USS Constitution 1:70 Scratch
After making a few double blocks and some rope, I worked on the main and fore yard lifts. The lifts consist of a double block hooked to an eyebolt on the cap, and a single block attached to the yard. The lines haven’t been belayed to their points on deck yet, I need to make the belaying pins first.
I’ve been working on the mizzen mast for a while now. Essentially, it carries the same fittings as the main and fore masts, but with the addition of a spanker mast along with its boom and gaff. So far, I’ve installed the mizzen fighting top, the topmast, and the topmast crosstrees. The upper shrouds and all the ratlines are complete, and just like on the main and fore masts, the upper jeer blocks and sling have been rigged and secured. Once those were finished, I prepared the crossjack yard. I built it in three sections, joined them together, and added the cleats, lower jeer blocks, and other blocks. Once the footropes are completed, the cross jack will be mounted in place.
They look magnificent!!!
Hello Mustafa,
So happy to see you and some of the other MSW builders here. Without you guys for info, and example, I would be lost.
I've got you bookmarked here and of course will continue to follow along
Frank
Welcome Frank, it's great to see you here too. Will you be starting a build log?
I prepared the main topsail yard and secured it to the topmast. To keep the yard firmly in place, I inserted a pin at the center of the saddle; this pin fits into a hole in the mast and locks the yard in position. For the parrel, I used 2 mm beads. The main topsail yard tye & halliard consists of a double block attached to the yard, running through single blocks hanging on either side at the head of the top yard.
I wanted the topsail yard to be in the lowest position.
