HMS Enterprise 1774 POF 1:48.
Good morning.
Just some more of the same- I installed the remaining cannon with breech lines……still have to rig 10 ……Eish. Total procrastination ROTF .
Some pics :
View attachment 627160View attachment 627161View attachment 627162
And then :mad:o_OSpeechless :
I took this pic to show my marvellous immaculate perfect alignment….ROTFROTFROTF. I can live with the multiple little inconsistencies however the arrow shows my middle grating and corresponding deck planks being a problem child . I can’t believe I haven’t noticed this - I hardly see this with the naked eye- Eish a redo coming up.:rolleyes:.
Cheers Grant
If there was no arrow ……… then there was no problem.;) Had anyone already reported that?
But now …… a re-do is necessary, Grant.
And for the rest, she is becoming more and more impressive with nice cannon riggings.
Good afternoon Grant,
I'm sorry, but even after zooming in, I can't figure out what kind of huge mistake you made. The grating looks fine, and so do the planks. Could it be that the planks aren't completely aligned in the center?
I'm curious to see what this piece will look like after the correction.
Good morning.
Some pics :
Cheers Grant
Well, I can see how after all this time you missed it because I still don't see what error your arrow points to?? Is it the aft edge of the grate frame not over the deck support beam maybe?
Good afternoon Peter. After this photo I saw the middle grate not being square to the other hatches etc. It is so marginal even after pointing it out Arlene cannot make out the discrepancy………If can unglue this easily I will fix it.
I don't see the problem. Some camera lenses cause distortion. It's also true that I'm a bit blind as a bat.
Salud Beer Beer
Hello Guys. Arlene (the Admiral) can’t see it either…..the centre grate is not square to the others and centre line. Ever so slightly. As I said to PV if I can unglue it without breaking it I will change it.
Guns look good all lined up there in the photo. Feeling your pain vicariously RE: rigging cannon.
Once you see something you'll never unsee it. Maybe also check the planks behind (to the stern) it as well.
Hi Paul. A very true story. I don’t mind the small deviations in the Carlings as we won’t see these ……mostly ROTF , however this grating does affect the deck planks (as you mentioned) going back. Ahh how photos reveal the true story of my ship building skill…;). Non the less I really enjoy my ship so far and even more so playing with her. (Sounds badROTF).
Cheers Grant
This weekend was a lazy one…..we only had all the kids and wives around for brunch this am….so…...plenty time to play in my shipyard.
I continued scratch building the chain pumps - WIP :
No crank handles yet, and I have used a straight bar to get all the brackets in line.
The four main square pillars are from the kit, however these were totally black with char. I have removed as much as I could before these started to loose scale and change shape. So dirty square pillars it shall be. I shaped and made the smaller fore pillars- I still have to make the stern ones.
The kit did not include sheaves so I decided to make the worst sheaves I have made to date…..my Blades and mind refuse to cooperate…… ROTF Added the outer sheaves on the fore pillars.
I still have to make the cranks. The connecting sleeves for the crank handles I am making by soldering brass tube to the connecting rods….plenty to go - clearly no colter pin.
Some close ups of my attempt:
Cheers Grant
Grant,
The pumps are really coming along nicely, with all the customization you are giving them.
I tend to agree with Peter and Daniel, the misalignment you refer to is apparent to you but so subtle to be almost invisible to the rest of us.
Thanks for sharing your wonderful WIP!
Grant,
Thank you Brad. Yea I am happy with them although my scratch detailing is not so accurate. I struggle with making these tiny little aspects- especially the brass work. I will get there one day…….in a galaxy far far away ROTF .
The pumps look great!
For the misalignment, I guess I’m an even greater noob than I thought. I can’t even see what the problem is…
Thank you kindly. The Admiral says I’m being pedantic ROTFSpeechless.
Cheers Grant
Good morning. I decided to put my pumps into the ship. There is some touch up as my worn appearance on the metal is a little blotchy.
I soak the brass in vinegar for at least 24 hours so it tarnishes up. I then blacken once for 30sec and buff. Has mostly worked.:rolleyes:.
Some pics :
My scratch building details, especially brass work, needs some attention, however I am pretty chuffed how “Grants pumps” came out.
Cheers Grant
Some pics :
View attachment 628110View attachment 628111View attachment 628112View attachment 628113
Cheers Grant
The pumps with the blackened metalwork looks great, Grant.
Some pics :
Cheers Grant
The pumps look great Grant! I have also had problems with blackening after soldering because of flux residues and I found the best thing to use was some alloy car wheel cleaner (acid type) from my local auto shop. Soak for 2 minutes, rinse with clean water and then dunk in 10% brass black for 1-2 minutes and rinse off.
Dom
Grant those pumps came out fantastic! The contrast between the deck boards and pump works is awesome.
Good morning Daniel. Thank you kindly Sir. My colour contrast, where such a hit and miss experiment, however I guess I got the luck as I am really liking my look and feel.
Those cranks turned out great, Grant! Bravo!
Thank you indeed Paul. I still struggle to get my scratch details accurate. They always turn out to be more representative than exact, however from my Victory to now I am improving.....just a tad ROTF . I had a lot of fun making these pumps and cranks and for "Grants pumps" they look cool on my ship.
From the master of detail I appreciate this compliment Peter. I am a total metal work novice and my shipyard becomes a comedy show when I solder etc.....a lot of laughing occursROTF.
Dear Grant
those pumps came out wonderful
Thank you Shota.
Dom
Good morning Dom. I always appreciate your help. Cheers Grant
Good morning from a South Africa in mourning…..on Saturday the All Blacks (New Zealand rugby team) didn’t just beat the Boks (South African Rugby) they whipped our “ass”. @ConsNZ was definitely smiling Speechless.
Anyway, I did the waterways and margin plank on the upper quarter deck. I looks way to symmetrical for the style of the rest of the ship so hopefully a few irregular deck planks will break this.
Cheers Grant
