Chaperon Sternwheeler build log.
Isle of Anglesey
Hi all,
Not everyone’s cup of tea, but starting the Model Shipways Chaperon.
Cruising very quickly through the basic hull build as other builders have a more detailed description.
Managed to start this build from the very beginning unlike my CR lamb build
All good so far.
Next comes the four part deck sections with pre cut joins which leaves a lot to be desired.
We’ll see !!!
Deck on. Four pieces, terrible jointing idea and design but careful tweaking on the joints , sawdust mixed with glue, came out acceptable without adding a layer of decking.
Red oxide rattle can and the joints barely visible.
Main stairway made, albeit wrong orientation. The wall boarding is vertical, should be horizontal. Think I can get away with that. Eeeeek !
My mistake but I made new treads because the supplied ones were a little narrow and looked gappy so did away with them.
I found, as others, that the laser scribing on the supplied deck sheets was inconsistent so using those sheets as a 'sub deck' I planked the deck with 1/8 x 1/32 strips. This so far has worked quite well without any issues with the extra thickness as I continue my build.
My only regret so far is that I didn't purchase the CR Lamb instead of the Chaperon. (Saw your build log on the CR after I had purchased the Chaperon)
Hi all,
All good so far.
We’ll see !!!
Nice to see the start of your new build-log, Neil. Great that it is the build of a paddle steamer!
Main stairway completed and temporarily situated to make sure it all fits.
Also, the Chaperon lettering came out better than I expected.
I was dreading that bit.
Enjoying this build also.
The rub rail is proving to be a pain in the neck. The strips are too short to do in two, so a silly little section will have to be fitted somewhere.
Haven't installed the rub rail as yet and wondering if you can supply information on those long clamps you used.
Thanks,
Ron
Very well done!
This kit builds a real vessel. Chaperone was a short haul river boat. Sailing from Evansville, Indiana she serviced towns along them lower Ohio River and up smaller tributaries in neighboring Kentucky. She was active into the 1920’s and possibly the 1930’s. There are photos of her. A real riverboat.
Roger,
Hi Neil, I'm finally on this forum. Excellent build from you as always and Excellent photography as well. I'll enjoy seeing your progress. :)Thumbsup N, C & B.
Hey. Fantastic Neil.
Thanks for your time and support.
Time to post your work for everyone to enjoy.
Chat soon.
Little more done.
Checking through the carrier sheets, I noticed the N. on the small Chaperon signs did not laser.
I emailed John at Model Shipways, and he was very helpful and arranged new parts to be sent to replace them.
Faultless service, fast and considering I’m in the UK, didn’t even charge me any postage.
That’s service for you.
Highly recommend Model Shipways to anyone thinking of getting any of their kits.
Thank you.
Unfortunately, the replacement laser cut sheet was worse than my original.
Will grin and bear it and make the best of it.
Pics showing the two sheets.IMG_1118.jpegIMG_1119.jpegIMG_1121.jpegIMG_1120.jpeg
Boiler installed. Not much detail as I think as it is so hard to see when completed, a bit pointless from my point of view.
Boiler deck weighted and glued down and keeping the nice gentle concave shape.
Notice the Rob. E Lee and the Lamb in the background.
Just love these little steamers.
