HMS Enterprise 1774 POF 1:48.
A repeat but, I do love the Armstrong Frederick pattern guns which would be appropriate for Enterprise, 1774 instead of the generic cannon we usually see.
How are you rounding the axles on the carriages? Have you made and tried a cutter like in https://shipsofscale.com/sosforums/threads/tricks-of-the-trade.15492/
Hi Allan. I have just done a skim in the lathe however I still need to finish off by hand. My cheap lathe doesn’t hold the wood 100% centre so some hand sanding to get them round still needs to be done. Well mostly roundROTF.
Cheers Grant
If you have a small piece of brass or aluminum, or steel rod, just drill a hole the size of the axle that you want. Cross cut with a hack saw or hobby back saw to creae a couple teeth. Cut the ends of the axles to the right size, square or octagon as you wish, then hold the axle piece in a vice and chuck the cutter in any small drill press or even a hand drill and cut the axle. It takes a fraction of a second and does a clean job, It will save you a lot of time and grief. If you were closer I'd pop one in the mail for you. Whatever works, go for it.
I have four or five cutters of various diameters that will last life times.
View attachment 584791View attachment 584792
Thanks Allan. This very cool. I have seen you post this before however I am very tool limited. I will give it a go and see if I can drill a hole dead center into brass/metal rod...... ROTF. Worth a try though as it will save me plenty of time trying to hand sand these. Cheers Grant
You mentioned you have a lathe. If it is a metal turning lather, easy peasy. If not, drill and vice will work, but slow and steady. You only need to go in a quarter inch or so. Or, if there is a shop nearby or someone you know with a lathe, maybe have them make a half dozen with different diameters for future use. Wish I was closer to make some and send to you. Even US Postal basic (read that as very slow) service is $20 or more.
Good morning everyone
I have changed the kit cannon carriages so I have a more representative version of the real thing.
I have added some axle bolts and through bolts and moved the tackle ring bolts. The eye bolts are as the kit. I also included a hinge bolt on the cap squares. I just used a nail on the front bolt however may change this on the others.
On some of these I left a tiny protrusion to represent a bolt.
@AllanKP69 My hand sanded axletrees are not spot on so I will attempt to make your jig. Thanks for the assistance.
Cheers Grant
View attachment 585204View attachment 585205View attachment 585206View attachment 585207
Cheers Grant
Very nice
Cheers Grant
A very nice outcome of the carriage and canon, Grant. It will definitely look good on your model. You will add some representative blocks and ropes?
Based on the number of "likes" on the post showing photos of the cutters, I am guessing a lot of members had missed the tricks of the trade subject. There are a lot of tips from a number of members that others should find useful, or at least interesting.
Very nice
Thank you Gilbert. Congratulations to your team for winning the 6 nations last weekend. Close call tho :D
Thank you kindly Peter. I am very please with how it came out. Unfortunately, as it is not my favourite job, I will be doing the full rigging for the cannons.
Thanks Allan. It is always good to pick up ideas etc from the other guys.
Well played, Grant!
A very nice change to the canon carriage's Grant.
Thank you Paul and Daniel. I’m pretty happy with this look- I think it will go very nicely with the look I want to achieve.
Cheers Grant
Cheers Grant
In the end, the most important thing is that you are satisfied with your own work; when it matches your vision and brings you that quiet sense of “yes, this is right.”
Agreed, we are doing this for ourselves after all, even if we post our build. ;)
Good morning Jim and Dean. True story. I’m at the stage in my shipbuilding career ROTF where I am building something representative vs going for a 100% replica. Maybe one day I will attempt this however right now my knowledge and skills are limited so “if it looks like a 18th century ships cannon it must be an 18th century ships cannon”ROTF.
So far I’m very chuffed with how my Enterprise is going and the fact that the Admiral says on regular occasions - “stop building ships and go make some money” says everything ROTF.
Cheers Grant
