Pelican scale 1/45 a small English galleon 16th century
Oost Vlaanderen Belgie
The start of this model was sometime in 2016.
After building Billing's Vasa, I wanted to make a scratch model. The choice fell on the Golden Hind; the intention was to make a perfect copy. Little did I know then that this would turn out to be an impossible task. The name of the build log soon changed to "Pelican".
If I were to do it over, it would be without the cabin under the poop deck and without the balustrade at the stern.
These are many photos that need to be sorted through and resized. And given that the original text has disappeared in the MSW crash, it will take a while to rebuild everything.
The finished model in 2022
Some drawings of what the ship might have looked like.
Initially, the idea was to use the Aeropiccolo plans.
Which were later adapted to a narrower version, with the guns below deck.
Start of the keel laying.
The wood used for the keel, planking, and decks is ramin. This has a fine grain, but as will become apparent later, it is sometimes difficult to bend.
Construction of the keel, bow, and stern. Plywood holds the structure together.
And the whole assembly is mounted on the construction board.
The frames.
Mathew Baker's drawing served as the basis.
The spacing between the frames was also adjusted.
New spacers had to be sawn for this adjustment.
The spacers are glued to the keel piece, but the frames aredry fit.
The "rough" shape is there.
The frames have been sawn out internally and are being glued to the keel piece. At that time, I didn't have a laser yet, just a straight metal strip.
The keel piece with the glued frames.
The cannon deck.
First, a deck was laid as a base using just long, thick planks. Partly as a base, partly as practice (this was my very first deck ever)
Then a layout of this deck was made.
The forward frame was hollowed out so that the deck runs all the way through.
And the final deck with hatches
and a first cannon port exercise
Next steps
Reinforcing the tops of the plywood frames
After that, filler blocks. If you are inexperienced and have no idea if your frames are correct, then this is a handy method.
Filled neatly on the port side and then sanded carefully. This is hours of work
For the starboard side, less patience and having become a bit bolder. The vertical sander an big blocks, this is a few minutes work.
And after filling and fine sanding, quite okay.
And then a comment came from a more experienced builder.
Your transom is going to sit much too low below the waterline. On a real ship, this will affect the operation of the rudder. In hindsight, that was correct. And thanks to the thick filler blocks, this mistake could be sanded out without any problem.
The line of the hull is now also smoother at the stern.
Couple things that are really odd. This one may not matter in the least to you, but just in case, there are belaying pins on the drawings. The English did not use belaying pins until the second half of the 18th century.
Very well observed, thanks. And indeed very correct.
Later, much later, you will see that no belaying pins will be used on this model.
