MEERMIN Dutch wijdschip 1/44
  • Thread starter Thread starter Iterum
  • Watchers Watchers 7
Ah, clear.
In my scale (1/77) it hardly mattered where to perforate, but in your case I would choose the lower line to put my knife. Remnants of the torn off top will sufficiently fill the gap. The dek will camouflage all the gaps in the end.
Ah, clear.
Thank you very much - I was able to lay my Hand on the last two sheets of beige/tan 160g paper in my Copyshop :cool:
When unable to build due to destoying more than progressing - I try to do a bit of research.
On the VdV- picture (ink on paper) of the Wijdschip we can clearly notify a small boat in the deck - we are lucky to get presented a top view:
It looks a bit bend like a "banana-keel" ;-)
So I tryed to figure out where I have seen such a boat - and in the second row of books with plans I digged out "The Ships of Abel Tasman" Uitgeverij Verloren, Hilversum) with a Set of printed plans in 1/75 scale:
and in there for the JACHT HEERMSKERCK Info und the boats/launches in a seperate sheet in 1/75 in two types:
figuring out the smallest boat is a 10 oar lanch - much too big for the small coaster!
The other book is by Werner Jäger
"Die niederländische Jacht im 17.Jahrhundets" Verlag für Regionalgeschichte, Bielefeld, 2001
I found this redrawing of another well known VdV- drawing:
Here I found an other very nice pice of art - a complete Jacht, also very nice but with a much too big breadth again.
Can I resized the Abel Tasman boat by a bit more than 50% so it is becoming a reasonable
a)
two thweat/men
b)
four oar boat
of realistic size (without a banana-keel)?
Asks Chris
Everything prepared by the night-shift:
Bulkhead N° 9 and bulkhead N°13 were taken away by the carpet-monster - so I had to find the copies and restarted...
So this will be bond untill after breakfast, hopefully... Speechless
How often do you change the blade
Hello Titanic,
really a funny question you ask - as I bought my blages at Temu when I got aware of how many I do change during a build. Let's say: "Very often!" ;)
I usulay do only my fine cutting with the scalpell blade N°11 only - after this I use a cutterknife following the given slot...
...hopefully. The cutter's knifes "muzzels" do very often have a nasty tollerance. So I do use metall ones pressing the muzzels in my metallic vice gently untill it holds the blade sliding.
One scalpell N°11 blade is dull after two to three bulkheads fine cuts in my MEERMIN. I do collect them,
bent off the dull tip in my vice and have by this got again a sharp blade again - this makes the computing difficult (and ist my reasonable point for the laughing Smily above).
But the cutter's blade is also used as a "falling blade" on the straight parts in it's hole length by setting it in the prescratched groove and using a hammer to cut the slots very percise. Most use is made for the bulkheads' slots in spine and for the spine's slot into the bulkheads. So the cutter blade isn't only in use at it's tip but I would say one is good for three or four bulkheads at maximum.
Hopefully this gives you an idea of my polution of earth by dulling blades.
... just a bit of progress today concentrated at bulkhead N°12a ;)
And as allways when you have set the missing part of the drawing togeather from other offcuts, the missing drawing is miracously appering from nowhere...
Polish_20260215_161111721.jpgand the carpet-monster snatched one of your parts ready to run into phase two (slots) this time it is certainly bulkhead N°13 that did it,'s transformation into an invisible pice of paper and card!
EDIT:
First time half of the spine and half thickness of the bulkheads are married in test fit...
...and further bulkheads we're cut out and got their slot for the spine - I am too tired to deal with the curved deck's slot.
So best wishes from Berlin Card Yard!
Hello friends,
here today's results on the bow section in my typical toddlers' steps. Her the second Break of the Blade for Fürther undull cutting of (mainly straight ) lines using the scalpell three times. So eleven of nineteen bulkheads are in propper progress - coming from Stern and stemmtowards the main frame.
I think about taking the bulkheads to the copyshop, xeroxing then three times - one for doubling the bulkheads to fit into his 3mm slot in the spine; then the lay my hand onto two further doublicates that will be needed below the deck's curves to thicken the bulkheads' side space for a better bond of the glue towards the cardboard cladding - that will become the fundament of the planking.
So not too much today - but the bow is becoming the recognizable shape of a Wijdschip...
Hardening by superglue will be done when all the four layers are bond togeather and can be sanded to the needed beavel.
Any suggestions from.the expierienced readers?
I would suggest to take a sturdy Stanley knife for cutting such thick cardboard. Scalpels are for the miniature jobs. I would also prefer to cut the parts from 1 mm thick cardboard and glue the layers together to get the right thickness.
But of course its all up to you...
By the way, of course you can simply build the sloops you show for less rowers to be used om the wijdship's boat.
Hello friends
for the first time, all the frames (half the thickness) are mounted on the Centerboard (which will also be doubled). So she's taking shape!
Tomorrow I'm going to the copy shop and all the original frames will be copied three times so I can double them and then have the needed material to spread the glueing area below the deck, ensuring the initial "planking" has enough surface area for gluing.
The deck, inserted by both half-decks, will then ensure the frames are perfectly square.
I'm sure I'll find a practical solution for the remaining space between the frames. Do you think this is needed die to the spaces between the bulkheads to up to 35mm or 1-1/2" at midships:
Greetings from the Berlin Card Yard!
Today I copied the bulkheads several times to be safe in my work on the doubling of the bulkheads and adding further glueing space below the deck. By arranging the cutouts on the Xerox I was able to get all my copies in a single DIN A3 plus a single DIN A4 sheet:
The first batch is cut out and ready to be glued on 1,5mm bookbinder's cardboard again.
The copy isn't bent - it does look like ;)
Dear Ab,
the Stanley knifes I bought are a bit whobbly, are not really suited for the fine cutting I do need - the scalpell is my weapon of choice. I will Look in the DIYshop for a better Stanley for the cheaper cutter Blades.
Thanks!
Hello friends,
doubling the centerboard is in it's way by the glue still bonding under pressure:
Gosseryglases filled mit wather and a stonesquare giving wight...
...the last bulkheads do becomes their curved slots for the bent deck and an "M" for distinguishing them from the LAMANTIJN 's bulkheads (the pile without letter is the very rest to be done).
The Stanley knife is too wobbly without a first cut with the scalpell to guide as a "rail''.Here all the bulkheads and the spine in one picture:
And the deck's two lower halfs with the Note of "Bulkheads 3mms" - so I have to draw a third line three millimeters towards stem and stern.
@Ab Hoving Is it okay to perforate the bow of the deck to the upper part by cutting in the second layer for ca. 50% of it's thickness? or by cutting into both? I am unshure how much pressure the bulkwalk will bring onto the "lost part" above the deck. It would be a pitty to Lösung the hole work by too much perforation.
EDIT:
All the slots are drawn for the 3mms bulkheads by using a pair of compasses...
I was able to cut the outer line
and made shure the lines of the deck's pices are allways 30mm from the centerline's middle:
Greetings from Berlin Card Yard!
Today the deck's underlayer are cut out - the copies were a bit bent by my enlargement of 192% for the Wijdschip:
And here my "big build hangar" I am still satisfying half of the kitchen:
That's from the Berlin Card Yard for now.
Today most progress was made at LAMANTIJN, but this evening Inwas able to deal with MEERMIN 's centerboard doubling:
and scratching the WLs into the back side:
