. As I have said before - stunning design work. Cheers Grant10 more to go?The stern Scottish thistle and crown are done.
That's it for this row of decorations except for the gunport decorations.
Well Vic, if you don't have patience you don't get the results you want.…..I can’t wait for the prints…. Sorry Kurt I don’t have your patience
THe taffrail and counter are next, then the column decorations. (what are they called again?)10 more to go?
Column decorations, maybe?THe taffrail and counter are next, then the column decorations. (what are they called again?)
Columns, definitely. At the moment I started working on some of the other decorative elements that surround the icons, starting with the carvings around the central figure of King Charles I. Here is how that one is coming along. The gallery around King Charles below this is next, and that gallery may be merged with the figure of the King to make one large central assembly.Column decorations, maybe?
I noticed that also. It was easily fixed. Another minor issue is that the painting is not completely symmetrical, so theye may be some issues fitting the objects into the panel rectangles on the model, and adjustments to scale and shape in the 3-D objects will occasionally need to be made and repriinted on the resin printer.Hi Kurt,
Fantastic results. One remark is there an option to slightly angle some of the emblemes at the corners of the stern. Your emblemes are now squared where they apear angled following thelines of the sides and friezes.
Vs
This would benefit the aestetics greatly.
1) Yes, the stern will not be flat, but will be curved, based on the Jacob Kniffe's painting below.Hi Kurt,
I was looking at the truly fantastic work you've done on the stern decorations, and noticed that Maarten asked you to put them at an angle. I don't think that this is the solution. The decorations look angled because they are lying on a curved surface. That stern is curved is shown on the Knyff painting that I showed and discussed in my posts. This brings up two questions:
(1) Are you going to make the surface of your stern curved?
(2) If not (and, here, I show my complete ignorance of 3D printing), and if you're going to make the decorations flat so they will fit on a flat surface, will it be possible for me to alter the STL files you produce to make them curved?
Blame it on the cat.Work is slow as I try to gather and modify assets to make the columns (called brackets) between the decorations.
I have the two central brackets on the counter almost done.
All this 3-D work is getting tiresome after two years. So, I pulled the model out from under cat-shield v2.0 to repair some damage. Two loose cannon barrels were locked down and the beakhead had broken off and so it was glued back only the stem, this time with brass pins to reinforce it. The seam was touched up with paint and the repair is practically invisible.
I noticed the rearmost portion of the upper gun deck has a bit of a twist compared to the forecastle areas. The area will be buried inside the stern castle, so I'm not too concerned.
Repairs complete. Back to Blender 3-D...
I've been playing lots of Kingdom Come Deliverance 2, and yes, I think that tavern sign from Kutternberg is really funny.![]()
Yup, but that's what they appear to look like...Gravity has not been kind to your brackets.
