How to bend 3mm thick tilia wood?
  • Thread starter Thread starter Naima
  • Watchers Watchers 11
I Bended it!!! ... using lots of elastic benda and Wellington soaking in hotel water and restino all night , after 3-4 days of attempts.
But a small problem I hotel to fix with sone glue and a clip...
Another problem is I bent too much ... but may be I should adapt the reat deck or try to unbend part of the stern ?
Personally I would rebend the stern facade, my friend.
I wanted to Use a 3 mm thick tilia wood for base for a ship Stern does someone knows if I can bend it like the small thin panels?
Hi naima a way to improve the bending process is soaking the wood piece in a warm solution of urea (a common nitrogen fertilizer ). Urea helps to soften lignin and hemicelluloce wich are in part responsible of wood stiffness.
Maybe it is better to hold plank inside pot, not autside (i mean oposite wall side)? Because of water wapor.
except if you can bend it enough to get it on the inside wall, then it wouldn't be that tough to bend. If you use the outside of the pot, you can still leave a lot of it straight or not as tight a bend as the container around which you are bending. :)
For planks, not an entire stern :),,,,, broad bending is not difficult and nothing fancy or cumbersome like steam pots are needed. Water and some kind of container like a piece of plastic pipe with a cap on one end, a hair drier or hot air gun and an empty can is all that is needed. None of the methods above for broad bending work for the edge bending so the planks that have been tapered in breadth will be shaped to neatly sit on the frames/bulkheads without lifting. That is not as easy, but just as important if not more so.
