Yup, It's fun to make rope. Seeing it when it turns out of the machine, the whole learning curve. Perfect rope will look like the real thing. It will bring your model to a higher level.Have fun doing great rope!
Even if you have to go to ropes of scale for the larger diameters you should see savings on the overall cordage expense. Plus the satisfaction of doing it yourself.After spending a fair bit of time with this machine, I think it’s important to also talk about the big positives, because there are some genuinely strong advantages here.
First up — footprint.
This rope maker takes up very little bench space. For anyone working in a small workshop or on a crowded modelling bench, that alone is a huge win. It’s compact, tidy, and easy to move or store when not in use. Compared to traditional rope walkers that can take over half a room, this thing is incredibly space-efficient.
Second — rope quality (within its sweet spot).
When used for what it’s designed for — fine rope — the results are excellent. Clean lay, consistent twist, and very uniform diameter. For thin running rigging, detail work, and smaller scale builds, the quality is right up there.
But there is another practical consideration that doesn’t get talked about much — the bobbins.
If you go down this path, you’re not just buying a rope maker… you’re buying into a bobbin system.
To use it properly, you’ll need to wind your own bobbins, and realistically that means having access to a sewing machine. Hand-winding just isn’t practical if you want even tension and decent capacity. It’s not difficult, but it is another piece of equipment you need to factor in.
So before anyone jumps in, it’s worth knowing:
• You’ll need time to prepare bobbins
• You’ll likely need a sewing machine to do it properly
• Bobbin capacity becomes a limitation on thicker rope
• But for fine rope, it works extremely well
For me, this machine still has a place in the workshop. Its compact size alone makes it very attractive, and for thinner lines it produces excellent, repeatable results.
It’s just a matter of matching the tool to the job.
If your focus is fine rigging and you’re short on space, this rope maker makes a lot of sense.
If you need heavy, long runs of thick rope — you’ll want to look elsewhere.
Every tool has a purpose.
Every build teaches you something.
Thanks Steef66.Yup, It's fun to make rope. Seeing it when it turns out of the machine, the whole learning curve. Perfect rope will look like the real thing. It will bring your model to a higher level.
And keep the right turning direction in mind like Kuba said.
I wouldn’t say I gave up on the PL4. It’s just not suitable for me. The bobbins are to limiting for what I want to do. I tried again making 1.5 and above rope and they don’t look as good as the thinner ropes and the bobbins don’t hold enough line to make the thicker ropes.you are determined. i was surprised to see you give up on the pl model so quickly. it seemed like the ultimate rope walk.
im still stuck looking for threads. i went to hobby lobby but their wide selection just doesnt have what im looking for in the colors i want. ive got the same problem at michaels (they bought out joann's) and the threads they have are limited as well. i just hate mail order but it seems the only alternative. for now, im goint to finish my clipper with what ive got.
Looks perfect to me.Even 4 strand rope is positie on this machine. You only need a core thread.
This is a result one of my buyers send me with Mara 150. 4 strands with a core of mara 150.
View attachment 582774View attachment 582775
I purchased that very unit. It was useless. I returned it. When I returned the winder the store told me that they had many return for a refund for the same reason:Problem solved. Twenty-five bucks from Amazon. Works just fine. https://www.amazon.com/Simplicity-Sidewinder-Portable-Bobbin-Winder/dp/B004AGX2HI?th=1
