Sailing ship models - Cut Aways - internal structure
  • Thread starter Thread starter Uwek
  • Watchers Watchers 7
Uwek
Administrator
Administrator
Forum Moderator
Vienna, Austria
I found some Cut Away models of sailing ships, which are showing the internal structure and could be for some interest for Plank on Frame (POF) modelers
BELLONA (1782)
https://digitaltmuseum.se/021176541639/bellona-1782
https://digitaltmuseum.se/021015976368/utstallning-i-flottans-paviljong
KRONPRINS GUSTAF ADOLF (1782), 62 gun ship
https://digitaltmuseum.se/021176498282/kronprins-gustaf-adolf-1782
https://digitaltmuseum.se/011014855603/b1392
Scale: 1:24. A contemporary half-longitudinal model of the 80-gun two-decker HMS ‘Collingwood’ (1841) built plank on frame and mounted on its original wooden baseboard. Externally, some of the planking has been omitted to show the layout of the framing whilst internally, the deck beams have been cut away to show the composite construction of the hull with the use of iron riders, diagonal braces and knees. The combination of iron and wood enabled larger and stronger ships to be built. Originally designed by William Symonds in 1832, the ‘Collingwood’ was eventually launched at Pembroke Dockyard in 1842. Measuring 190 feet in length by 56 feet in the beam and a tonnage of 2589, she required a complement of 720 men to operate the 32-pounder guns. She was later converted to screw propulsion at Chatham Dockyard in 1861 although not fitted for sea service. Her machinery was fitted later but as was the similar fate of some of her sister ships, this proved to be un-economical and she was sold for breaking to Castles of Charlton in 1867
https://collections.rmg.co.uk/collections/objects/66765.html
Scale: 1:24. A model of a half midship section of Royal George (1756) made entirely in wood with metal and organic fittings and painted, stained and varnished in realistic finishes. The hull is painted white below the wales, the wale itself is painted black and the hull above the wale is stained and polished wood. The upper hull is sectioned and scored to resemble planking that has been fixed to the frame with treenails. The section of frieze has been finely painted showing trophies and medallions on a blue ground. The inboard hull is painted black to just above the gun deck and also the lower part of the middle deck. The gun deck beams, knees and planking are polished wood. The middle deck knees and beams are painted red and the upper deck knees and beams are cream. All four decks are stained and polished wood and scored to resemble planking. The inboard hulls of the upper and quarter decks are painted red with blue above. There are ten gunports, two on the quarterdeck, the remainder have lids that can be opened (one lid missing). A section of channel is positioned between the upper and quarterdecks. Four guns on wooden carriages are shown, one on each deck. The guns are made from turned wood painted grey and the carriages are red with sea service trucks. The model is displayed on a rectangular wooden baseboard with bevelled edges and turned feet. The model is supported along its keel section by two brass stabiliser supports
https://collections.rmg.co.uk/collections/objects/66456.html
"linjeskepp om 74 kanoner enlig af Chapmans ritningar från 1792, vilka, lätt modifierade, användes för byggandet av tre linjeskepp: Gustaf IV Adolf (sjösatt 1799
https://digitaltmuseum.se/011024822503/fartygsmodell
Nice pics Uwe and thanks for posting.
Somewhere on YouTube I have seen a model of Fleuron that is split top and bottom and the top raises by two rods operated by electric motors.
Kind Regards
Nigel
It would be nice to see... if you will come across again
Hi Jim,I might be completely wrong,but I have a feeling it was displayed at one of the Japanese 'Rope' exhibitions.It was an outstanding piece of work
Kind Regards
Nigel
Kind Regards
Nigel
I guess it is this Le Fleuron built by Gordon Stiller - very good model and highly interesting
Gordon Stiller - 1729 French Frigate Ship Le Fleuron
other models built by him
Gordon Stiller - 1784 British Ship HMS Bounty & Bedford Whale Boat
Gordon Stiller - 1778 Ship USS Confederacy
Gordon Stiller - 1750 British Ship HMS Royal Caroline
Gordon Stiller - 1776 Ship Oliver Cromwell
A really good modeler....
Uwe I have had a search and no it isn't Gordon Stiller's model.It is only split along one line and the top raises on two stainless 'pistons'.Trouble is that if it was a Japanese post the search facility on YouTube won't find it,i.e. the title is in Japanese.
Kind Regards
Nigel
Kind Regards
Nigel
I think I know / remember which model you have in mind.
Via Pinterest you can come to the images - but I have problems with the further link of japanese page
https://www.google.com/search?rlz=1...iAhXEZ1AKHbJXCEYQsAR6BAgIEAE&biw=1518&bih=652
789abac00c791616dae751574a6bd47f.jpg bd4ab830007f4c306b17847e76367d79.jpg c0330f94ff9117ad311a3235a65153bf.jpg
some drawings / sketches of the HMS Royal Albert 1854 which fits to this topic
Section of a First Class, First-Rate Line of Battle Ship of 131 Guns, with Screw Propeller & Auxiliary Steam Power Royal Albert (PAI6692)
Illustrations of the Spars, Rigging, Sails and Interior of a Steam Line of Battle Ship with views and description of the Warrior and Royal Sovereign, Iron-clad and Turret ships... Line-of-Battle Ship Class of Royal Albert, Wellington etc (PAH9267)
https://collections.rmg.co.uk/colle...el-344706;browseBy=vessel;vesselFacetLetter=R
