My 1/72 scale aircraft
B-25 update…
Built the main wings…
Then I test fit them on the fuselage…
I think I am going to finish the fuselage and everything that goes on it and add the wings afterwards. I can build them as sub assemblies to be glued on later. There will be no putty needed as the joint to the fuselage is excellent.
B-25 Update…
A lot of work on the fuselage assembly…
Paint, guns, etc…
I decided I wanted to paint it the sand color the aircraft stationed in North Africa were painted.
IMG_4709.jpegIMG_4708.jpegIMG_4707.jpegIMG_4710.jpegIMG_4711.jpegIMG_4713.jpegIMG_4715.jpegIMG_4719.jpegIMG_4720.jpeg
I will continue to add guns and canopy frames, etc. then I can add decals and clear coat. I will build the main wings as separate assemblies to be added to the fuselage later.
B-25 Update…
Paint, guns, etc…
View attachment 645312View attachment 645313View attachment 645314View attachment 645315View attachment 645316View attachment 645317View attachment 645318View attachment 645319View attachment 645320
A. Nice color, Dean. And the seams came out very nice.
Nose finished…was a small window at the bottom of the nose, the upper canopy and the nose canopy. The nose canopy has 4 guns that go thru it, and one mounted to the middle of it. That made assembly interesting…having to align and pass 4 guns through it at the same time, while trying not to knock off the center gun.
Now I can paint the black on the wing leading edges and add decals.
After further investigation, it seems the B-25 squadrons in North Africa and Italy did not use de-icers (rubber boots on wing edges). So I will not be painting my wing edges black, although I think it looks cool. :(
