I kept thinking for a few days that I wanted to move the crowsnest down. I even took one side of the backstay apart. Taking all the shrouds apart would have been a mess. Plus I don't have enought of Pavel's heavy dark brown rope incase the shroud lines are damaged from glue. The crowsnest in slightly over 1 inch too high. I also had thought to sand a couple small semi-circles in the wide wood rail on the crowsnest where the backstays touch. Then thought I may just make things worse. I decided to leave everything as is. I'll try to be more precise going forward.
I put the ratlines on. The kit shrouds are a very thick rope. I've seen some rigging which use the same thickness for the ratlines as the shrouds. This doesn't look good to me. And I've seen tan/almost white ratlines. Again, just doesn't look good to me. I tried .5mm rope. This looked good. I have some .45mm dark brown rope that I bought for some reason and never used. So I used this for the ratlines.
