Captain John smith's Shallop by Sevish
Hello everyone
I'm back on the table with a new small relaxation short project before my next big project build.
The Shallop of cap. John smith
So without further ado.
The start of the build with the first cradled and laying the keel.
The kit: no unboxing-forgot to take pictures
The cradle:
Later with the next update : the ribs
Cheers
Guy
It's coming along.
And the ribs are Super fragile.
And my test on painting the blocks to look more woody.
The blocks were changed feom wooden ones to 3d printed ones :
And last question ,
Dose anyone know how those blocks called?
I consider to change the blocks but couldn't find any considerable replacement for that block.
Cheers
Guy
Enjoy the build - it's a very nice kit, but with some (very few actually) tricky corners...
Cheers,
Frank
Good morning all,
The lay of the ribs has been finished, yay,.
This kit is super gentle and need extra carful when working on it and lots of adjustments on the cradle.
And the final result after extraction from the cradle.
Enjoy and have a great weekend of relaxation
Next update : the planking
Cheers
Guy
It's updated day,hooray!
After a week or so of planking and sanding i completed the main part of the boat's hull construction.
IMG_3763.jpegIMG_3789.jpegIMG_3831.jpegIMG_3839.jpegIMG_3894.jpegIMG_3923.jpegIMG_3924.jpeg
For the hull finish I decided to divert from Pavel Nikitin method of painting
I did used first his patina , but after Sanding the hull i used teak oil as finish and not diluted patina.
I love the result, i think it's looking better that way.
Next update: the benches
Cheers and great weekend all
So with the finished hull of the boat I continued with the boat decks,benches,and the rudder.
For the fore deck I did it from new oarts that i made to match the curvatures of the hull,the steam moved about 3mm forward while planking.
The original part in Comparison to my part
From here I continued with the branches and the railings
The installation of the rudder didn't turned out to the best as ir should be ,Partially my fult and partially the lack of proper parts in the kit to make hinges correctly.
From the kit part folding marks on the PE parts of the hinges will be much helpful and more important the addition of the correct tube for the pins to slide in, Any way this is the result, I think It will be less noticeable when the whole boat is completed.
Eventually it's a model for my self so I less judgmental about that.
Next update: the Leeboards system
Cheers
Guy
Nice going Guy.i love the authentic finish you are achieving. Cheers Grant
Hi Grant thank you for your words.
I tried to use Pavel's painting technique, but i messed up with it and achieved this great finish, and i also thinks it looks really authentic.the secret is to use paintbrush instead of airbrush to apply the patina.
Cheers
Guy
Another day another update
That was quick and hard and tedious but mission accomplished,The leeboards has been installed.
The boards themselves are not a problem easy peasy.
And the raw pully system
And for the hardest part to make the chain and attach everything together.
And both sides attached
Next update: The oars and stuff
Cheers
Guy
Amazing how the week flew by.
And the oars and stuff are ready.
For now only the oars and barrel are mounted.
The axe
The boat hooks
The lantern
The oars
And everything together
And the final result for now
The rest will be attached in the end of the build.
Next update: mast and yard
Cheers
Looking great. I'm amazed that you had the patience to do that little chain. I tried, a lot and then chucked it in the bin and just used a piece of rope. There was no way my giant fingers could control those tiny links.
Thank you, i was sooooo close to throw it away and do it also with other more easy technique.
