Dutch 143' ship GIDEON 1664 in a recent scale
Berlin/Germany
Hello sometimes my brain outwits me out - so I tryed to change the scale for GIDEON from 1/66 towards 1/44 by using the 150% scale...
and I certainly got 1/66 × 1/2 = 1/33 :oops:
So now I have got a very, very fat Dutch Lady!
But I allways dreamed about one model in a "recent" scale:
Here my 125% trial in some 1/55(?) scale in comparison to 150% copies.
I know it is madness but I really fall in love to her - sometimes it is really better to be an independent single without any supervision of any admirality... ROTF
So let's use this quote as the real reason:
So let's do some stupid things we do like.
Best wishes from Berlin Card Yard,
Chris
____
ErrorAlert:
She iwas certainly build 1681 and not 1664, sorry for this.
Today's night I started with the criticism of the plans as I was told to do - and Instarted with labelingthe frostpaper:
Here the bulkheads in 1/33 scale side by side:
Here the Centerboard with it's 8mm thickness - measurement done admids of the given lines:
First I draw all the horizontal lines in frostpaper
Than I decided to add all the vertical lines in perpendicular to the CWL:
Aaaaand now it is starting that the wrapping of the paper is coming to be seen:
So the lines are bent towards port and all the lines, too.
So here I stopped and decided to look if it is only this particular photocopy that is bent below the warterline such heavily or if it is problem infecting all my seven 150% enlarged copies Cautious :mad:
That's all from here and me for today,
Chris
Okay back to start - found the booklet with the original drawings send by Ab. They were firstly downloaded and printed and are straight - so restarting the hole story!
Something about data from "Dutch warships in the Age of Sail" - here AKERBOOM and GIDEON are born 1664 and not 1681:
Also the drawings by VdV are the right ones.
Now U brought her up to 1/33 exactly: the 143 Amsterdam Foot with its 283mms length does become 40.469mms;
40.969mms through 33 makes 1.226,333mms
and here we are:
Now she is really a big fat Dutch girl Okay
Next step is glueing the parts together so they become a complete plan.
Here the first steps guarded by my workminion:IMG-20260824-WA0036.jpeg
And here my start to glue the centerboard into one very big pice from seven parts:
The two rulers and the one cent coin may give some idea of her sitze to you (the set square is 30mm in length).
This from here and now.
Today I measured my copy and recognized the Lpp of 140 Amsterdam voet makes certainly
283mms × 140 and scaled to 1/33 is 1.200,6mms it does fit:
Here the hole drawing in a pair of pictures for this famous "closer look" - so it is...
And in one picture
Have a nice day.
Have been asked how many hours I do think this project will need (in a modelbuilding beginners' group)?
My answer: Really I do have absoloutly no idea how long, I do use bookbinder's cardboard and at this size I will have to invent other techniques to get a stiff construction. The centerboard could be a twelve sheet layer of 1mm cardboard - much too heavy, so I would have to cut twelve times the this same part and glue it ontop each other - but the tickness of glue suddenly becomes a part of the computing! You see? So I do not think about time I do ask myself how many clever solutions I do have to find - one more than problems visiting me - I hope very much.
Today I copied the Heinrich Winter's sideview into 1/33 scale by enlarging to 306%A1p8e-xssuL._AC_UF894,1000_QL80_.jpg
So I got the side with it's gunports positions and the gallion in detail to my immense size - without the underwatership:
Today a little progress was made
cutting out the centerboard template:
I enlarged the "Dutch Twindecker" a bit too large:
I may messed up my bulkheads?
After N° 16 there are still framed but -
where to find them in the lines plan to build the transom right:
:eek: Where did I implemented an error!?:eek:
I do think I figured out what was made wrong:Polish_20260901_170929171.jpg
THREE "H"s as similar bulkheads so I do need to replicate the main bulkhead three times as the hull's lines are quite parallel admidships:
So undoing the numbering tomorrow so I can start to go into the bookbinder's cardboard.
I think this is normal for most nations' ships. This dead flat area is well marked on contemporary British ship plans where the station lines fore and aft of midships are marked with parentheses..... fore to aft (B), (A), 0, (1), (2). Once past the dead flat, the frames are marked without the parentheses,,,,,,, from midships forward for example,,,,,, 0, (A), (B), A, B, C,,,,,,, &c.
Hello friends, very slow progress but I started to construct the stand (still classifyed!) and the mid of is orientaded at the mid of the Lpp. The bulkheads will be 5mm thick, the centerboard may really be in need of this 12mm to bear the wight of cardboard, glue, filler and gold
By this I figured out that the plan fits 1/2 onto my home yard in my kitchen - and yes she is a big girl compared to my flat. :cool:.
Today I dealt with the numbering of my bulkheads. N° 1 Up to 7 could stay as they were and 8 changed towards H1, 9 towards H2, and 10 was converted into H3:
Than comes 11 and so on untill 14,
and 15 is the last existing in the lines drawings, so I "invented" 15a, 15b, and 15c - that have to be constructed to give the transom a good backing and the "doll house" of the captain's chamber a solid environment:
That's all for today, dear friends ..
Today I enlarged the Heinrich Winter plans (not all sides) by 255% to come close to my 1/33 scale and so I can construct the gallion into the centerboard/"spine". By doibng this it will be easier to handle it than any separate part that has to be glued to then stem later on.
So my question is If the placement is done right with the cutwaters so deep für to the "higher" CWL?
Here Ab's solution for the same plan:
Here a cutout for showing some details:
By the way - my diet works:
I can see my feet!
Today I started my work on the centerboard
And with the placement of the cutwater I am completly irritated (as to be seen in the difference between the original and Heinrich Winter's CWL. .
The placement of the bowspriet looks right.
I had to lengthen the centerboard template byt three millimeters to get my Lpp of 1.200,3mms at the CWL.
Chris
Hello,
today I am still dealing with the gallion addition to the centerboard.
I am still un shure If my placement and distance between CWL and the opening for the "Spritzurring"
I coloured the lower opening in orange...
Polish_20260909_113502787.jpg...it's minimal distance to CWL is 21,5mms x 33= 709,5mm -> 2-1/2 Amstrdm. Feet Redface
So the ropes are getting very very wet.
@Ab Hoving @Herman is my placement historically correct for midst of the 60th* ?
Here dealing with the sprietmast's slot for the centerboard. Position of the fockmast is quite easy to construct:
here the completed cut by Heinrich Winter:
Thank you very much.
*17th century ;)
Hello,
View attachment 633574...it's minimal distance to CWL is 21,5mms x 33= 709,5mm -> 2-1/2 Amstrdm. Feet Redface
*17th century ;)
Hi Chris.
I am no expert, just a hobbyist, for now following the drawings of Blom and Dik. I am now studying Ab’s book “Nicolaes Witsens Scheeps-Bouw-Konst open gestelt” to get more basic knowledge. What you come up with looks ok to me with one remark. Looking at one of your latest drawing, 1788955430658.jpegthe bowsprit seems to come in contact with the upper parts of the galleon. It should of course stay clear.
Enclosed a picture of my 7 Provincien.
First steps with the bulkheads have started
I pinned the centerbord to the table's top and added the ruler parallel to theowest line called Alpha. Than I looked for 90° edged by the use of two set squares. By the use of these I prolonged the waterlines to the sheet's edge and aligned the bulkheads.
The outline of the bulkheads is coloured in yellow due to the good contrast.
After this I added the slots for the horizontal boards and by dots 5mms away from the deck's top the curved slots for the deck(s).
My time invest? I needed one hour for the first two bulkheads
Best wishes from Berlin Card Yard, Chris
P.S.:
Here I will have to add the dotted line for the back deck as a support:
Hi Chris.
I am no expert, just a hobbyist, for now following the drawings of Blom and Dik. I am now studying Ab’s book “Nicolaes Witsens Scheeps-Bouw-Konst open gestelt” to get more basic knowledge. What you come up with looks ok to me with one remark. Looking at one of your latest drawing, View attachment 633599the bowsprit seems to come in contact with the upper parts of the galleon. It should of course stay clear.
Thank you very much Herman! So I have to avoid contact between bowsprit and the upper parts of the gallion.
As shown by Van de Velde:
