Tutorial. Stropping of Served Double-Stropped Jeer Blocks. One Continuous Thread. No CA glue.
  • Thread starter Thread starter Y.T.
  • Watchers Watchers 4
Toronto, Canada
I developed a process that I would like to document here so I do not forget how I did it. It can be useful for someone too. I use Domanoff serving machine for this work. I have quite a few pictures to upload. This will be done trough many posts. Please refrain from comments till I am done with this tutorial. Below is what we are going to use.
Wrap the thread several times over the hooks. I did this 6 times. Start serving this from left end. At the start keep thread very tight to the hook. Serve up to right hook. Tie the thread with an overhead not very close to right hook. Cut of the thread from spool leaving long end.
Remove one end of strop off the hook. Using needle tie the thread through strop little hole and tie with one overhead knot. Remove strop other end off the hook and using needle tie both strop ends together finishing with one overhead knot. Now you should get a complete strop with long thread end.
Change for stronger hooks. Put both strops on the hooks. Stretch tight. Tie both strops together with one overhead knot. Make a few turns and again tie with one overhead knot. Take strops off the hooks and wrap them loosely over the triple block.
Change the hook on the left with my patented double hook block holder. Put block on the hooks as shown. Tighten the strops on the block using overhead knots and some thread turns.
Well presented tutorial YT! It brings up a question, hopefully you or another member can help. Were strops, served or not, tarred like standing rigging? I cannot find anything one way or the other. Looking at contemporary models at Preble Hall and RMG, some look to be using tarred strops, and others do not. There is no correlation with the era of the models I looked at. Like so many things maybe it depended on the boatswain on each ship so no two were the same. As well, most, if not all, of these models have been re-rigged since first built so more questioning than answ3ering if they were not rigged as on the original.
Thanks again YT, well done!
Serving and tarring the strops makes good sense. In fact strops are sort of stationary rigging as it does not go through sheaves. Serving and tarring would provide better preservation.
The blocks are 8 mm just for those who may want to ask.
My heartfelt thanks to YT for such a marvellously detailed tuturial. As a newby to model ship building this website has provided me wonderful information over the years. This tutorial is most outstanding, encompassing quality photographs rather than 1,000 words. Thank you again, cheers Richard.
I recently completed the Norskelove 1765 by Billings, I would have incorporated this tutorial exercise into my model. Next time for sure.. Although I will build the Domanoff Serving Machine / Tool out of Lego bricks and gears ( I used Lego to create my Rope Walk using my variable speed drill for the motor, it worked well as I created over 270 feet of rigging rope. From another posting I used White Paper Glue to cover the rigging ropes sparingly to eliminate thread fuzz while maintaining thread flexability.)
Thank you, Richard. I maintain same principle regarding the quality of learning materials: the picture is worth a 1000 words and sometimes a million. I am though a bit surprised that about 100 people read this thread but only 4 made decision to follow it. May be what is presented here is somehow above the capabilities of many? I do not know what is the reason.
Hallow "YT", whether 4 or more choose to acknowledge, many read it, and then wish they had made one or bought one.
I read every week this website, but rarely respond, mostly because I do find some of them are a 1,000 words are too much !! Being an electrical draughtsman for 35 plus years, quality photographs such as yours tells me everything. If I can draw an accurate drawing, I know then I can build it.
I bet you have many other wonderful model ideas, please share them, cheers Richard.
