Sea of Galilee boat - SE Miller Creates - 1:12
Nunnelly,Tennessee
I debated on doing a build log for this build, mainly because there are several very informative logs here from the past. But just to bring it back so others can decide to enjoy this build. It will be my third time. The first two were 16” and this one is 26”. The first week was just building the strong back.
I learned to covers the frames with packing tape so the planks don’t stick to as bad.
Scott pre-bends the keel and attaches it to the stern. Also pre-bends the cap rails which are not shown in the material below.
Strongback completed, ready for the keel.
Keel is set and the two first planks are just notched in the frames so I can check the shape of the hull.
The bow stem is next but I’ll be busy on other things for the next week.
Bow stem installed this morning. I’ve been using PVA but the kit suggests using CA. I’m leaning on PVA with this build, if I am able to get the planks bent enough where there’s little tension. The main reason is I don’t enjoy wearing CA :-)
I’m trying any way that comes to mind on the best way to bend these planks. I use a ladies hair straightener to heat the planks up after misting them with water as they dry. I squeeze the straightener like I was using one of those crimper benders. Then I’m made a jig on the cork work top, until I’m ready to put it on.
I use this spade to try to edge bend the bow end.
First planks on.
Trying PVA on the edges.
I’m always changing the way I try to clamp.
The bow rises and it’s hard for me to get enough edge bend with the fear on snapping it. I’m hoping the PVA will handle any stress I leave in the planks.
I’ll keep trying new ideas and way I think I can get em bent better:-)
The third planks are tapered on the stern end. 3-7 are supposed to be easier than when it starts transitioning to horizontal.
Hi captain B,
When I start with bending, I always start with the "standing" way. I build a small tool, in my case for planks of 1.6mm. (wet planks are 1.7 or 1.75mm)
I think the images say what it is. Before I put them in for bending, I put them in a tube with hot water. (one side closed) From heating boiler.
After about 20 minutes a placed them in the "bending tool". (big word) :)
2 big parts are fixed with a curved rebate in the wood. Then I bend it with a smaller rebate piece in how far I need it and fix it. They stay flat.
Wait 24 hours until dry.
It is then try and retry until you find your correct bend.
After that, I start bending in the other direction. Also first wet/hot in the pipe. :mad:
I hope it can help you. If not, maybe for somebody else. Thumbs-Up
Hi captain B,
View attachment 628716 View attachment 628717
View attachment 628719 View attachment 628720
Thank you Papatoalos! Those are some great jigs you’ve made. I’ve got a similar jig that I’ve made but I made it for a much smaller build. You’re ideas are definitely worth trying.
I’ve reached the seventh plank on the starboard side. Planks have been typical and that has helped develop a routine . First I edge bend the bow end. Then wet it down, but not soak it. I’ve gotten pretty good at using the hair straightener. The mahogany planks are 2mm thick, heat up well and can handle quite a bit of bending. After eyeballing my bend but still warm I put in the push pin jig on the cork table top and let it dry. All but this 7th plank has almost laid right where they needed to be. The stern end on this plank needed edged down. I dipped the end in water while the straightener heated up. Being careful not to unbend what I’ve bent, heated up the stern end of the plank. While warm clamped it on the strongback. We’ll see how that worked later.
At both ends where the planks meets the stems, I worried about the lack of surface that was actually glued. I’m not for sure about the strength difference between PVA and CA, I don’t want to take a chance. So I cut some wedges and glue them after the planks have dried.
Here’s the bow. After I have mated and cut the stern end to meet the stems. I clamp the plank on the strongback and saw the bow end plank on strongback. I’m hoping the ends hanging over will help me cover where the cut water meets the bow. From experience this is a very hard piece to flawlessly meet for me:-)
This is the stern. When the ends get cut off there wasn’t going to be much touching. The bow stem could have been push farther out I think. But the directions said it was to touch the E frame.
Step 5 is completed, that was planks 3-7. Planks 8-12 will transition from the sides to the bottom. The middle of the plank will need to be beveled so a crack won’t appear between the planks. This should slow me down considerably. Here’s where I stand on the build.
I’ve only got one more plank glued on and one on being shaped. My wife added on her project that involves attaching 750 sq ft of burlap to the walls of her she shed / garage / decor storage. This takes much more out of me than model ship building:-)
I start by pre-bending a damp plank. Then while warm but not wet I strap it on the strongback.
Here is the middle of the plank just strapped on.
The top edge of the plank looks like this against the frame. Which is not what we want.
The way to get the edge down, the lower inside of the plank needs to be beveled. Here is the port side that I’ve beveled and glued on the same frame.
The way I’ve started to bevel the edges is just visually looking at the crack it makes on the outside when I press it down to lay flat on the frame. I couldn’t take a pic of this because it takes both hands:-) I make a pencil mark on the inside of the end of the plank I’m starting from and just do 3 or 4 inches at a time. The I place a piece of tape on the inside of the plank trying to duplicate the crack on the out side. I color the part I want to remove and sand away hoping I’m taking too little instead of too much:-) That’s experience talking:-)
The next plank will take a little more beveling.
Another thought for how it will be displayed to show scale, I’m thinking of trying to figure the water line and have it set like it was in shallow water with two fishermen ( who knows it could be Peter and Andrew, or maybe James and John). With them wading in the sea holding a net pulling them fish to the shore.
Well that’s all I’ve got on the Sea of Galilee boat but I’m going to post pics of what’s slowing down the build:-)
I’m about half done with this.
I’ve made it to plank 11 on the port side. It is by far the hardest so far to get right. I bend it, strap it on with 18 rubber bands, take a look at the crack between the planks and take it back off. I’ve been doing this quite a few times on this one plank. Pretty much the whole distance needs some bevel. I just do a little at a time. Looking closely at the 3rd pic , I’ll be taking this one off to bevel some more.
I’ve also worked on painting the mannequin and trying on new cloths.
On the starboard side I decided to sand the bevel on the top side of the plank already installed. This was a little nerve wrecking knowing I could mess up what’s already on. But it was easier to see what was needed. I when frame by frame and used a knife to cut right at the frames edge. The next plank doesn’t make it to the bow. It has to be cut to meet the keel. Here’s the bow end.
I sanded the bevel, on the right to except the next plank.
Then cut the plank to check the fit and see how much bend it’s going to need.
Quite a bit.
After soaking it for about 15 minutes, I heated it up and gradually got it to lay right on the strongback.
Next I’ll remove the plank and try my hand again at the beveled edge on the edge of the existing plank.
I’ve made it to plank #13 on both sides.
One thing that I’m doing out of order from the directions is the cut water at the bow. I left the planks hanging over the stem to try to hide the joint where it connects.
I carve the end so it fits between the planks and cut it off, hopefully a little longer than needed.
I hope I’ll be able to shape it after they all are glued on.
The next planks will be the last that connects to the stern. After that both ends of the plank will meet the keel. A plank a day has been my average. And I usually can add a block or two to the bow while a plank is being bent.
I want to say a little more about the cut water. Building it while on the strongback to me was a lot easier to see what it was looking like as I added blocks. This is how I went about doing it. I took a scrap plank and laid the edge flat on the lower block to copy the curve of the bow stem.
After that I traced the outline of both sides, on to the plank.
Then transposed the lines on to the square stock.
I only had to remove about a mm from each side for it to slip between the planks. I had to add an extra block just to fill a small space where it meets the stem.
If I redid it I might try to line up the plank ends better. I was hoping they’d just disappear when they met the cut water:-) I know it’s stuck on better. I’ve sanded the bow down a bit,(I couldn’t wait any longer) I still sand on it every time I set down in front it.
I’m starting on plank 15, it was the first plank that glued to the keel instead of the stem.
Here a shot of the stern with the 15th plank on the port side.
