HMS Enterprise 1774 POF 1:48.
Good evening.
I am busy with the cathead and I am convinced the kit design is wrong. They are underlaid catheads which is correct, however I am sure the tails won’t end by attaching to the bowsprit step?
Goodwin example has the cathead tails finishing under and being bolted to the deck beams.
Here is how CAF has mine going :
HELP…… ROTF
Cheers Grant
OH - I said I would post some non blurry photos of my stove chimney:
On the Kingfisher it did go under two beams but came nowhere near the sprit step. FYI I made mine in two pieces and hid the join under a beam.
Good morning Paul. I had a look at your Kingfisher again and this definitely makes more sense. I cannot see any cathead putting so much foreward pressure onto a bowsprit step or other. I will attempt to do what you did. Thank you.
Cheers Grant
Good morning. I have found the answer to my Cathead concern. Here is a pic of how these go on the HMS Enterprise 1774. My big issue (like so many things with this kit) is the deck beam placement. I only have one beam vs 2 and I cannot notch the cathead tail to this as the angle of the cathead to the hull would reduce to much…..hmm
Kit mods don’t always work….. ROTF.
Let’s see…
Cheers Grant
I believe that is ZAZ3387. It should be on the bottom left of the full plan. ZAZ3387 is not dated specifically on the RMG site, but it does give circa 1771-1778. There is also ZAZ 3390 dated 1787 but has very little detail. Lacking better information ZAZ3387 seems to be a reliable source IMHO.
I’ve recently started working with Google Gemini - here in Mexico it has become a quick go-to. Glad to see others opting towards AI.
Good morning Hugh. It has been extremely useful, however sometimes “He/She” ;) gives incorrect information so it is worthwhile to check back to original docs at times. Cheers Grant
OK Grant !!!!
Were you there??
Awesome display - .
Regards,
Good afternoon John. I was not at the stadium unfortunately. The game was as awesome as the fly over. There was plenty of controversy about that fly over although it certainly energised the crowd.
Noted -- but Grant is big Rugby fan - this was for him in his hometown as well- and this became world-wide news
True story John. I was surprised this bit of excitement in Cape Town went international. You would certainly know the risks associated with this low fly over, but for the layman rugby fan they loved it:eek:.
Off topic post deleted out of respect for Grant's build log.
No problem at all.
Wonderful progress Grant, as always you're doing magic with this kit
Cheers
Guy
Good afternoon Guy. Thank you kindly. It has been a beautiful challenge- I’m having plenty fun building this one.
Wow Grant, very nice working!! :D Thumbsup
Thank you very much
