quite a deal instead... . From E2 pics it seams the first gunport from bow is well under the foredeck. E2 shows something similar to a bulkwark leaning out the port beneath the quarterdeck, so... is this the bow or the stern of the model?This is the wall that has the cannon port directly behind it. As you can see it's not something that can be removed. You can even see daylight through the port.
I watched the videos... that's definitively a kit fault.Oh my days... from this view it's pretty clear that the bulkwark or the gunport (or both) is in a wrong position. That's quite a deal instead... . From E2 pics it seams the first gunport from bow is well under the foredeck. E2 shows something similar to a bulkwark leaning out the port beneath the quarterdeck, so... is this the bow or the stern of the model?
I've started planking my Beagle but something is not right. The fore and aft gun ports are in inaccessible places with the aft ports having a wall directly behind them. Do I cover them with planking or leave as is?
The point is that quarterdeck bulkhead couldn't be there at time the ship was designed. Totally agree on dummy gunport solution, but I can't guess why Occre suggests to cut it off the gunwale.Is this right or has Occre screwed up?
Seems to be the case.
If it was a framed ship, the futtock would stop just short of the lower sill that makes up the lower part of the port so what you have is not unusual. Consider frames were nearly a solid wall so most ports would be blocked by a couple frames as yours is blocked by a bulkhead. The instructions should have shown this so you could cut an opening in the bulkhead if not cutting off the top portion altogether before assembling. A closed port seems like a logical solution at this point.
SnapAnatomy Of The Ship: Hms Beagle Survey Ship Extraordinary [PDF] [2v56b5i44mb0]
Anatomy Of The Ship: Hms Beagle Survey Ship Extraordinary [PDF] [2v56b5i44mb0]. HMS Beagle was a Cherokee-class 10-gun brig-sloop of the Royal Navy, one of more than 100 ships of this class. The vesse...vdoc.pub
Yep, I'm finding that too, especially that there are no written instructions, just pictures to follow that are often in the wrong order. For example, the planking of the stern is particularly confusing as the pictures show this...Throughout my Beagle build, I found the instructions either useless, contradictory, or confusing, depending on which stage I was at.
