Revell Gorch Fock II 1:350 kit conversion to Tovarishch
Belgrade, Serbia
It's time to start a topic, I think. As a relatively quick and straightforward project (in reasonable sense, of course) I decided to take a very simple and low detailed (less changes) Revell kit in 1:350 and convert it to Tovarishch (actually Tovarishch II, Ex. Gorch Fock I). I will try to take into account the differences between the original and sister ships, especially the modifications done in her Soviet and Ukrainian periods. The purpose is to show her in her late years before leaving Kherson, like on the photo below, when she was used as a training ship by Kherson State Maritime Academy. I understand that the kit is not 100% convertible, has fantasy details, and in some cases I will have to accept a compromise. But I will try to make the model recognizable in 1:350 by its specific details and hopefully get it to completion.
PS
Although I got a lot of public info and images, including a German documentary film from 1993, still there are some unclear places (the deck behind the foremast, for instance). I guess among the users of this forum there might be people who had a maritime practice on her or visited as a tourist. If you were there, I would appreciate sharing any information or probably photos of the ship - especially if you were there in 90-s. Thanks in advance for any feedback to this post, anyone is welcome!
PPS
I know about this topic - Gorch Fock I is in shipyard for restauration - "White Lady" is now rusty - thanks a lot, @Uwek! Especially for photos of the decks cleaned to the metal!
The current state of the build is as follows:
- some sanding is done to smooth out the hull lines and remove the details, specific to Gorch Fock 2
- the hull under the waterline is painted green (the paint comes with the kit) with brush
- the temporary stand is in place now
While I am working on the upper part of the hull, I am coming to a first big compromise with the kit as a base - the portholes. Of course, there are differences between Gorch Fock 2 and Tovarishch making the last one recognizable - I marked them with blue. But the portholes.... Revell's version does not correspond to either, Gorch Fock 2 or Gorch Fock 1 - sometimes closer to one, sometimes to another, sometimes is something new :D Take a look:
After reviewing this, I decided to leave the portholes with a black dot inside and make 6 new ones where you see a black circle. Others will be fixed with putty - and this is the compromise. :confused:
The extreme approaches are:
- to remove most of the portholes with putty and carefully reproduce the real porthole positions
- to paint the portholes black as it is, hoping no one will notice :D
But I am doing a plastic kit conversion, not a scratch build, to make it more recognizable. I don't want it to become an endless and not completed story of changing everything. I know there are and will be much more mistakes from Revell (we will see when it comes to the decks!) so even if the portholes were 100% accurate, the other stuff would not. Therefore I decided to minimize the changes to get it looking as much close to the prototype as possible.
An intermediate point in the process - I think I've made a mistake in the central area of the hull (red and green frame). Unfortunately, I don't have plans for my target period, only much earlier plans for Soviet era, about 70s and I have an existing plastic kit I am trying to adopt. So after checking a lot of drawings, photos of different years and at this moment, as well as applying Revell's deck to my hull, I think I came to final positions of the portholes (in the middle, v2, green):
Still working on the hull, I got quite a surprise when I realized that it is asymmetric: port side and starboard side are different!!! :D I will put it here if someone decides to follow - just to be aware:
But now I think I am ready to put all of this in place. The black lines, circles, rectangles reflect the changes I am going to apply to Revell's hull. The starboard side (7 portholes on the forecastle, ending 3 on the poop and so on):
The port side (9 on the forecastle, ending 4 on the poop, etc.) - the orange areas have scratches I occasionally made and missed:
The port side is missing an anchor, for instance. Previously, in 1930s, it was on the forecastle's deck like that:
But in modern life there is no place on the deck to put it. Why Revell left it this way, with just one anchor - I don't know. :D
Going to make a copy of the anchor on starboard side (in process).
PS
If you see a mistake - please, be so kind to let me know now - before it is implemented in plastic & putty!
Question-Mark
Probably it looked as if I've abandoned the project, but I did not! :D These portholes - so many cardboard, plastic and wooden model makers ignored the fact that starboard and port side positions are completely different. It made me pursuing the goal - to do the right positions in my case, at least for once!
A lot of time was spent on research last month, reviewing photos and videos, drawing sketches and honestly - waiting for some ordered goods to come, especially another model of her from Japan, in the same scale 1:350 - as a donor of items and a cross-checking source. Finally, after sorting my photo/video materials by periods of time. I decided to build both, similar - but very different, in early 70-s and 90-s to put together and compare. But it will be a separate story, while this one is progressing... ;)
Please, stay tuned!
Boatman - I am following with interest your build of the Gorch Fock / Tovarisch Revell kit. I know you did a lot of research on the portholes on the original vessel, but did you decide how you want to present the port holes in the plastic kit? I am building another windjammer similar (but smaller IRL) to the Gorch Fock, it is the Juan Sebastian de Elcano / Esmeralda kit from Artesiana Latina. The A/L kit comes with a ABS plastic hull like the Gorch Fock (see pictures), and I feel like leaving the port holes unpainted or unmarked would look less realistic than adding color. Also attaching a picture of the Esmeralda underway to show the coloring of the port holes seen from a distance. But do you just darken each port hole with a pencil? A Sharpie? Black paint? If you could let me know how you decide to present the ship's port holes and include pics if you have them. Thanks!
@Ignatius27 Sorry, I am also following your build and missed this post among others. Yes, surely. I will paint them black in my case.
It depends on how the portholes are looking in real life. Usually the brass is used for portholes fittings so in many kits and prototypes, especially for late XIX or beginning of the XX century you can see a brass ring around the black porthole:
But in my case at least only the black rubber is seen outside the porthole, while the brass fittings are visible only from inside:
PS
This is Gorch Fock 2, but very detailed:
PPS
On J.S. de Elcano it is similar:
So you will and I will both paint our portholes black. But how will you go about it? Sharpie? Paint brush? Charcoal pencil? I hope to find a method that is effective to show that the potholes are there, but without risk that I might screw my hull paint job if I make a mess of it.
I will paint them black using a thinnest brush I have, like in this video (video is not mine, to avoid any confusion):
A tooth-stick can also be used, if you don't have a brush.
But in your case, when the model is almost assembled, you can try to use Stabilo 0.4mm markers instead
I think it's time to start posting the updates, since there has been no report for a long time and the last few months were spent working on the build.
Thus I spent a lot of time trying to find the right porthole positions, using the ones provided by the Revell kit as a base, to minimize the amount of work but make her recognizable. I was trying to move them left or right, but it was always wrong :D But finally I noticed one thing, which gave me a clue, and I want to share it with you.
First, portholes on a steel-hulled ship can't be cut out in any place, like in the wooden hull of the XV-XIX centuries, by cutting through parts of the frames, like this:
In steel shipbuilding, portholes can only be placed between the frames. never through them, as can be seen on these photos of Gorch Fock in Stralsund:
So there is a minimum spacing, and each subsequent porthole is positioned at 1x, 2x, 3x that spacing, and so on. Then I looked at the hull again and noticed that there are 12 portholes on both sides in the middle of the hull, with the same spacing between them. The only difference between the starboard and port sides is the presence of additional portholes inserted between them:
Their positions are the same on both sides and represent the original positions, when she was launched at Blohm & Voss in 1933 and these additional portholes were added later during her long service life. By the way, note that her mizzen mast carried only two sails then:
Once I realized this, I was able to easily find the correct positions for the portholes - the ones I need to keep and the others I need to hide and come up with this final layout. The yellow line marks the bulkhead used to operate the overboard ladder:
Honestly, I was surprised by the amount of changes to convert the kit and I was even considering hiding everything and re-mark all the portholes from scratch but... There is no reliable plan for that - only photos! :D And I needed some reference points anyway, so the existing portholes from the Revell kit did the job!
From that point on, I only had to find some time to implement everything in plastic and putty. To be continued!
Said that, I've started implementing the schema above on the model.
First, I've removed all the portholes, marked red using two types of putty, AK103 hard applying it with an old bank card and Vallejo 70.401 with a thin applicator for small and precise work, giving necessary time to completely dry and then sanding with P600.
Second, I've updated the hull:
  • marked the porthole positions using the masking tape to maintain a single line
  • made two cut-outs in the middle of the starboard and port sides
  • extended the board with small pieces of plastic from sprue to round the corners later with a file:
By the way, these elements are still present on Gorch Fock in Stralsund (like you can see here), making it obviously different from Gorch Fock 1933. I guess they needed them due to the large heavy seas lifeboat installation. Just imagine: you can't release it without hitting the board otherwise!
The lifeboat was removed in her soviet period of service, but the board is forever cut out and this makes me thinking about her life and destiny. What do we have now in Stralsund? The same hull, steering wheel, many other things - so she is still living, and great thanks to all the involved enthusiastic people for that!!! But she is not the same as she was in the 30-s as Gorch Fock, neither Tovarisch of the 70-s - all her previous life was wiped out by the time and people, and in our days she became something new, but not a model of herself before...
Thinking about that I've started drilling the new portholes with a manual drill. It took several iterations with putty and drill, honestly. :D
Finally, there were two updates on the bow - the figurehead and bobstay fitting (also made from sprue):
Sorry, It took 3 days to make this post due to regular interruptions, but I need to move on (to be continued).
I am following you build for a while but have not posted till now, Alex. I do appreciate your attention to detail and the time you take for adjusting the hull.
Thank you, Peter! I wish my hands were as good as my attention to detail! :D But I want to complete my build, even if I'm not completely happy with the results.
Next step is painting the hull. Officially Revell recommends their color 05, White matt.
Looking at the hull it does not seem snow-white, but a kind of slightly yellow warm white to me, like on this photo, where the white paint, recently added to repair, contrasts with the basic color:
Definitely not that white as Gorch Fock II or J.S. de Elcano above
So I decided to try several paints I had at home and choose the right one.
And finally I decided in favor of Revell's 05 color and applied it using the Revell's brush, coming with the kit:
So I painted the hull from both inside and outside. I also restored the board a bit (with putty) in the place where I made cuts:
Honestly, I am not happy with the resulting porthole positions - but making them closer on the starboard side could be dangerous due to the initial kit positions. So, another compromise.
To be continued! :D
This post should have appeared early in July - before my vacation... But I was too busy to write it - with work and many other stuff. But now I am finally back and going to work on Tovarisch further.
I would call this post "Operation Anchor - 2026" :D
During all her years of service she was a training vessel for marine cadets. I think this is why she had only one modern anchor and a second one - an old-fashioned admiralty anchor to train its catting and fishing. Due to that, Revell's kit comes with an empty place for the port side anchor, which wasn't the case of Tovarisch. So the question was: how to duplicate the starboard anchor as if there were two from the beginning?
The modelling clay was my solution. I took the shape and baked it as described in the oven, thinking to use the sprue to fill the form.
I don't know, guys, if you ever tried, but my experience with the melted sprue (using a candle) was a total loss of time! :D
Then I came to the idea to use putty - to fill the form and when completely dry. just paint it over! I covered it with the foil, and this is the result (a tooth stick is just for size reference):
Then I had to glue it to the board, but it should be at the same level and and the same angle as on the opposite side, so using the masking tape I set it up:
This is the final result to this moment:
PS
I would say next time I will consider removing the printed anchor and make two custom copies, as it is much easier to paint and gives a better look.
This time I have to ask for your help and advice! This is what happened to my Revell's 05 White matt paint! ROTF
It hasn't dried completely, there are still some wet places, so probably it is not completely lost. Did anyone tried to dissolve this type of the paint?
First problem is that I've started using it already and I don't want to repaint the hull (probably, I would do) - because I need to fix several places around the portholes and the anchor and I don't want different shades of color to mix.
Second problem - it is an "aqua color" paint. but I tried already (maybe I did something wrong) - it does not dissolve in the water. I can wash it with 96% alcohol, but I'd like to hear your opinion first.
Finally, there is an enamel paint from Revell with the same name and number, but I haven't used this enamel yet and it is too thick for a brush (I don't use the airbrush due to home and family limitations). Is there a way to lightly dissolve it to use with a brush?
Thanks for any advice and suggestion! Beer
I've tried the new (enamel) paint. Good news - it is absolutely the same shade! Thumbsup
Bad news - it is glittering when it comes over the old "aqua-color" paint - remaining matt in other places!!! ROTF
