Oseberg 1/32nd from Pavel Nikitin - With hopefully also many added details.
Daniel.
I also spent weeks trying to find the book. It needs to be directly pre-ordered from Pen & sword -- they receive books directly from
the museum - NO other sources ------
or -- you could just order that one directly from Amazon ROTFROTFROTFROTFROTF
Cheers,
Hi mates,
An update - thanks for your continued interest in this log. Made some comments within some of the images
Regards,
PS: I also posted a preview of the next build coming up after the Oseberg. if interested its here;
2.jpeg3.jpeg4.jpeg5.jpeg6.jpeg7.jpeg8.jpeg9.jpeg10.jpeg10b.jpeg11.jpeg13.jpeg14.jpeg15.jpeg16.jpeg17.jpeg19.jpeg20.jpeg21.jpeg
Hi mates,
Regards,
View attachment 624345View attachment 624346View attachment 624347View attachment 624348View attachment 624349View attachment 624350View attachment 624351View attachment 624352View attachment 624353View attachment 624354View attachment 624355View attachment 624356View attachment 624357View attachment 624358View attachment 624359View attachment 624360View attachment 624361View attachment 624362View attachment 624363
Classic John work- every fine detail added. Excellent work. Cheers Grant
Grant thanks....as always
I am having lot's of fun with this Oseberg -- ESPECIALLY Pavel's kit.... well, it is certainly an easier build by comparison to so many other much later ships.
and, the more I read and study about Vikings' skills and thoughts on how they built these 2000 years ago --- I bow in respect....
Regards,
Hi Mates,
Continuing work - she’s getting there. Adding ballast --- this may be a point of contention…
As we all know she was a burial ship. That said the Oseberg did sail local waters for some time before she became sacrificial. She sailed in coastal waters and fjords for about 14 years before being used as a royal burial.
Because it had a low, light hull, experts considered it unsuited for rough open ocean voyages, unlike deeper-hulled cargo or war ships. That said the Oseberg likely used stone ballast in its central area near the mast when actively sailed. I could not find a reference for ballast in V. Bischoff’s text (out of context for her book) except, of course for the approximately 180 tons of rocks placed on top - before its burial….
From Google AI: Archaeologists suggest the heavy pile of stones was used to anchor or crush the ship inside the burial mound, or symbolically act as a "reverse ballast" to help weigh the sacred vessel down for its downward journey to the Norse underworld
In deference to Oseberg --- I should have actually made a housing mid-ship also including two skeletons along with all of the items found as well. Including that beautiful cart. obviously Last image..
But, moving on - next up working on deck boards…
As always thank SO much for your continuing interest with this log….
Cheers,
1.jpeg2.jpeg3.png3b.jpeg5.jpeg6.jpeg7.jpeg8.jpeg8b.jpeg10.jpeg11.jpeg12.jpeg13.jpeg2308264 copy.webp2333409.jpg
Hi John... for some reason I'm surprised these boards were nailed down???
Paul,
Thanks for the question - a good one..... You are indeed correct deck boards were not nailed to the deck. Treenails were used for many of the deck boards. Though, per my understanding most near mast center boards were not treenailed so as to allow for easy lifting - allowing access for placing cargo below.
Last image --- getting ready for the 1000's of nails - on lte list after deck boards
Regards,
IMG_7651 copy.jpegweb_hent_bilde (1) copy.jpegweb_hent_bilde (7) copy.jpegIMG_1462.jpegweb_hent_bilde (16) copy.jpegIMG_1592.jpeg
Hi Mates,
Started work for deck board treenails. Here are some images...
I know that is seems as though this log is always in a "holding pattern", but, slowly it is moving forward. I follow other logs that can build entire ships
within the time it takes me a few weeks just to add a few details :mad:;)
Next up will be the center deck separate piece boards - last image some of which will be removed so as to allow views of ballast, and barrels.
Then, onto the sooooo many outer hull nails and cleats.
AGAIN so appreciate your continued interest.....
Regards,
