Looking for mesh for deck railings
Toronto Canada
I am thinking of building a boat that will have a screen mesh along its deck railings. I have lots of standard screen mesh that has square openings, but I am looking for mesh that forms a diamond-shaped pattern (see photo). I am planning to make the model about 1:32 scale, or so. Dose anyone have an idea of where I can source such a mesh? Thanks, Carl
Carl, this is my Bluebird of Chelsea model in its early stages of construction. The rail stanchions and horizontals are made of brass, and the webbing is a rubberized material over the top of a cloth mesh. The original material was dark brown in colour, but was easily painted white with a spray can.The webbing was then cut to required size and sewn on to the brass frame. The diamond shape stood on end and was cut to whatever shape was required as can be seen in the openings around the mast turnbuckles. I purchased this material at a fabric store, and have no idea what it was intended for, but it is a perfect medium for model ship building.
Jim
Look on Amazon or check out Michaels. Mesh like this is used for needlepoint. You can get different sizes.
Tob
did you try Fabricville? That is where I got mine
Jim
Beautiful job on this boat, by the way. Can you provide a close-up photo of the detail? I may want to copy this approach. Thanks.
I notice that Fabricland has this type of material. (Thanks YT, I was able to see this on their website). They also have black mesh in similar style that's used for hair netting.
I am not familiar with fabricland. Here it is called Fabricville.
Thanks Carl, this is as close as I can get for a clear shot. As mentioned above by Rob444 I had originally tried the plastic material used for needlepoint work but found it was filled with scabs from manufacturing which really showed up when painted and could not be easily cleaned out.
Uh.....if you take a square screen and rotate it 45°, it becomes a diamond....
All railing frames are made from 1/16th brass rod. They are put in place on the boat and soldered, and then removed for painting. they are then put back on, and the painted netting stitched in place. All my railings on all vessels are made and soldered on the boat. This ensures the proper angle of the railing and stanchions. I have a corning ware plate that I put between the railing and superstructure so as not to scorch or set fire to the boat. All my soldering is done with a small butane torch as I can not hold my hand steady enough for an electric gun.
