Micro Lux table saw blades
Since Micro lux no longer offers the 230 and 180 tooth table saw blades for their table saw, are there any other blades equivalent that I could use? Mini circular saw blades with a 10mm arbor seem pretty common, but can they be used in a table saw safely?
I have a Proxxon circular saw - I think it is the same animal that is sold as Microlux too. I've got different blades to it and not only Proxxon ones. They work fine and safe. I even use a blade (most likely a Dremel) with a bigger hole so I made a brass ring into it with the compulsory 10mm hole.
János
János
Thank you for your reply. I have my eye on a few that I am going to try.
Try searching for slitting saw blades, MSCdirect do a selection of them for different size shafts.
I just entered slitting saw blades in a search engine and several venders popped up.
I got mine from a German company and use them for all my plank cutting after coarse sizing on a band saw. They work very well on plastic as well.
Kim
