The Great Republic 1:48
I did not get as much done this summer as I thought I would but it's time for another progress report for the record. In the last post the deck cabins were just being started. They aren't finished but they are screwed down to the deck and they each have a removable roof. I don't now why but they do. The deck is now colored with Min Wax stain, a gray blue color that I had to send away for. I wanted a light gray/ bluish transparent color and this fell short of the desired shade by a tiny bit. Knowing my tendency to keep trying to get better with paint and making a real mess of the job, I chose to stop right there and leave it alone. I don't think I like it a whole lot but there it is. Your thoughts? Next came the channels. I could not find anything on the measurements of this timber so I did an educated guess and arrived at the conclusion that the channels were 22 feet long at my scale. I'll have to do one once I get the masts stepped and see what it looks like. The jib boom is finished and looks fine to me. I bought one of those tools that lets you run a stepped down size of dowel starting with the largest diameter part and turning down the rest at smaller and smaller diameters. You mount the dowel into a drill motor chuck and then run the dowel into this block with several diameter cutting holes and presto chango, you have a dowel ready for sanding at the diameters you want. Made the whole jib all in one piece which I hope will be much stronger than several smaller pieces glued together. I may redo the top mast of the three primary masts over again for the same reason now that I have one of these blocks to turn the dowels in. Look much nicer too.
I even built and installed the railing around the weather deck, painted it and then stained the top rail ( monkey rail). I was surprised that I only had to build the rails two times and then installed them. The stern rail took some remodeling to get it level and straight but it came out ok. actually looks like it belongs there. That taff rail gave me a fit. Then came the mast coats. Made them for all the masts and then fitted a block that goes all around the jib and the bowsprit. It's called the "cap" of all things. After that I carved an Eagle head for the figure head and was surprised again at how well it came out. Not as good a some I've seen like the Staghound figurehead which is amazing but it looks like an eagle at least. Have to try the rear Eagle now. By the way, what takes finger prints off copper that won't discolor the metal? Anybody?
That's about it up to now. Here are a few pictures:It looks like I didn't get very good pics of my rogress tis summer. I'll take some more tomorrow and post them. Pete. That's the little tool for reducing wood dowels. pretty handy I'd say. Only $28 with thefreight. It's smaller than it looks.
I once read that good clear photos were not readily available until after 1855. That was probably about western town pictures of the local bad guys at te OK Corral. If that's true then the clear black and white picture above was taken after the fire by at least three years. Also the plans that you refer to don't look like accurate measurements of the GR.. Without a date it could be a different four masted bark after all. So much for the confusion.
Actually, that is NOT a photograph, but a lithograph and any image of a painting I provided closely or nearly, represents GR's configuration as described by Duncan McClean...a first hand accounting. What my research is always attempting to decipher...is errors depicted that *MIX & Match* structures that were found on the GR before and after the fire. She had double topsails with a mixed Forbes design, that slid down the outer foremast doubling....unlike Howes, where the lower topsail was fixed to the mast cap, via a crane. She had a complete circumpherential stanchioned rail protecting her weather deck.
Great progress Pete....and thanks for the Staghound compliment. Your GR surely is coming along for sure....the deck color is not all that distracting....a mild blue grey would begin to develop anyway from exposure. It also is a good example of personal expression. I'd like to see your eagle figurehead. One idea that you might find helpful. I scoured the internet and local pawn and trinket shops, for an eagle emblem that I could modify for the stern of my GR.
Rob
I was so happy with my figurehead I decided to go ahead and use it. I've never carved anything in my life and since I could tell what it was ok, I decided to use it. At least it's the right length for my scale but it's still pretty small. I need to take some more pics to match what I was yakking about in my post so that still needs to be done. The taff rail is another problem. I rebuilt it three times and the frames under it but I just couldn't get it right So yes it's round on the original but it's going to be oval on my GR. That will just be one way you can tell I built it if you ever happen to see it at the White House. Ha! Yours looks really great. Hope you took a close up of the stern Eagle. It's kinda hard to see.
Sorry for the delay but life gets in the way sometimes. Batteries ran out on my camera and I haven't been to the store to get some more.--Yet. Meantime I've run into a snag on the GR that requires some knowledge be requested from the forum. If a deadeye is 5mm for a model at 1:78 scale, how big would a deadeye be for a 1:48 scale model?
Show me the formula if you can because it will work for the rope and blocks too I think.
(5 x 78)/48= 8.12mm
Thanks for that Pepite 1/60. It's amazing how simple that is but do you think I could remember it? Noooo way. At 85 my math mind is a blank. Use it or lose it so they say. The only thing that gives me hope for the future is that I had decided that 8mm would be right because it looked right. However I wanted to be sure. Thanks very much for the formula too. That will help a lot. Pete
You're welcome.
Here is bit better image.
