- Aug 27, 2025
Thank you for the help.838.75 Hard to understand the words from where they are measuring. 60 feet is shown on line A that I have added. Overall length is 838.75 inches. (Line B) This is assuming the overall print is not stretched or shrunk or otherwise degraded. I inserted the print into CAD and took it full scale using the rule under the keel.
Hope this helps. Do you know the source of this drawing? It may be easier to get clearer information if you know who holds the original.
This makes sense because this cutter has a lot in comin with HMS Alert which was about 90ft. But maybe that's just because there both British cutters.My guess for the source is a plate in:
NAVAL ARCHITECTURE 1787 2ND ED 2 VOLUMES
STALKARTT,MARMADUKE
It may or may not be the plan of an actual vessel.
I do not think that either A or B would match the 60 ft description.
The thicker lowest black line at the wale. Where it hits the thick black line at the wing transom aft and the aft edge of the stem rabbet. A perpendicular line at each point AP aft FP fore. Use that for the 60 ft.
My bad for causing confusion. Neither line that I drew was meant to match the description, I was just showing you the actual dimensions at those points as examples. The drawing is full size, 1 to 1 scale, and dimensions/lines I show are actual at those points.I do not think that either A or B would match the 60 ft description.
Great point Roger, thanks. The plan matches the legend, 25' 4"On the other hand, the word Beam is well defined. It refers to the vessel’s maximum breadth, easily measured on your drawing. If I am reading the small sized drawing correctly the extreme breadth is also listed there.
