Statenjacht UTRECHT by DORIS - HISModel - 1/72 - new 2026 version of the kit
Hello everybody,
Allow me to introduce myself. I am a builder of large card models of historical sailing ships, especially scratchbuilds. I have been involved in model building since childhood, still enjoy it, although now I will be focusing on plastic model kits for some time.
A few years ago I finished my largest card model - scratchbuild of the Royal Katherine.
The beautiful historical painting by H. Vale also depicts the royal yacht, which had already impressed me so much during the construction of the Royal Katherine that I planned to build it in the future. I have not yet been able to find accurate and complete plans for a similar yacht, but now I have the opportunity to build a nice model of the Dutch royal yacht Utrecht. It is a plastic kit with a whole range of high-quality accessories in 1/72 scale, manufactured and offered by HiS MODEL (www.HiSModel.com).
Statenjacht Utrecht 1:72, Premium version - stavebnice lodi - HiSModel
This model appeared on the market some time ago, but now it comes with a completely redesigned decoration and a different stern in 3D printing. So I will present here a prototype model representing the yacht Utrecht in its older and much more decorated form than the original kit version, including the current replica of the yacht Utrecht.
I plan to build the model according to museum models of similar sailing ships and try to imitate natural wooden materials as faithfully as possible.
Prins Van Oranje (1764); Royal/ceremonial vessel; Royal yacht; Dutch | Royal Museums Greenwich
Please excuse my English, which is not very good, so I have to use Google translator.
Here are previews of what the model will look like with the new 3D printed decoration and stern section:
3D návrh.jpg3D návrh1.jpg3D návrh2.jpg3D návrh3.jpg3D návrh4.jpg3D návrh5.jpg
Appearances may be deceiving, but as I found out, it will not be exactly a relief considering the very detailed designed kit with a number of metal and wooden accessories for a more realistic rendering. From my point of view, this is a kit designed for more experienced modelers, it is significantly more sophisticated than plastic kits from most other manufacturers. Basically, it contains many accessories like luxury wooden kits, but plenty of parts in this kit are designed directly to measure, which will give the model more realism
I plan to create the model with minor improvements. The hull structure will require additional modifications and reinforcement of the side parts of the hull so that everything fits perfectly.
The model's castings are of high quality, the softer plastic used makes it easier to work with and shape the parts. However, it is necessary to study the instructions very carefully, drill holes in advance and make adjustments to be able to place the individual parts exactly in their places. In some cases, I had to add areas and reinforcementfor precise gluing of the parts (stern section and front bulkhead of the cabin and front section of the deck).
Here are some photos from the process:
Assembled hull - in some places I corrected the joints by putting, but otherwise everything fit nicely:
DSC_0273-změněno-na-velké.jpegDSC_0276-změněno-na-velké.jpegDSC_0279-změněno-na-velké.jpeg
Filler spraying + minor corrections and cleaning of the joints:
DSC_0281-změněno-na-velké.jpegDSC_0282-změněno-na-velké.jpegDSC_0284-změněno-na-velké.jpegDSC_0290-změněno-na-velké.jpeg
Preparation of the base for future wood imitation - will be done with oil paints:
The deck is attached to three beams in the hull and is closed by precisely designed side panels from the top side. This gives the hull an optimal thickness and the inner side has completely elaborate details. However, it was necessary to underlay the deck at the bow so that it would be slightly raised and fit tightly with the interior panels - solved by gluing plastic profiles into the hull.
This premium version of the kit also includes a wooden deck, which needs to be glued to the plastic molding with a suitable glue. I used colorless glue from Pattex for this, which took a long time to dry and it was necessary to use clamps around the perimeter of the deck, but the advantage is that there is enough time to place the deck precisely and in case of glue stains, this can be removed without any problems. I previously impregnated the wooden deck with Tamiya's colorless matte varnish (TS-80), it worked well for me on previous models.
Next up are the first 3D printed parts from the new version of the model. The stern has exceptionally beautiful decorative details, the coloring (considering their fineness and small scale) is a bit of a challenge, but even more challenging is "standing the macro photos", which reveal a lot of flaws. Well, I still have a lot to work on, although I have the basics down and I will deal with minor repairs on the model, where this part is already glued in place:
Overall view and a few pieces of decoration provisionally placed on the model:
DSC_0310.JPGDSC_0314.JPGDSC_0315.JPGDSC_0317.JPGDSC_0318-změněno-na-velké.jpegDSC_0322-změněno-na-velké.jpeg
3D printed parts are hard and fragile at the same time, so it is necessary to work with them with utmost care. Gluing the decorated stern panel into the hull was quite challenging, it is not possible to shape it to fit and for a stronger joint I had to strengthen the edges of the hull and pull them together at the top - the sides of the hull protrude slightly and here correction is also necessary for gluing the front bulkhead of the cabin. I used wooden strips, which I glued inside the cabin and created an auxiliary structure for reinforcing and shaping the hull. Once again, it turned out how an accelerator for superglues is an indispensable assistant...
I note that for this version of the Utrecht yacht I will use a different color scheme than the current replica. I am partly based on museum models and also on my own aesthetic sense, simply so that I like the model and it looks like wood. There is still a long way to go, but it is also a great challenge....
The model has already received its final color form, I used oil paints + powder weathering from Tamiya to paint the hull and imitate wood. I gilded the decoration with decorative spray paint from Motip. Most of the 3D printed decorations are already placed on the model, the most difficult part was inserting the window fillings into the fragile rear galleries - they are designed quite accurately, but since the material is very unyielding and the columns between the windows are extremely thin, you have to be very careful. I managed to break off two columns + the material tends to shatter. Here it would probably be better to use photo-etched parts considering their thickness for subsequent glazing or print the window fillings as a part of the galleries. Well, it was more difficult, but in the end it worked.
DSC_0326-změněno-na-velké.jpegDSC_0327-změněno-na-velké.jpegDSC_0332-změněno-na-velké.jpegDSC_0335-změněno-na-velké.jpegDSC_0343-změněno-na-velké.jpegDSC_0345-změněno-na-velké.jpegDSC_0346-změněno-na-velké.jpegDSC_0348.JPG
The railing on the bow also required minor adjustments and adaptation to fit without problems. Compared to the original version of the kit the new one contains also beautiful decorations and a very successful lion statue, which really worked out.
DSC_0352.JPGDSC_0357-změněno-na-velké.jpegDSC_0356-změněno-na-velké.jpegDSC_0353-změněno-na-velké.jpeg
The model is photographed with a SLR camera with a flash, so the colors are more vivid in the photos than in reality, where they have a more muted shade. The macro mode did not disappoint again, which after significantly enlarging the details again revealed flaws, so I will still have to correct and retouch what the eyes can hardly see.
Enjoy the photos and have a great time.
Doris
View attachment 605145View attachment 605148View attachment 605147View attachment 605146
Doris
Good to see your build of the Utrecht, Doris. You are doing a great painting job.
Using flashlight for taking pictures of your model is delicate. Perhaps use it ‘indirect’ via the ceiling or use natural light and the camera on a tripod for longer exposure times.
I've enjoyed, and been amazed, by your card models. I know this model will show what a "plastic" kit is capable of, and am enjoying it as well.
Doris
Superb paint work!
Doris, it is so great to see that you are active again! You had seemed to vanish so completely after the Royal Katherine, that I was concerned about your well-being.
Your Staten Yacht is coming along beautifully, and I love the salt weathering of the upper bulwarks. I look forward to your progress, and to learning new things, as is always the case when you are creating. Welcome back!
Hallo Doris
Es ist schön, das du wieder da bist. Ich habe jeden Bau deiner Kartonmodelle mit Bewunderung verfolgt. Einfach einsame Spitze Daumen hoch!!! Da hast du jetzt Neulend mit dem Plastik-Kit betreten? Wie du die Holzimitation hinbekommst, ist schon eine Augenweide. Früher hast du ja deine Skulpturen für die Ornamente selbst mit der Hand gemacht- nun bist du beim 3-D-Druck gelandet. Ausgezeichnete Arbeit. Bitte weiter so.
Karl
Hello friends,
thank you very much for your encouraging comments, I am very pleased and appreciate it a lot. I still enjoy to make ship models, but I don't have that much time anymore and I have other hobbies that bring me pleasure - mainly real cars, their renovation, detailing and driving them.
As for the Utrecht yacht model, I must admit that its 3D printed decoration is definitely the best I have ever seen in model kits. In addition, this plastic kit includes a lot of high-quality accessories that will allow you to build not only a beautiful model, but also a very realistic one. By the way, this beautifully decorated newer 2026 version of the HISModel kit is also based on the plans of the real yacht Utrecht, but from an earlier period.
As for imitating wood on plastic models, I proceed as follows:
First I spray the base with a suitable shade of Tamiya spray paint - for subsequent imitating lighter wood, I found TS 46 - light sand to be a good choice + I lightly seal the whole thing with a matte colorless varnish (TS-80), but it is not absolutely necessary.
How to achieve a perfect wood imitation?
I use a wide range of shades of oil paints - white, light yellow, light and dark ocher, brown shades and black in different proportions, I mix the lighter shades first and apply them to the model with a soft brush, where I spread the paint into the thinnest possible layer. Then I use a harder brush, with which I make longer brush strokes. Thus create a typical wood engraving. I sometimes lightly dip the tip of this brush in darker shades of oil paints and repeat the rubbing in places where I want to indicate a darker drawing on light wood. It's like playing, it's not complicated at all and the painted area can be adjusted or changed at any time during the work, oil paints dry for a longer time.
This has worked well for models with a smooth base. If there is already an imitation of wood engraving directly on the moldings, it is easier and only the color shade is solved without the need to imitate fine engraving with a brush. However, I always apply and spread only a very thin layer of oil paint. After it dries, I still make small local improvements with Tamiya powder patinas (weathering):
Best regards,
Doris
This is inspirational work.That's a very realistic wood effect that you have achieved.I look forward to seeing your model progress.
Hallo Freunde,
Vielen Dank für Ihre ermutigenden Kommentare, ich freue mich sehr darüber und weiß das sehr zu schätzen. Ich baue immer noch gerne Schiffsmodelle, habe aber nicht mehr so viel Zeit dafür und habe andere Hobbys, die mir Freude bereiten – vor allem echte Autos, deren Restaurierung, Detaillierung und das Fahren.
Was das Utrecht-Yachtmodell angeht, muss ich zugeben, dass die 3D-gedruckte Dekoration mit Abstand die beste ist, die ich je bei Modellbausätzen gesehen habe. Darüber hinaus enthält dieser Kunststoffbausatz viele hochwertige Zubehörteile, mit denen man nicht nur ein wunderschönes, sondern auch ein sehr realistisches Modell bauen kann. Übrigens basiert auch diese wunderschön dekorierte, neuere Version des HISModel-Bausatzes aus dem Jahr 2026 auf den Plänen der echten Utrecht, allerdings aus einer früheren Epoche.
Was die Imitation von Holz auf Plastikmodellen angeht, gehe ich folgendermaßen vor:
Zuerst besprühe ich die Grundfläche mit einem passenden Farbton von Tamiya-Sprühfarbe - für die spätere Imitation von hellerem Holz habe ich TS 46 - leicht angeschliffen als gute Wahl empfunden. Außerdem versiegel ich das Ganze leicht mit einem matten, farblosen Klarlack (TS-80), aber das ist nicht unbedingt notwendig.
Wie gelingt eine perfekte Holzimitation?
Ich verwende eine breite Palette an Ölfarben – Weiß, Hellgelb, Hell- und Dunkelocker, Brauntöne und Schwarz in unterschiedlichen Mischungsverhältnissen. Zuerst mische ich die helleren Töne und trage sie mit einem weichen Pinsel auf das Modell auf, wobei ich die Farbe so dünn wie möglich verteile. Anschließend verwende ich einen härteren Pinsel, mit dem ich längere Pinselstriche mache. So entsteht ein typischer Holzschnitt. Manchmal tauche ich die Spitze dieses Pinsels leicht in dunklere Ölfarben und wiederhole den Vorgang an Stellen, an denen ich eine dunklere Zeichnung auf hellem Holz andeuten möchte. Es ist wie Spielen, überhaupt nicht kompliziert, und die bemalte Fläche kann während der Arbeit jederzeit angepasst oder verändert werden, da Ölfarben länger zum Trocknen brauchen.
Dies hat sich bei Modellen mit glatter Basis bewährt. Ist bereits eine Holzgravur-Imitation direkt auf den Formteilen vorhanden, geht es einfacher, und es muss nur noch der Farbton angepasst werden, ohne dass eine feine Gravur mit dem Pinsel nachgebildet werden muss. Ich trage jedoch immer nur eine sehr dünne Schicht Ölfarbe auf und verteile sie. Nach dem Trocknen nehme ich dann noch kleine, lokale Verbesserungen mit Tamiya-Pulverpatina vor (Weathering).
Beste grüße,
Doris
Liebe Doris, als ich zum ersten Mal Deine Royal Caroline - ich denke das war vor 14. jahre gesehen hatte . War ich restlos begeistert. Damals habe ich mit dem Bau der Royal Caroline von dem Hersteller Krick begonnen. Ich habe damals Fotos von Deiner Royal Caroline ausdrucken lassen und als Vorlage für meine Fertigung genommen . Ich bewundere die Schönheit Deiner historischen Segelschiffsmodelle und Dein umfangreichsten Können. Danke Dir dafür.
Ich wünsche Dir und deinen lieben beste Gesundheit - alles Liebe und Gute - vor allem viel Freude
Beste Grüße Holger
