Sovereign of the Seas Airfix (1:168) by Michael D.
The current status of my S.O.T.S. I'm working to finish up the sheets for the spritsail, but I needed to mockup the anchors to check for minimal interference when it's time rig them.
I've included a photo link of her from the beginning, along with my other builds. Thanks for the much-appreciated welcome into the forum.
Michael D.
Sovereign of the Seas- Airfix:
Vasa-Airfix:
Reale de France- Heller:
Victory of 1765- Heller:
Just spent way too long poring over your google photo albums, time well spent I feel, I do need to ask though, how do you get such amazing wood tones on the hull and how do you finish the exquisite gold detailing?
Loving these albums mate.
Thanks for the kind words, Buster. For the wood tones, I'll try to simplify, the first illustration shows styrene sanded with 120 grit and based with my go too Tamaya desert yellow, the middle one thinned down a bit. The next image shows all three toned with the same acrylic burnt umber thinned too various levels to give different effects.
The last image I included one using raw umber on the left, and all are finished up with a black wash, the only other color I use sparingly as a highlight is acrylic yellow ochre. I know there's a myriad of other methods out there that work just as well, but this has always worked for me. I use 24 carat gold leaf, after brushing off most of the leaf I use a toothpick and an exacto blade to achieve a clean edge, I do not seal it, hope this helps Mate. Cheers.
Michael D.
Michael D.
Most excellent, thanks for taking the time and trouble to do this for us all.
Greatly appreciated.
Michael D.
Good day Michael!
Im glad to see You and your amazing works here!
Thank You very much for sharing with us your very effective woodening technique!
Very usefull information specially when we could see these impressive results!
All the best!!!
Thank you Kirill, hopefully it will be of some use to someone, it's great to hear from you as always.
Work continues on the anchors, for the bands on the wood stock I used tape with a little CA to help secure them.
The clinch for the anchor cable is a little tricky to do but turned out okay. Cheers.
Michael D.
About 50 percent complete on the portside anchors, the aft anchor is pretty much set, and I'm still undecided on which timberhead to tie off the shank painter, although where it's at temporarily could work.
Still have the anchor buoy, cat block and falls, fish pendant tackle ETC left to do, oh my!!!!. Cheers.
Working on the cat blocks and falls. the following pictures show the evolution of the cat blocks using 3mm double blocks and styrene, I've also included the thimbles for the cat back ropes, these along with the pendant guys will be fun to rig. Cheers20260516_092540.jpg
Michael D.
The rigging of the port anchors are completed along with the fish pendant and spritsail sheet pendant, for these I used .20mm line. The spritsail pendant is led through a thimble spliced to the tricing line and has a 2mm single block stropped at its end, the sheets are 60wt thread made fast to a ring bolt and led through the block and sheave and belayed to a cavel block.
The long block for the fish pendant is made from 2.5mm and 2mm single blocks and the tackle is 60wt thread with a 2mm hook block to an eye bolt on the channel. Thanks for taking the time to stop by and checking out my progress, cheers everyone.
Michael D.
I was finally able to complete the starboard anchors and rigging, fish pendant and tackle, anchor buoy, cat back ropes etc. along with the sprit sail sheet. up next I'll complete the belaying of the buntlines at the forecastle rail.
Michael D.
Michael D.
Vasa-Airfix:
View attachment 599658View attachment 599659View attachment 599662
I am extremely impressed with your planking detail on the hull sides. The kit hull is very bereft of planking. How did you do this?
Thank you for your interest. I used Tamaya tape centered between the Wales, using a #11 blade I lightly scribed both sides of the tape, after a few passes I used the backside of the blade to create some width.
Repeated the process for the remaining planks, light pressure is the key.
The grain is created using the backside of the blade, 120 grit sandpaper and a scotchbrite pad to smooth the surface.
Michael D
