Majestic Mary Rose build log
I've been wanting to build the Mary Rose for a long time now, the history, stories and the mystery of why it sank, but let's not go there now, as that is a big debate. This is only my fourth ship; I haven't long finished the Occre Revenge, which took three years on and off, and think the Mary Rose will be the same. I'm realising it's a bit above my skill level, but I think it's a good way to learn.
On first impressions, the kit has quality wood materials, CNC-cut sheets and the fittings look good. The instructions are a booklet with all the history of the Mary Rose and about six pages of written instructions, which are understandable with experience building model ships, but you also get eight large, detailed, drawn plans, and they do assume you have previous knowledge of building.
That's all the bulkheads, keel, frame and lower deck for the dunny cannons cut out and cleaned up, ready for assembly
BuIkeads glued in and blocks glued in, ready to hold the dummy cannons later, ready to start palnking the second deck
Came across a problem with the main deck as it won't go on in one piece due to the bulkhead positions. Without thinking or asking my peers, I cut the deck into sections, but stupidly not realsing as I was later advised, i coud have cut it in half longways.
main deck planked, you can see where I cut the deck as I have join lines, but I also made a schoolboy error, I should have laid the last plank centrally to hide the centre join line, so don't do what I did. You won't see much of the deck when its finised, so it's not too bad, but I know it's there lol.
Forecastle and poop deck also planked and stained along with the main deck. I used sapele wood stain, and i thinkit came out quite good. A bit of advice, test the upper bulwarks along with the Forecastle and poop deck before planking the decks. I found that the stern deck was slightly too long towards the bow, and the bulwarks were too short, so it might ned trimming
Main Deck fitted, and bulkheads sanded, I will have to do a bit more sanding on the bulkheads as I go on with the planking of the first hull layer.
Lining up the first plank to start the hull. I haven't got an image, but I used the main cannons when doing this, to make sure the cannon barrels had some clearance above. This is a good guide for the waist gunport later.
Went down seven planks on each side and marked out the gun ports for the dummy cannons.
I've only planked up to the deck line for now, as I need to test-fit the upper bulwarks. Both sides planked up to deck level, and dummy cannon gunports cut out.
test fit for the upper bulwarks so I can determine how high to go with the planking, the first layer.
A good sanding of the hull, but will have to do more later. Im am adding two more gunports at the back as the Mary Rose had many more cannons, and I have two spare from a previous build.
Main deck cannon gunports done.
Took a bit of a break from the ship and made up the cannons, anchor, and made my own ladders, and I thought the ladder assembly that came with the kit protruded out too much. My ladders aren't perfect, but my carpentry skills are improving.
Started work on the bulwarks, on the panels, I just used Danish wood oil on the walnut, it came out nice and dark. Beige for the outer bulwarks and yellow for the inner bulwarks.
Waste gunport glued onto hull, and cutting out the gunports.
I cut out the rear extra gunports. I can see a future problem with getting the hull planks to sit flush with the sternpost. I've sanded back as much as I can, but I will have to keep that in mind as I build.
First layer of hull planking complete and sanded, all waste gunports cut out. Now onto planking the stern with 1x4mm and 1x3mm walnut strip, then I can start plankinking the second layer of the hull with 1x4mm walnut.
I used this little handy rotary tool for the gunports; it has three speeds, it doesn't have a massive amount of torque, but it can handle small jobs and is lightweight, great for detailing, and only about ÂŁ15 from Temu. Along with bits from the Dremel cutting kit, gunports took no time. These small wood chisels are great aswell
My wood arrived from Amazon, I got some 1mm balsa because I have seen other builders add a fourth deck at the bow and stern, which is not in the instructions. I haven't really scratch-built anything before, but I will have a go.
Made a start on planking the stern, lower planks are 1x4mm and the upper planks are 1x3mm. At this point, the instructions want me to add two more gunports, i forseen a problem in cutting the ports later, as there is nothing to strengthen them behind. I had the idea of using 2x5mm strip to act as a border for the gunports, which seems to work well.
That's the stern planking finished; for some reason, they didn't supply dummy cannons for the upper gunports. I purchased some Amati bronze cannons from Cornwall Model Boats. The four dummy cannons are for the stern gunports, which are 21mm, not including the stem, but I think I may have to get 15mm for the upper gunports. I am seriously thinking of replacing all the black dummy cannons, port and starboard, with 15mm bronze, but I will see. The two cannons with carriages are decorative, 30mm bronze. These are to replace the existing painted bronze cannons that came with the kit, I still need to get two more, as they were out of stock. Along with the gunports, you can see there will be two more on the third deck, and when I add the fourth deck, there will be two more. In tota,l there will be eight cannons at the stern, I'm doing this according to Anthony Roll illustration.
A good start to planking the second layer of the hull, I pinned a temporary plank in place to get the line right. I've noticed I may have a problem at the bow when trying to get a level surface, so some very careful sanding may be needed, the 1x4mm walnut is quite soft, so it will be easy to oversand. I was going to do staggered planking, but I'm personally finding this hull awkward to plank because of the many angles, so I will have a go on another build at a later date, this build is confusing enough for me at the moment.
View attachment 579998View attachment 579999
Planking the second layer is going well, but slowly, as I had to cut out the gunports. Now that I'm past the gunports, I should speed up a bit.
Portside second layer of planking is complete. Planking went well without many problems, so hoping the starboard side goes aswell.
View attachment 582569View attachment 582570
It's been a while, I've been having a bit of a break from modelling, planking the Mary Rose felt like a mammoth task, but back on track now. I ordered the rest of the cannons from Cornwall Model Boats; some of the deck, the cannons that came with the kit needed to be painted bronze, and the dummy cannons painted black. I decided to get some proper bronze cannons for the deck and replace the dummy cannons with bronze as well, as I'm going to add a fourth deck, and I'm adding extra cannons as well. I won't be able to get the 91 guns estimated by the Mary Rose museum due to the scale of the model, but going to be as original as I can. I have seen references to the Mary Rose having five decks, but there is alot of speculation on the exact history, but it wouldn't be possible with the scale of the model, I think.
Finally, the planking of the hull is finished; it seemed to take forever, it didn't turn out as perfect as I wanted but I'm happy with the results. I tried to get straight planks from bow to stern all the way down with tapering and steelers, but I found planking this hull a challenge, lots of curves, lol. I see some models with perfect planking, I don't know how they do it; I guess it's down to experience, trial and error.
I intend to use Danish oil on the hull now that it's sanded, but I need to tidy up the decking first and restain it, paint the inner bulwarks, and paint or stain the inside frames of the gunports, as some of the first layer is showing. For the main lower dummy cannon gunports, I will probably use a 0.5mm strip to add a frame.
I did have a problem with the garboard strake, trying to get it to sit flush with the keel. I sanded back as much as I could, but I was in danger of revealing the first layer. If the keel had been thicker, I don't think it would have been a problem, maybe in hindsight i could have buit up the keel so its somthing to check in future builds.
Inner lower bulwarks and waste gunport painted, and decking cleaned up and restained, now ready to start staining the hull. Not all the inner bulwarks have been painted because I will be scratch-building a fourth deck. I will be using Danish oil on the hull, 2 to 3 coats to start, to see how it soaks in, as I want a darkish finish on the hull.
Outer hull now stained using Danish oil, a lot more detail to add to the outer hull yet, but it's come out quite well, just the finish I was looking for. Never used Danish oil before, but I will be using more oil-based stains in the future. The Danish oil has darkened the 1x4mm walnut strip and brought out the wood grain, resulting in a nice finish with just one good coating of oil. I was going to try another coat to go slightly darker, but, judging by how dark it got with one coat, I decided to leave it as is; otherwise, it might go too dark. It's just knowing when to stop sometimes, the next step is to add the rubbing strakes, five on each side of the keel.
