Bolton Triple Expansion Engine “The End Test”
United Kingdom
A short intro into this model of the triple expansion engine’s history,
Hello everyone.. first post Thumbsup
It was started in 1983 by Mr Mick Cook. Mick was a Toolmaker by trade and also a keen very talented model engineer from an early age. He has produced many many incredible builds over the years, from clocks to Traction engines to loco’s even a steam powered hydroplane all scratch built. He was the chief model maker at the Ford motor company Basildon plant for the retirement gifts, things like, working lathes in bottles to many different job related models! great job if you are a keen model maker !
I was fortunate to be Micks apprentice, And that’s something that stood me in good stead for the rest of my own engineering career.
Mick is now 91 years old and unfortunately has lost his sight and has had to give up his workshop activities.. very sad to see him giving away his lifetime collection of tools and equipment. And so this is how i came to be tasked with the ‘Apprentice end test’..!
One day while visiting him he said “I want you to have this” and uncovered the triple..!
As you can imagine I was a little surprised also also excited.. then came the BUT.. You have to finish it in the same way as it was started…!! So let me explaine…
Micks ethos regarding model making is simple to say but not so easy to undertake.
‘Detail’ when do you stop? - when you can’t see it. (That does not mean if it’s hidden it means when it’s so small you physically can’t see it! :-))
‘Making things look right’ - make it as the real thing would be manufactured not the simple route.
Thanks Mick…
So my workshop is well equipped I’m retired now and been a luthier for many years, and I build bespoke vinyl turntables tone arms. Platters and plinths all for those those black plastic discs that make the best music ever ! Being a youngster of 65, my imperial days are in the distant past. Fortunately DRO,s do both haha !
It’s taken me a few weeks to get back into the rhythm, but parts are starting to come off and they seem to fit okay.. purchasing silver soldering equipment and various materials to do this job has taken some time, but things are falling into place there to, so I would like to share the journey and also keep a log for Mick my Mentor !
Cheers
‘The apprentice’
Karl
So the first job was to sort through the parts and items given to me in a big box and tins. Drawings supplied are the revised version by J.P. Bertiant, (wow how anyone has ever made this engine using these dwg’s without extensive experience is quite amazing) No datum’s no tolerances and endless chain dims. And a few to many mistakes. But heyho all in the challenge. I have the complete ME walk through from the period which is quite detailed and the new book that’s just been published by E&J Winter for the Bolton No 9 triple expansion engine. This book is again a walk through but differs a little from the original build, im not following some of this books details as i think it deters from the spirit of ME. (Personal opinion)
So having collated materials tools etc. Time to get cracking Thumbsup
Looking at the build i decided to make the parts to get the engine in a running state. Mick had made all the valve gear but not assembled the IP valve. So i striped it back made a few mods. And basic timing set, the engine turned over by hand but with some tight spots. (Remember this had not move in nearly 40 years.
So having reasonable confidence that nothing major was wrong. I looked at the the first job the reverse gear.
One of the first things Mick said was “please don’t make the forward/reverse wheel ad per drawing!” Which is to roll a rim from 1/8 and then a boss with spokes inserted.. make it solid as it was..! Yes Mick.
So there’s the start point…
Mr Cook was pleased with the first step…
Next up was to make the rest of the FWD/REV link assembly. My intention is to make and fit all the new parts then final finish them on the build.
Link arms roughed out ready for silver soldering…
Drag Links made and then assembled.
Weighshaft operating lever and link arm (which i may remake in steel not happy with the top boss alignment when assembled)
Crank roughed out but not finished
Assembled i used M2 grub screws for ease of assembly and testing operation on the HP cylinder. These are all pinned on final assembly but i may change to keyed as the 1/16 pins do look oversize just a little, we will see..
All worked as it should.
During the fit i had to remove the condenser to machine a flat face for the brackets that hold the worm shaft. As i removed the end cap of the condenser I noticed that there had been a small home built…!??
Clearly someone thought this is a nice secure place to build a house!
Next up strip down and clean, paint the base and make some of the ancillaries that are attached to the engine while paint is curing etc..
I made a Bolton triple about 10 years ago using the OB Bolton and Bertinat plans, and yes it was difficult. Looking at your photos I can see that Mr Cook and you are doing a beautiful job. Mine was just my third model engine and I did not have a metal working background. But it works on steam and regularly features in local shows, working. I wonder if you have seen the book pictured. It was published a year or 2 ago and is obtainable from EJ Winter, Bathurst, Australia and it is VERY good. I just wish that it had been available when I was making my triple.P1010074.JPGIMG_6173.jpgprop.jpg
Hi John, thanks… yes I’ve seen your engine as you can imagine taking on this half ‘cooked’ pun intended i needed to do some research.
I have that book.. its just been updated last year 2nd edition. There is good info but also as i said somethings in my opinion are not in the the sprit of ME like using EDM to make parts..? when he clearly has the talent and machinery to manufacture them.
i may be asking you some questions in the near future.. what are your consulting rates ?;)
Next job was to strip the engine down remove the crankshaft and main bearings clean the base casting up, drill some holes to fix the base later to a plinth. Also machine a small amount of clearance for the LP valve eccentrics as they are very close to the casting.
Mick has made a stunning job of the crankshaft and main bearings.Thumbsup
Main Bearings are all stamped in pairs but I wired them together just in case.
After a good degrease and hot soapy wash some heat resistant etch primer was applied.
Then after a couple of days the first coat of again heat resistant dark maroon, the actual engine castings will be a light cream and machined surfaces left as gun metal, steel etc.
Next job while the paint cures properly ill look at the Edward’s air/water pump assembly, looking at the drawings there’s is a lot of room for error.. again this part lacks dimensions there are again no datum’s so I’ve decided to work backwards and make the pump fit it to the engine then make the linkages to fit. There is a casting that’s in two halved that acts as the pivot point. These castings are not great ,but do give a way to make the pump shafts to be square. There are three shafts in all and they must run true for the air and water pumps to work.
Some pics of my boiler, in response to a request from Kanders.
It is 6" diameter, and propane gas powered, has a hand pump, and a Southworth steam driven pump.
It is tested to 200psi static and 120psi steam pressure, and certified to 100psi.
My triple will run quite well on 25psi, but at that pressure I doubt that cylinders 2 and 3 are contributing much.
Edward’s air and water pumps, wow this does take some thought Dwg’s are again not great. As I said I’m going to make the pump so that it fits to the engine first.
After cleaning up the castings and making a few special boring bars. I made a start, Cleaning up the main datum faces to size square and parallel was key.
So I machined the two side faces on the mill then transferred to the lathe and 4 jaw. Then I bored the body out to take the cylinder and the cavity. Next the cylinder bored for the piston then machined to size.
Drawing has the piston screwed onto the shaft. I decided to make a press fit and the silver solder a ring on the underside.
Next made the valve plates and made sure the disc of the valve was just held in position with the plate able to slide to open the valve, all this has to be quite accurate so lapped faces etc required.
Next over to the mill and dividing head for the bolt holes.. big errors on the dwg here but actually plenty of room to get all the holes in. I put a dowel hole at the rear for the cylinder to body
Then the gland nut made, I reduced the sizes for this as looked out of scale per dwg.
Pump shaft needs to be smooth and reasonably free to move. Once the packing is in it will need to be run in a little. Next job add some port holes. I’m not going to drill water pump mounting holes until they are made.
Thank you Karl for letting me know where to look for the answer to my question.
It’s awesome, well done
Decided not to just have a bent copper pipe from the condenser, so spent the day making flanges with 10BA bolts nuts and washers. Bending the copper to make the elbow was done by annealing the copper and filing with fine sand, I made a 1/4” half moon in a piece of Ali and bent it round, advantage of this is the pipe stays nice and round..
Next silver solder the flanges and make some gaskets.
Quite pleased with the look.
Thanks Mick…
Cheers
‘The apprentice’
Karl
Hi Karl
I started the same engine three years ago. To discover someone else doing the same thing is very
encouraging. I shall follow along with interest. I like the hand wheel, hard to tell, is it steel or aluminium?
best regards
Geffo
I made a Bolton triple about 10 years ago using the OB Bolton and Bertinat plans, and yes it was difficult. Looking at your photos I can see that Mr Cook and you are doing a beautiful job. Mine was just my third model engine and I did not have a metal working background. But it works on steam and regularly features in local shows, working. I wonder if you have seen the book pictured. It was published a year or 2 ago and is obtainable from EJ Winter, Bathurst, Australia and it is VERY good. I just wish that it had been available when I was making my triple.View attachment 583211View attachment 583212View attachment 583213
Hi john
Saw your post years ago which inspired me to buy the engine from reeves in the uk. Just ordered the book
Best regards
Geffo
Hi Karl
Like the scaled down gland nut. All the pipe work around the condenser side looks really out of scale.PM research
do some cast fittings for pipe work which would really reduce the pipe work bends.
Really like the colour choice for the bed plate
regards
Geffo
Piping from the LP cylinder should be quite large to handle the high specific volume of the below atmospheric pressure steam. Bends allow less pressure drop than elbows.
Roger
So the engine is now stripped down so I can fine fit and finish all the components. Thought id share this shot as you don’t see how many parts there are in a lot of builds, this is still not everything but id say about 98%..
The main body had a few markers and dings from the last 40 years so pistons out and clean up. Also a chance to lap the valve slides.
Didn’t take much to bring these back to new..
First coat of light cream on the structure castings, matched with the Maroon base looks right posh !!
Crankshaft cleaned as were the main bearings and a little fine tuning the crank runs very smoothly
Added some lubrication cups that will either be fed by a small lubrication pump i have or manually, as Pipework could be a little cumbersome?? A decision for another day atm.
I’ve set the valve eccentric’s, the drawing is next to useless for this, and the new book actually doesn’t help as the author has gone and changed all the valve timings.. which is not so bad in you are starting the build but not much help if you are past that stage. Plus he doesn’t give you all the info. ( if you get this book you must read it completely before starting any part of the build as he changes a lot of things. and there is not enough information to do what he’s suggesting. in most cases if you have some experience you can work it out, but just make sure you read the book through !!)
According to the drawing the top of the eccentric has to be .270 thou above the crank shaft. It shows a method which seems very complicated. I simply used a DTI, a height gauge and a surface plate with the crank in position. Plus fine tuning is possible once the engine is being assembled.
I’ve made the decision to put the water pump valves under the engine when its on its base, ill have a clear front face of it base so the detail can be seen, my intention is to have the railings and stairway up to the top of the engine. Well that’s the plan at the moment
P.S.
Thanks to all who have viewed and thumbs up’t
Cheers..
Progress on the engine over the last few weeks has been clearing and fine fitting, the glands all now packed with graphite packing. The forward / reverse gear linkage now works as per the drawing in that it goes through 360 degrees continuously through Fwd and Rev.
I had to make a special retaining nut for the link next to the arm as the gap is not big enough to follow the sizes on the drawing, I noticed that others have done the same thing.
The gland nuts on the connecting rods also need to be opened up as they restricted movement once tightened with packing and backed off once they were made slightly larger the engine now turns over smoothly by hand using the flywheel.
As a side note… I found some nice aluminium scaled checker plate (see pic above) on a RC car website this will make a great base, cut into plates and fixed should look very nice!
Next up I’ve started on the pipe work and drain down valves,
Having looked at making the drain valve I didn’t like the ones on the drawing and making 6 off of very tiny taper valves also didn’t appeal i have purchased some that i can modify to suit this engine. I may also follow the “new book” method of mounting them on the rear via a linkage…
Pipework so far i have made a start on the steam pipe from IP to LP cylinders using flanges for a little extra detail rather than just bent copper.
Waiting for valves to arrive once they are fitted I should be able to test run on air.
BTW…. I took the engine down to see Mr Cook… He was most pleased with the apprentices progress
