HMS ENTERPRISE by Keith 1:48 scale. New Kit from M.D.
Another milestone reached. She's out of the cradle. Quite easy really. And as a testament to the accuracy of this kit, this is it with absolutely no work to the outer hull as yet., just care when fairing the ribs. Also there is now room to do what was discussed in my last post. The tapering of the head. The excellently detailed CNC boxwood figurehead is roughly fitted. I'm going to some work with staining and a dark wash to bring out the detailing. The stern gallery artwork is even more spectacular. Can't wait to get round to that. But that is some time away yet. Really pleased with the result
Looking great Keith! Nice work!! Magic Mike
What a milestone and great view to she her standing free and showing her nice lines, Keith.
Keith,
Wow! You have done this kit justice! What an impressive hull, standing without the cradle, it looks simply superb!!
Your pictures show what a wonderful job you've done and also the quality of the kit.
A great kit in the wrong hands can be a disaster but, in your hands, this has become a thing of beauty.
Thanks for sharing!
Keith,
Thanks for sharing!
Thank you for your very kind comments Brad. But it is really as you say, it's the quality of this kit that makes a good result
Good afternoon and thanks to all. The next stage of this build is the make up and fitting of the cabin bulkheads below the quarter deck. These are made of sections of 3 x .5 m laminate pearwood with the awkward tendency to curl up as soon as the glue is applied, so had to have glass panels ready to trap each section until dry. A bit tricky but looks OK in the end. Also the double capstan is assembled and fitted. The 1:1 drawing is necessary to get the correct height of the centre spindle.
I have not seen anywhere written details of the building process for the hawse pieces for this kit, so l will give my interpretation of how l think it should be done over the next few days, going by the 3D drawings in the pdf manual. I hope it will work out OK, but only time will tell. I have started by making the 2 jigs supplied with the kit which support and accurately place the parts during the building process. The parts making up the jig are a really tight fit so a little cleaning of the char is necessary in all the joints. The next step is dentifying the components, and making up the last of the bow cant frames, x8A and B. The hawse pieces adjoin to x8A. The hawse pieces themselves consist of 28 seperate parts (F1 to F7) that join together making 7 port and 7 starboard frames as shown in the photos . The weather here, over the last week or so has been extremely hot, 37 deg C outside and 31 in my workshop, so am calling it a day for now. I shall continue over the next few days detailing the process as l understand it, so until the next time . . .
Sorry to ask about a post so much later than it was posted, but I could use some help. How did you get the angles of the cant frames and hawse pieces correct? I've struggled with this in the past with POF. I have some complicated ideas using trigonometry and jigs for the cants with sanding lines parallel to the end of the frame, but this one looks like it is not only canted, but tipped inward. Did you just do these with some finesse based on experience or did you have a system? I ask because whatever you did looks great. Thanks!
Hi Glen. Thanks for your comments. I do not have a system or use any complicated formula. I have built a few of these kits now. With this kit there are rough lines etched into the parts to help guide the shapes and with careful sanding and lots of fitting as you go, it all seems to come together. It is a bit tense at the time though, thinking how easy it is to mess up
