- Jan 9, 2020
If I may quote our friend @GrantTyler - True Story!
The last knightshead is the one of the fore mast. The original is heavy eroded but you can still see he is looking slightly up, he wears a hat and his ears are visible.
This is the outcome of mine, it is around 6,5 mm. I made him slightly older in his face by adding some additional lines.
View attachment 608977View attachment 608978View attachment 608979View attachment 608980View attachment 608981View attachment 608982
And the three sizes. The small one will still receive some additional tweaking.
Great carving, Maarten. Very special that each one has his own expression and details.Also the smallest is now a little tweaked. Look for the 10 differences
How it was.
How it is now.
View attachment 608985View attachment 608986View attachment 608987View attachment 608988
Thx Paul, guess your carving production starts soon.Brilliant! You are a rare talent!
Thx Daniel, exactly the same is nearly impossible, they all are slightly different like in the original.Amazing craftsmanship Maarten, to fashion 3 figures of different sizes that essentially look the same is talent.
Thx Peter, it was nice to fiddle around with the details and change the expressions.Great carving, Maarten. Very special that each one has his own expression and details.
The smallest is 4,8 mm, 6,5 mm and the big one 9 mmThere are two possibilities:
It does not matter. The head is looking fantastic
- You have giant fingers
- The head is really small
Thx Grant, but I had a fingerprint transplantBrilliant Maarten. Some o the carving lines are smaller than your finger print. 3D printing couldn't do better- Kudos. Cheers Grant
Thx Herman.Superb carving Maarten, hats off.
ThxÚžasná práca.
A nice nailing of the deck planks, Maarten. With a nice size contrast with the nails in the beams. And the corner connections of the coming are fitted ‘spot on’.The deck is now finished and nails are added to every beam and carling.
These decks were just nailed, no treenail.
You can also see this on Vasa.
For my deck I used 0.3 mm anealed wire.
View attachment 613702View attachment 613703View attachment 613704
The next step is the hatch coamings.
You see different varieties but I selected again the ones of Vasa for this deck, a solid profile layed on top of the deck planks.
View attachment 613706View attachment 613707
The profile size is 5x6 Amsterdam duim for the main coaming and 4x5 Amsterdam duim for the fwd coaming.
View attachment 613708View attachment 613709View attachment 613710
Next the fwd coaming and the covers.
Indeed, nice work.And the corner connections of the coming are fitted ‘spot on’.
My planning is to put a layer of shellac on the deck, sand it with steelwool and then tip the nails with some ballistol.Are these nails in time going to change in colour?
The size is 0.35 mm which is +/- 1/2 Amsterdam duim and comparable to the square iron nails we had in the flooring of our 15th century house here in Zutphen. One of the nails we found during restauration work I still have in a small frame.Very nice, Maarten. Perfect scale on the nails!
Love that!One of the nails we found during restauration work I still have in a small frame.
