So I think I've decided on a design and strategy for my new cross-section. Granado 1:72 - I have already made a Miniature Arts one in pear which gave as a birthday present to a cousin. However, I wanted to do something familiar for a first scratch build, so I'm following the Staudt Granado plans with a little variation From P. Goodwin's book.
For material, I sourced some very nice Castello. More yellow than my other pieces, which are a little whiter.
I'm laser cutting the frame pieces. Biiiiiiiiig learning curve and still can't really figure out kerf and material loss from filing, so everything is cut oversized and final sizing at a later stage. Added to this challenge is variation in the amount of power required to cut through the wood as it can vary slightly across a single sheet. This makes power/speed selection difficult because I don't want to burn the material, but I do want it cut all the way through! Overall my main concern is the accuracy of the inside line of each frame so as to reduce fairing too much because I'll be leaving out chocks on some of the frames. This will make then difficult to fair without distortions.
As the frames are glued end grain to end grain, I'm using bridging blocks/scabs to give strength during fabrication. Everything will be hand polished and waxed which adds a further level of challenge with compulsory tooling wherever there are parts glued together.
All I have completed so far is the keel and a couple of frames, but I’m set on my path now so here's hoping!
