To all you French members and Vexillology historians. Flag conundrum?
Newcastle, NSW, Australia
Hi All and particularly members from France and vexillogists (And might I say, vexillology...what a great word).
My dilemma is I have almost completed the Arcne 1680 1780 long boat (again) and am at the point of putting on the finishing touches. I wanted to use historically accurate flags and to my surprise it appears that French military flags of this ere are totally white...nothing on the at all...no adornment or colour...
Now I have weathered my sails using tea and have cut a flag from material shown below...No really happy with the look. If I go with white I’m leaning toward dousing it with tea to give it a weathered effect. However, would the French admiralty of the day have frowned on having a tarnished flag on one of their vessels? To tea or not to tea, that is a question?
Another option which would be more attractive would be to use a flag with a bit of colour to it but still historically fitting in for the period and the vessel. There is the option based on the following but how likely would the king be on my humble longboat?
Historical Context
White Ensign: The primary flag used by the Royal French Navy was a plain white ensign, which became the standard for French naval vessels from the 17th century until the French Revolution. This flag was often displayed with golden fleurs-de-lis, representing the royal authority of the King of France.
Variations: The white ensign was sometimes modified to include the royal arms or other symbols, particularly when the King or a member of the royal family was aboard a ship. The flag indicated the presence of the monarch and was a mark of royal favor.
Another possibility is to call it a merchant vessel and use other forms of French flags of the era. At least they have colour and interest. But would a small merchant longboat likely to have been armed with small (expensive) cannons?
Look forward to your comments.
Cheers Rick
Whether plain white or with fleur de lis or other colors, if you are interested in having the flag hand naturally you might want to soak the flag in matte medium and let it hang with a little weight like a spring clamp until it dries. Alternatively, silk span makes a good looking flag that can be made to drape naturally using matte medium as well.
This is a repeat, but in case you had not seen it before it explains better than words.
Thanks for the info Alan and Winter. My flag (if I use it at all) was hang on the boat with a paper clip and is by no means the finished article. It was only posted to show how implausible and contrasting the white is against the weathered look of the sails. That said, the advice you have both given is valuable and I will be experimenting with these techniques.
Good morning from central standard time!
A couple of thoughts. First, how white is white? You may have done this, but you might try looking at period paintings to see how the ensign looked. You may even find some where you can compare the ensign's color with the sails.
Second, I think that most cloth flags are too thick to accurately represent the flag at scale articularly when compared to the sails. The cloth, from what I've seen will simply not behave as if it were a scale size and an appropriate weight. You might try paper which is much thinner :p than cloth, you can get a crisp print of the images on the flag and can be made to permanently take on the form desired. An example:IMG_20230223_220121.jpg
Good luck!
Blessings. Peace. Gratitude.
Chuck
Second, I think that most cloth flags are too thick to accurately represent the flag at scale articularly when compared to the sails. The cloth, from what I've seen will simply not behave as if it were a scale size and an appropriate weight. You might try paper which is much thinner :p than cloth, you can get a crisp print of the images on the flag and can be made to permanently take on the form desired. An example:View attachment 576638
Good luck!
Chuck
Good morning Chuck and a thousand thanks.
You have made me increase the size of the flat spot in the middle of my forehead. Of course...this was the place to look and a quick scan of images show tea coloured sails and crisp white ensigns. In several pictures they also show white ensign at the stern with pennants of blue and red which will add a bit of contrasting colour to an otherwise drab sort of look if things were all white. As for material I'm going to experiment with a cloth and paper. I have used tissue paper in the past to reasonable effect but it tends to be a bit translusent when stiffened with clearcoat type finishing material.
And also thanks to Jim Daniels for the short direct answer. "use the white version do not try to weather it… Yup will do...
Cheers
Rick
